How to activate Armed Home or Away by lua and trigged by time?
iffen5
Post by iffen5 »
I want to activate "arm Home" at weekdays between 07:00 - 20:00 adn deactivate the rest of the time?
Have anyone did this before and can you share your script?
/Ingemar
jimtrout87
Re: How to activate Armed Home or Away by lua and trigged by time?
Post by jimtrout87 »
i think this should to it... Although if you manually tried to arm away\disarm in the day it would auto set back to arm home. You could use a variable if this became a issue mind.
time = os.date("*t")
if ( time.hour >=7 and time.hour <20 and otherdevices['Security Panel'] ~= 'Arm Away') then
	commandArray['Security Panel'] = 'Arm Home'
	elseif (time.hour >=20 and time.hour <7 otherdevices['Security Panel'] == 'Arm Away') then
	commandArray['Security Panel'] = 'Disarm'
Bikey
Domoticz version: 2020.x
Post by Bikey »
Even more flexible is to activate the arm home/away based on a virtual switch and then use the timer function on the switch to switch it on or of.
iffen5
Post by iffen5 »
Many thanks!
/Ingemar
Users browsing this forum: Ahrefs [Bot] and 1 guest
