Locked
robgeerts
Domoticz version: 3.7067
Re: New Dashboard Design
Post by robgeerts »
You can zip the files and send them via PM?
stlaha2007
Re: RE: Re: New Dashboard Design
Post by stlaha2007 »
robgeerts wrote:You can zip the files and send them via PM?
I will zip them and send through PM. Don't expect them before friday.
Need to clean up and add more buildin documentation.
Spare time is running out at the moment.
robgeerts
Post by robgeerts »
No problem, i'm just glad you (and others in this topic) like the dashboard!
gjaa
Post by gjaa »
If you look at the code, it only applies to Toon Thermostat values.
I have commented that line out and it shows my temperature now:
//         if(data.result[r]['HardwareType']=='Toon Thermostat'){
                     if(data.result[r]['Type']=='P1 Smart Meter' && data.result[r]['SubType']=='Energy'){
                        $('.energy').html(data.result[r]['Usage']);
                        $('.energytoday').html(data.result[r]['CounterToday']);
                        $('.energytoday').parents('.hideinit').show();
                        $('.energy').parents('.hideinit').show();
                     if(data.result[r]['Type']=='P1 Smart Meter' && data.result[r]['SubType']=='Gas'){
                        $('.gas').html(number_format(data.result[r]['CounterToday'],2,',','.')+' m3');
                        $('.gas').parents('.hideinit').show();
                     if(data.result[r]['Type']=='Temp' && data.result[r]['idx']=='19'){
                        $('.tempinside').html(data.result[r]['Temp']+'°C');
                        $('.tempinside').parents('.hideinit').show();
I knew is was Toon, so I changed Toon to P1 Smart Meter USB
But with your solution its working, thanks
madrian
Post by madrian »
This dashboard is so far the best.
I combined temp+humidity+barometer:
stlaha2007
hpapagaj wrote:This dashboard is so far the best.
Nice combo... Can you share the code how you solved this?
As i can't see if the icons are smaller or equally sized as the others...
And i also have a few sensors which i would like to combine in one box...
madrian
Post by madrian »
Yes, it needs some tweaking to equally size icons. Maybe later I check this.
For BME280 dummy sensor:
in main.js find line
if(parseFloat(data.result[r]['Favorite'])==1){
few lines down find this line
$('.blocks').append(html);
after this you must add the following else if statement:
else if(data.result[r]['Type']=='Temp + Humidity + Baro' && data.result[r]['SubType']=='THB1 - BTHR918, BTHGN129'){
								$('.block'+data.result[r]['idx']).remove();
								var switchHTML = '<div class="col-md-4 mb no-pr" data-light="'+data.result[r]['idx']+'">';
										switchHTML+='<div class="transbg"> ';
											switchHTML+='<div class="col-md-4 padding-2">';
												switchHTML+='<em class="fa fa-thermometer-half fa-thermometer-half-switch"></em>';
											switchHTML+='</div>';
											switchHTML+='<div class="col-md-8 padding-2">';
												switchHTML+='<strong class="title">'+data.result[r]['Name']+'</strong><br />';
												switchHTML+='<span class="state">'+data.result[r]['Temp']+'°C</span>';
												switchHTML+='<em class="wi wi-humidity"></em>';
												switchHTML+='<br />';
												switchHTML+='<span class="state">'+data.result[r]['Humidity']+'%</span>';
												switchHTML+='<em class="wi wi-barometer"></em>';
												switchHTML+='<span class="state">'+data.result[r]['Barometer']+'%</span>';
								$('#switches').append(switchHTML);
Ierlandfan
Post by Ierlandfan »
Just a small observation on that amazing code, Barometer output should read hPa
robgeerts
Post by robgeerts »
hpapagaj wrote: after this you must add the following else if statement:
Added this to my code at gitlab!
Ierlandfan wrote:Just a small observation on that amazing code, Barometer output should read hPa
Changed this to hpapagaj's code ;)
madrian
Post by madrian »
I forgot that I changed margin-left for the first icon (fa-thermometer-half-switch)
Line 46 creative.css:
.fa.fa-thermometer-half {margin-left:8px;}
after that add:
.fa.fa-thermometer-half.fa-thermometer-half-switch {margin-left:4px;}
There is a place for more cosmetic work:
-vertical-align middle for sensor values
-equally sized icons (I have a feel that the last icon is smaller than others)
robgeerts
Post by robgeerts »
hpapagaj wrote:I forgot that I changed margin-left for the first icon (fa-thermometer-half-switch)
Added!
hpapagaj wrote: There is a place for more cosmetic work
I know, not all icons are aligned ok when using the same margins so some icons need other values.
madrian
Post by madrian »
May I ask which icon set do you use? I need to add some switches. :)
robgeerts
Post by robgeerts »
Well, the bulbs are just png's foinded on gooe. But i also include font awesome. Be my guest to find an iconset that fits the design.
gjaa
Post by gjaa »
Hi Rob,
Is there a possibility to see the weather forecast of today?
Schermafbeelding 2017-03-24 om 07.22.21.png (197.15 KiB) Viewed 3772 times
My son asked me, the weater forecast for today and I only know the temerature at the moment
Gerard
robgeerts
Post by robgeerts »
Yes, replace js/weather.js with the new one (see attachment)
weather.js
(2.01 KiB) Downloaded 162 times
HansieNL
Post by HansieNL »
I did add the weekday to the Date and Time block at the right upper corner.
In main.js add $('#weekday').html(moment().locale('nl').format('dddd'));
In index.html add "<h4 id="weekday"></h4>"
Blah blah blah
robgeerts
Post by robgeerts »
HansieNL wrote:I did add the weekday to the Date and Time block at the right upper corner.
Thanks, I've added this to the latest version in Gitlab.
gjaa
Post by gjaa »
I changed Gasverbruik in Gasverbruik vandaag (index.html)
Schermafbeelding 2017-03-24 om 21.25.27.png (60.77 KiB) Viewed 3676 times
robgeerts
Post by robgeerts »
gjaa wrote:I changed Gasverbruik in Gasverbruik vandaag (index.html)
Changed it in Gitlab too!
gjaa wrote:Hi Rob,
Gerard
Earlier, I mentioned I changed this, and I did, but from now on, it still starts with the weather of tommorrow after 15:00h
gjaa
Post by gjaa »
Thanks, it's working
Another question
How can I add my solarpanels?
I entered ...../json.htm?type=devices and catched the devices (see atcached file)
solarpanels.txt
(2.15 KiB) Downloaded 106 times
Locked
