robgeerts
- Domoticz version: 3.7067
Re: New Dashboard Design
You can zip the files and send them via PM?
stlaha2007
- Target OS: -
Re: RE: Re: New Dashboard Design
I will zip them and send through PM. Don't expect them before friday.robgeerts wrote:You can zip the files and send them via PM?
Need to clean up and add more buildin documentation.
Spare time is running out at the moment.
robgeerts
No problem, i'm just glad you (and others in this topic) like the dashboard!
- gjaa
I knew is was Toon, so I changed Toon to P1 Smart Meter USBIf you look at the code, it only applies to Toon Thermostat values.
I have commented that line out and it shows my temperature now:
// if(data.result[r]['HardwareType']=='Toon Thermostat'){ if(data.result[r]['Type']=='P1 Smart Meter' && data.result[r]['SubType']=='Energy'){ $('.energy').html(data.result[r]['Usage']); $('.energytoday').html(data.result[r]['CounterToday']); $('.energytoday').parents('.hideinit').show(); $('.energy').parents('.hideinit').show(); } if(data.result[r]['Type']=='P1 Smart Meter' && data.result[r]['SubType']=='Gas'){ $('.gas').html(number_format(data.result[r]['CounterToday'],2,',','.')+' m3'); $('.gas').parents('.hideinit').show(); } if(data.result[r]['Type']=='Temp' && data.result[r]['idx']=='19'){ $('.tempinside').html(data.result[r]['Temp']+'°C'); $('.tempinside').parents('.hideinit').show(); } // }
But with your solution its working, thanks
This dashboard is so far the best.
I combined temp+humidity+barometer:
stlaha2007
- Target OS: -
Nice combo... Can you share the code how you solved this?hpapagaj wrote:This dashboard is so far the best.
As i can't see if the icons are smaller or equally sized as the others...
And i also have a few sensors which i would like to combine in one box...
Yes, it needs some tweaking to equally size icons. Maybe later I check this.
For BME280 dummy sensor:
in main.js find line
if(parseFloat(data.result[r]['Favorite'])==1){
few lines down find this line
$('.blocks').append(html);
after this you must add the following else if statement:
else if(data.result[r]['Type']=='Temp + Humidity + Baro' && data.result[r]['SubType']=='THB1 - BTHR918, BTHGN129'){
$('.block'+data.result[r]['idx']).remove();
var switchHTML = '<div class="col-md-4 mb no-pr" data-light="'+data.result[r]['idx']+'">';
switchHTML+='<div class="transbg"> ';
switchHTML+='<div class="col-md-4 padding-2">';
switchHTML+='<em class="fa fa-thermometer-half fa-thermometer-half-switch"></em>';
switchHTML+='</div>';
switchHTML+='<div class="col-md-8 padding-2">';
switchHTML+='<strong class="title">'+data.result[r]['Name']+'</strong><br />';
switchHTML+='<span class="state">'+data.result[r]['Temp']+'°C</span>';
switchHTML+='<em class="wi wi-humidity"></em>';
switchHTML+='<br />';
switchHTML+='<span class="state">'+data.result[r]['Humidity']+'%</span>';
switchHTML+='<em class="wi wi-barometer"></em>';
switchHTML+='<span class="state">'+data.result[r]['Barometer']+'%</span>';
$('#switches').append(switchHTML);
Ierlandfan
Just a small observation on that amazing code, Barometer output should read hPa
robgeerts
Added this to my code at gitlab!hpapagaj wrote: after this you must add the following else if statement:
Changed this to hpapagaj's codeIerlandfan wrote:Just a small observation on that amazing code, Barometer output should read hPa
I forgot that I changed margin-left for the first icon (fa-thermometer-half-switch)
Line 46 creative.css:
after that add:
There is a place for more cosmetic work:
-vertical-align middle for sensor values
-equally sized icons (I have a feel that the last icon is smaller than others)
.fa.fa-thermometer-half {margin-left:8px;}
.fa.fa-thermometer-half.fa-thermometer-half-switch {margin-left:4px;}
robgeerts
Added!hpapagaj wrote:I forgot that I changed margin-left for the first icon (fa-thermometer-half-switch)
I know, not all icons are aligned ok when using the same margins so some icons need other values.hpapagaj wrote: There is a place for more cosmetic work
May I ask which icon set do you use? I need to add some switches.
robgeerts
Well, the bulbs are just png's foinded on gooe. But i also include font awesome. Be my guest to find an iconset that fits the design.
- gjaa
Hi Rob,
Is there a possibility to see the weather forecast of today? My son asked me, the weater forecast for today and I only know the temerature at the moment
Gerard
Gerard
robgeerts
Yes, replace js/weather.js with the new one (see attachment)
- weather.js
- (2.01 KiB) Downloaded 162 times
- HansieNL
I did add the weekday to the Date and Time block at the right upper corner.
In main.js add $('#weekday').html(moment().locale('nl').format('dddd'));
In index.html add "<h4 id="weekday"></h4>"
Blah blah blah
robgeerts
HansieNL wrote:I did add the weekday to the Date and Time block at the right upper corner.
Thanks, I've added this to the latest version in Gitlab.
- gjaa
I changed Gasverbruik in Gasverbruik vandaag (index.html)
robgeerts
Changed it in Gitlab too!gjaa wrote:I changed Gasverbruik in Gasverbruik vandaag (index.html)
Earlier, I mentioned I changed this, and I did, but from now on, it still starts with the weather of tommorrow after 15:00hgjaa wrote:Hi Rob,
Gerard
- gjaa
Thanks, it's working
Another question
How can I add my solarpanels?
I entered ...../json.htm?type=devices and catched the devices (see atcached file)
Another question
- solarpanels.txt
- (2.15 KiB) Downloaded 106 times
