Problem with dead node and Alarm Script
candrea77
Domoticz version: 2021.1
Post by candrea77 »
this night I was wake up by my alarm script.
Now I'm checking the log and I found this issue :
Mar 21 04:08:26 domoticzstable domoticz: OpenZWave: Received Node Dead notification from HomeID: 4081278406, NodeID: 82 (0x52)
Mar 21 04:08:26 domoticzstable domoticz: EventSystem: Script event triggered: AllarmeRileva
Mar 21 04:08:26 domoticzstable domoticz: 2017-03-21 04:08:26.457  (ZWAVE CONTROLLER) Light/Switch (PIR ALARM CUCINA2)
[/i]
Please note that NodeID: 82 is "PIR ALARM CUCINA2"
The script "AllarmRileva" is activated by Device event , and check for source device in order to know if trigger the "Siren".
Here you are a little part of the script :
tc=next(devicechanged)
switch=tostring(tc)
if uservariables["AlarmActive"] ~= 0 and uservariables["AlarmDetected"] == 0 then
    if otherdevices['Domoticz Security Panel'] == 'Arm Away' then
        if (switch:sub(1,9) == 'PIR ALARM') then
	    	ScriveLog('PIR ALARM motion detected : '..switch)
	    	commandArray['Variable:AlarmDetected'] = '1'
Is possibile that Dead notification can trigger the a "Device" activated script and false my alarm system ?
Sorry for any spelling mistake, English is not my native language.
DomoticZ running on Ubuntu 20.04 LTS , dzVents Version: 3.1.7 , Python Version: 3.8.5
emme
Domoticz version: latest
Re: Problem with dead node and Alarm Script
Post by emme »
Ciao,
first of all... the device is really dead?
- Do you need to NOT consider it anymore? (trie dto simpli rename it with something different than 'PIR ALARM'... like 'PIRdALARM'.... mmh... it does not sounds good in italian :P :P)
- hail the ZWave network or go to the OZWCP and remove dead nodes... this will remove the device also
Dead nodes should not have inpact in the otherdevice (maybe even on the devicechanged, but check its last timestamp) tables.... but if the node dead in ON state.... it could be that it triggers your script
"We always done this way"
candrea77
Post by candrea77 »
device is not dead , but focus on real problem.
Can a "Dead node notification" trigger a device script ?
candrea77
Post by candrea77 »
Sorry Emme ,
I haven't read your last phrase : Dead nodes should not have impact in the otherdevice (maybe even on the devicechanged, but check its last timestamp) tables.... but if the node dead in ON state.... it could be that it
I'll try to insert some Log and hope to don't have same problem anymore (but in case log some action)
In my code hadn't checked for "On" status : now I've added it!!!
            ScriveLog("PIR STATUS : "..otherdevices[switch])
            if otherdevices[switch] == "On" then
                if uservariables["ManualAlarm"] == 0 then
emme
Post by emme »
try also a:
ScriveLog("PIR STATUS : "..otherdevices[switch].." Ultimo Aggiornamento: '..otherdevices_lastupdate[switch])
this would confirm if a dead node trigger the devicehanged table... (maybe the attempt to contact it works like an update)
...btw...
ScriveLog().... quite curios to see what's in this function and see the difference between the normal print()... but this is my own personal curiosity :P :P
ciao
M
candrea77
Post by candrea77 »
ScriveLog is a simple fuction that before issue print command check for local debug variable.
if set to 1 then issue the print command, otherwise don't do nothing.
This night debug was set to 0 :D
Esattamente di dove sei ? Milano città o provincia ? Io sono in provincia di MB ....
emme
Post by emme »
milano SudEst, zona P.le Abbiategrasso
Ok.. allora avevo pensato la stessa cosa :P
