Lua Sample Script for Temperature Sensor
nettworker
Post by nettworker »
Is there a sample Lua Script where i can see how to react on a temperature sensor and switch another device on?
Thx
Siewert308SW
Domoticz version: Stable
Re: Lua Sample Script for Temperature Sensor
Post by Siewert308SW »
Something like this...
Beware, it's a personal script and not usable as you maybe don't have a UPS (Pico Power) or some functions.
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
	@ activity_heating.lua
	@ author	: Siewert Lameijer
	@ since		: 1-1-2015
	@ updated	: 13-3-2017
	@ Script to switch ON/OFF heating when someone @ home or not
-- Someonehome Switch
	local someonehome					= 'Iemand Thuis'
	local nobody_home					= 'Niemand Thuis'
-- Nest Various
	local nest_setpoint					= 'Nest - Setpoint'
	local nest_setpoint_idx				= 77
	local setpoint_low					= 17
	local setpoint_high					= 21
-- Various Switches
	local pico_power					= 'PIco RPi Powered'
-- Heating On when someone @ home
	setpoint_current_temp	= tonumber(otherdevices_svalues[nest_setpoint])
	if otherdevices[someonehome] == 'On'
	and otherdevices[pico_power] == 'On'
	and setpoint_current_temp == setpoint_low
    and timebetween("08:30:00","22:00:00")
	then
		timer_body = 'Someone at home, turning ON heating'
		timer_body0 = 'Current Setpoint: '..setpoint_current_temp..''
		timer_body1 = 'New Setpoint: '..setpoint_high..''
		commandArray["OpenURL"]="http://"..domoticz.ip..":"..domoticz.port.."/json.htm?type=command&param=udevice&idx="..nest_setpoint_idx.."&nvalue=0&svalue="..setpoint_high..""
	if otherdevices[nobody_home] == 'On' and otherdevices[pico_power] == 'On' and setpoint_current_temp ~= setpoint_low then
		timer_body = 'Nobody at home, turning OFF heating'
		timer_body1 = 'New Setpoint: '..setpoint_low..''
		commandArray["OpenURL"]="http://"..domoticz.ip..":"..domoticz.port.."/json.htm?type=command&param=udevice&idx="..nest_setpoint_idx.."&nvalue=0&svalue="..setpoint_low..""
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
