How to update a virtual 'Instant+counter' sensor with Lua
- Westcott
I'm getting the data from my SAJ solar inverter directly into Lua, and updating a virtual 'Instant+counter' sensor.
In particular, it's instantaneous 'now' in watts, and total for 'today' in Kw
commandArray[1] = {['UpdateDevice'] = "195|0|"..now..";".. today*1000}
The device appears as - Is there a better way to update the device with Lua?
To get the data I parse the file returned by -
local cmd = 'curl http://172.xx.xxx.xx/real_time_data.xml'
local data = assert(io.popen(cmd))
henr
Re: How to update a virtual 'Instant+counter' sensor with Lua
Can you please give me the lua script that you use or tell me how to make this work?
I also have a SAJ Inverter but i'm an absolute beginner with Domoticz.
- Westcott
Display is now correct. It was as simple as using 'total' rather than 'today'.
Henr, at last, a fellow SAJer! - here's my Lua code.
If you don't use PVoutput, delete that bit.
You also need to create 2 virtual devices, an 'Electric (instant+counter), and a 'temperature'
However, if you can hang on a bit, I'm going to rewrite the XML parser.
lineNo = 0
now = 0
temp = 0
today = 0
total = 0
v1 = 0
v2 = 0
i1 = 0
i2 = 0
ip = 'yourInverterIP'
i = 1
function UpdateDevice(device, data)
idx = otherdevices_idx[device]
if (idx == nil) then
print('** Unknown device '..device)
commandArray[i] = {['UpdateDevice'] = idx..'|0|'..data}
i = i+1
--Get the XML data from the inverter
local url = 'curl http://'..ip..'/real_time_data.xml'
local data = assert(io.popen(url))
for line in data:lines() do
if (lineNo == 0 and string.find(line,'Normal') ~= nil) then
lineNo = 1
elseif (lineNo > 0) then
if (lineNo == 4) then now = string.match(line, "%d+")
elseif (lineNo == 5) then temp = string.match(line, "%d+%.%d+")
elseif (lineNo == 6) then today = string.match(line, "%d+%.%d+")
elseif (lineNo == 8) then total = string.match(line, "%d+%.%d+")
lineNo = lineNo + 1
data:close()
if (lineNo >= 14) then
-- Update the Domoticz GUI
ep = v1*i1
wp = v2*i2
UpdateDevice('Solar', now..";".. total*1000)
UpdateDevice('Itemp', temp)
-- Upload the data to PVoutput every 10 mins
date = os.date("*t")
if (date.min % 10 == 0) then
baseURL="http://pvoutput.org/service/r2/addstatus.jsp?"
API="yourAPIkey"
PVO_URL= baseURL .. "sid=36263&key=" .. API .. "&d=" .. os.date("%Y%m%d") .. "&t=" .. os.date("%H:%M")
PVO_URL = PVO_URL .. "&v1=" .. (today*1000) .. "&v2=" .. now
commandArray['OpenURL'] = PVO_URL
return commandArrayZwave - Sigma Z+ stick, Fibaro, Horstmann, Neo Coolcam, EUROtronic
henr
Thank you very much.
I will try it this weekend
henr
It's working in Watts but Kwh today and total is not counting.
- Westcott
Hi Henr,
Can you make a screenshot of your sensor?
Also can you put your http://172.xx.xxx.xx/real_time_data.xml directly into a web browser and get a screenshot?
Thanks.
Thanks.
henr
Normal 226.4 5.24 50.02 1270 29.7 5.3 4.1 9405.5 9377.28 12680.2 221.3 3.35 179.2 V 3.02 A 357.7
- Westcott
Do you have a Sununo-TL4KA twin-tracker, and 2 sets of panels?
Your posted output is just like mine, but you have generated twice as much in total.
I think that an 'Instant+counter' sensor is not correct on the first day of use, since the 'previous' day's total will be zero.
henr
Hi Westcott
Thanks for your reply
I have a Sununo TL3KA and 14 solar panels 240Wp
nautronix
Here another user of Domoticz with an SAJ Solar inverter.
Thanks for the script, I created an dummy hardware named SolarInverter, with two dummy devices: Solar and Itemp
Copyed script (& changed IP in the script) into lua folder, seems to be running, but the log is saying unknown device:
2016-05-13 15:48:43.684 LUA: ** Unknown device Solar
2016-05-13 15:48:43.684 LUA: ** Unknown device Itemp
Am I doing something wrong? Not sure if I created device the right way.
Thanks in advance.
Thanks in advance.
- Westcott
Hi Nautronix,
Sometimes a restart of Domoticz is needed for the event system to see new devices.
If that doesn't fix it, can you post your code and a screenshot of your devices?
nautronix
Sorry for late response, but indeed, a reboot of Domoticz I didn't try.. Now it's working
annegerben
Westcott wrote:Display is now correct. It was as simple as using 'total' rather than 'today'.
- Spoiler: show
Thanks for your code!
I've been using it quite a while, but recently I've added a ping check so the script doesn't have to run completely when the inverter is offline.
Hi there
I hope you don't mind me hijacking your thread with a quick question, I've been speaking to a friend about Domoticz and HA and he's interested in collating data on both what his panels generate, and how much power he is using but without the use of a Smart Meter.
Looking at your sensors, are you collating not only what your panels are generating, but also how much power you've used and the excess which is put into the grid? If so, what hardware are you using and are you using a Smart Meter?
annegerben
the "energie" widget is not coming from this script, only temp and solar.7h1nk wrote:Hi there
gsmink
Hi Annegerben,
Can you share the code with the ping option
annegerben wrote: Thanks for your code!
edwinz
Hello, I do'nt even get the rea_time_data.xml out of my saj-solar-inverter wifi web server. Can anybody help me to "get" the input for the LUA script from the converter?
darkogorgievski
Apparently the above script is for single phase SAJ inverter, I had to play a bit wit the array so here is the code that can be used for 3 phase SAJ inverter:
-- data from the SAJ inverter
lineNo = 0
now = 0
temp = 0
today = 0
total = 0
ip = '192.168.1.221'
i = 1
i = i+1
lineNo = 1
if (lineNo == 13) then now = string.match(line, "%d+")
elseif (lineNo ==14) then temp = string.match(line, "%d+%.%d+")
elseif (lineNo == 15) then today = string.match(line, "%d+%.%d+")
elseif (lineNo == 17)then total = string.match(line, "%d+%.%d+")
lineNo = lineNo + 1
data:close()
if (lineNo >= 17) then
UpdateDevice('Energy production', now..";".. total*1000)
UpdateDevice('Inverter Temperature', temp)
nood
I have the same problem. I guess we have another type of web server. This is the page I get when I browse to my local IP: http://1xx.xxx.x.136/edwinz wrote: Wednesday 20 September 2017 11:29 Hello, I do'nt even get the rea_time_data.xml out of my saj-solar-inverter wifi web server. Can anybody help me to "get" the input for the LUA script from the converter?
Is this something we can use in a script?
Hieron
I've managed to get Westcott's script working for the type of webserver we have.nood wrote: Monday 20 November 2017 13:00 I have the same problem. I guess we have another type of web server. This is the page I get when I browse to my local IP: http://1xx.xxx.x.136/
You can check the status of your inverter via http://<LOGIN_INVERTER>:<PASSWORD_INVERTER>@<IP_INVERTER>/status/status.php
if you visit this address in your browser it will output something like this:
1,100928,27965,9,29,2305,65535,0,65535,65535,65535,60,5002,2305,39,65535,65535,65535,65535,3598,233,7922,2Code: Select all
lineNo = 0
xlineNo = 0
now = 0
temp = 0
today = 0
total = 0
ip = '192.168.xxx.xxx' --ip of your SAJ wifi module
usern = 'admin' --username of your wifi module
passw = 'admin' --password of yoru wifi module
i = 1
i = i+1
function split(myStr, delimiter)
result = {};
for match in (myStr..delimiter):gmatch("(.-)"..delimiter) do
table.insert(result, match);
return result;
--Get the PHP data from the inverter
local url = 'curl http://'..usern..':'..passw..'@'..ip..'/status/status.php'
local dline = data:read('*all')
-- unmask the next 3 lines to see the collected data in your log for debugging purpose
--print "Data collected: ~~~~~~~~~~~~~~~~"
--print(dline)
--print "~~~~~~~~~~~~~~END"
s = split(dline, ",")
for lineNo, line in pairs(s) do
--print(lineNo..' is '..line) -- unmask for debugging purposes
if (lineNo == 1 and string.find(line,'Normal') ~= nil) then
xlineNo = 1
elseif (lineNo > 1) then
if (lineNo == 2) then total = line*10
elseif (lineNo == 4) then today = line*10
elseif (lineNo == 12) then now = line
elseif (lineNo == 21) then temp = line/10
xlineNo = xlineNo + 1
data:close()
--print ("*****************value for 'total' is "..total) -- unmask for debugging purposes
--print ("*****************value for 'today' is "..today) -- unmask for debugging purposes
--print ("*****************value for 'now' is "..now) -- unmask for debugging purposes
--print ("*****************value for 'temp' is "..temp) -- unmask for debugging purposes
if (xlineNo >= 21) then
UpdateDevice('Solar Output', now..";"..today)
UpdateDevice('Inverter temp', temp)
return commandArrayCode: Select all
- 'Solar Output' Sensor type 'Electric (Instant+Counter)
- 'Inverter temp' Sensor type 'Temperature'- Attachments
- output.jpg (17.86 KiB) Viewed 7795 times
