robgeerts
- Domoticz version: 3.7067
Re: New Dashboard Design
I can fix this in the upcoming days!
- HansieNL
My Toon Thermostat setpoint is still seen as on/off switch. Should this one work ok already?
Blah blah blah
Anybody experiencing problem with limit of the Wunderground API?
Hello, Your wunderground API key exceeded its allotted usage today by making 12 calls within a minute but the limit is 10.
- HansieNL
I had the same a few days ago when I was editing and refreshing the page.
Did you refresh the page more than 10 times within a minute?
Blah blah blah
- gjaa
I've changed the collor of bulb_on in to a smooth yellow bulb
Is there a possibility to ad some more images (switch, tv, door-contact etc.)
- bulb_on.png (15.36 KiB) Viewed 3412 times
HansieNL:
Maybe, while testing I often reload page.
in main.js before:
add this block of code:
Result:
To convert font-awesome icons to png I found this website: http://fa2png.io. Just change color to any what you prefer and size to 57px, leave margin on 0.
Yeah, it is quite easy:gjaa wrote:I've changed the collor of bulb_on in to a smooth yellow bulb
in main.js before:
else {
var switchHTML = '<div class="col-md-4 mb no-pr" data-light="'+data.result[r]['idx']+'" onclick="switchDevice(this);">';Code: Select all
else if (data.result[r]['Name']=='Radio'){
switchHTML+='<div class="transbg"> ';
switchHTML+='<div class="col-md-4 no-padding">';
if(data.result[r]['Status']=='Off') switchHTML+='<img src="img/radio_off.png" class="off icon" />';
else switchHTML+='<img src="img/radio_on.png" class="on icon" />';
switchHTML+='</div>';
switchHTML+='<div class="col-md-8 no-padding">';
switchHTML+='<strong class="title">'+data.result[r]['Name']+'</strong><br />';
if(data.result[r]['Status']=='Off') switchHTML+='<span class="state">KI</span>';
else switchHTML+='<span class="state">BE</span>';
$('#switches').append(switchHTML);
}To convert font-awesome icons to png I found this website: http://fa2png.io. Just change color to any what you prefer and size to 57px, leave margin on 0.
robgeerts
Thanks, I've added this to Gitlab for the radio-button, as set in CONFIG.JShpapagaj wrote:HansieNL:
buttons.radio = {image: 'img/radio_on.png', title: 'Radio', url: 'http://nederland.fm'}
Added this to Gitlab, you can now simply change the following line:gjaa wrote:I've changed the collor of bulb_on in to a smooth yellow bulb
var buttonimg = 'bulb';Code: Select all
var buttonimg = 'bulbyellow';-
robgeerts
I added it to Gitlab, you can download the latest version (or only main.js) or add the following code to main.js:gjaa wrote:Thanks, it's working
Another question
How can I add my solarpanels?
I entered ...../json.htm?type=devices and catched the devices (see atcached file)
else if(data.result[r]['HardwareType']=='PVOutput (Input)'){
$('.block'+data.result[r]['idx']).remove();
var switchHTML = '<div class="col-md-4 mb no-pr" data-light="'+data.result[r]['idx']+'">';
switchHTML+='<em class="fa fa-sun-o"></em>';
switchHTML+='<span class="state">'+data.result[r]['CounterToday']+'</span>';
- HansieNL
Thanks a lot @hpapagaj
I did change some of my switches... Notebook PC, Desktop PC, Mede8er player, Venz M9 LibreELEC player, Sleep and Home.
Only my Toon thermostate setpoint (Thermostaatinstelling) is still recognized as on/off switch???
Maybe it's possible to have custom switches, icons and descriptions via the CONFIG.js as variables?
What I mean is like...
Switch Name,Icon On,Icon Of,Message On,Message Off
Sleep,sleep_on.png,sleep_off.png,Awake,Zzz
Home,home_on.png,home_off.png,At Home,Away
And in main.js it should be picked up as custom switch.
I can't realize this myself, maybe someone can?
Blah blah blah
- gjaa
Very nice, thanks But how can I place them under the weather forecastrobgeerts wrote:I added it to Gitlab, you can download the latest version (or only main.js) or add the following code to main.js:gjaa wrote:Thanks, it's working
Another question
else if(data.result[r]['HardwareType']=='PVOutput (Input)'){ $('.block'+data.result[r]['idx']).remove(); var switchHTML = '<div class="col-md-4 mb no-pr" data-light="'+data.result[r]['idx']+'">'; switchHTML+='<div class="transbg"> '; switchHTML+='<div class="col-md-4 no-padding">'; switchHTML+='<em class="fa fa-sun-o"></em>'; switchHTML+='</div>'; switchHTML+='<div class="col-md-8 no-padding">'; switchHTML+='<strong class="title">'+data.result[r]['Name']+'</strong><br />'; switchHTML+='<span class="state">'+data.result[r]['CounterToday']+'</span>'; switchHTML+='</div>'; switchHTML+='</div>'; switchHTML+='</div>'; $('#switches').append(switchHTML); }
robgeerts
Try changing #switches to .buttons (or #buttons), cannot check right now unfortunately...
- gjaa
When I change to #buttons or .buttons pv-output dissapears, but when I change it to #sliders it appears under the sliders, that's better than between the lightsrobgeerts wrote:Try changing #switches to .buttons (or #buttons), cannot check right now unfortunately...
robgeerts
Ok, if you want there's a title option you can set wich appears beneath those sliders... Take a look at config.js
I don't think that it is possible at this state via config.js (but it would be good), I think everything is hardcoded.HansieNL wrote:Thanks a lot @hpapagaj
If you post us domoticz/json.htm?type=devices I think we can help with the thermostat setpoint.
- HansieNL
This is for the Toon Thermostat:
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "19.0",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 7,
"HardwareName" : "Toon Thermostaat",
"HardwareType" : "Toon Thermostat",
"HardwareTypeVal" : 34,
"HaveTimeout" : false,
"ID" : "0000001",
"LastUpdate" : "2017-03-27 17:36:55",
"Name" : "Thermostaatinstelling",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"SetPoint" : "19.0",
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "SetPoint",
"Timers" : "false",
"Type" : "Thermostat",
"TypeImg" : "override_mini",
"Unit" : 0,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "35"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "19.0",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 7,
"ID" : "0000001",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Timers" : "false",
"Unit" : 0,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "35"
Blah blah blah
- EdwinK
- Domoticz version: BETA
O yeah, wanted to do that.HansieNL wrote:This is for the Toon Thermostat:
- Dynamic
- Target OS: -
How can I activate a scene? My 'favorite' scenes are visible, but when I click them, nothing happens. Or is it designed for groups only?
Edit: I found something. When you activate a scene/group, it does:
/json.htm?type=command¶m=switchlight&idx=1&switchcmd=On&level=0&passcode=
But it should be:
/json.htm?type=command¶m=switchscene&idx=1&switchcmd=On&passcode=
How can I fix this?
Edit 2: got it. In main.js you have to change this line:
else if(data.result[r]['Type']=='Group'){
info:
else if(data.result[r]['Type']=='Scene'){
But it should be:
How can I fix this?
info:
- gjaa
But is it possible to get the solarpanels under the weather forecast?robgeerts wrote:Ok, if you want there's a title option you can set wich appears beneath those sliders... Take a look at config.js
robgeerts
Download the latest version from Gitlab, OR edit the code manually:
In index.html, BEFORE:
Add this:
And in main.js:
Change the elseif-statement you've added earlier into this:
AND ADD BEFORE:
Add this:
<div class="row containstraffic mb">Code: Select all
<div class="row containssolarpanels mb">
<div id="solarpanels"></div>
</div>
if($('.solar').length==0) var classn='no-padding';
else var classn='no-pr';
var switchHTML = '<div class="col-md-4 solar '+classn+' block'+data.result[r]['idx']+'" data-light="'+data.result[r]['idx']+'">';
$('#solarpanels').append(switchHTML);
for(r in data.result){
$('.solar').remove();
- gjaa
Add this:
And in main.js:
AND ADD BEFORE:
Add this:
[/quote]
</div>
