New RFLink firmware (R46) now available!
433Mhz opensource Receiver & Transmitter.
Stuntteam
Post by Stuntteam »
Check here: http://www.nemcon.nl/blog2/
R46: (10/03/2017)
- New Device: Applidom DM82 motion sensor
- New Device: OWL Intuition PV / CM180i
- New Device: WH2A temperature sensors
- New Device: WH1285 TX (WH-5) Temp & Humidity sensor
- New Device: ABB lightswitch type 3299a-11900 (a.k.a. TX Tango) (Receive only!)
- New Device: Velleman VM130T Motor control
- New Device: HRC 101 Motor control
- New Device: AC512-02 AC to RF projection screen trigger
- New Device: 2 new Dooya protocol flavors
- New Device: D-YA / Diya Motor control
- New Device: Konx doorbell model 602 (Receive only!)
- New Device: Doorman doorbell (Receive only!)
- New Device: Acurite 3in1 3N1TXR / 3N1TXC (Thanks: JR)
- New Device: Byron BY532E (Receive only!)
- New Device: Stagnoli remotes
- New Device: Blyss temperature sensors (Ref.630467) (Thanks: JD)
- New Device: Grundig QH-831A 2010525 & Quhwa QH-831A doorbell
- New Device: 868mhz: Woonveilig security sensors
- New Device: 868mhz: Egardia security sensors
- New Device: 868mhz: Alecto WS3900
- New Device: Yale HSA3000/6000 alarm system sensors
- New Device: Sartano 50080 (Harald Nyborg 2794) switch set
- New Device: Astrell 85 portal motorization system
- New Device: Philips AJ7010/12
- New Feature: Learn RF device signals that use a standard EV1527/PT2262 protocol
- Fixed: Some small eeprom handling issues
- Fixed: Improved AI protocol priority handling
- Fixed: various CC2500 issues, make sure pin 6 is wired to ground to use CC2500!
- Fixed: Tightened Warema EWFS detection
- Fixed: RTSlongTX command
- Fixed: ON/OFF vs UP/DOWN command handling
- Fixed: UPM Esic extended packet detection and increased sanity checks on data
- Fixed: Optimized Novatys timing
- Fixed: AlectoV3 Humidity value validation
- Fixed: FineOffset vs Alecto improved differentiation, Note: device ID's have changed for WS1100
- Fixed: Alecto WS-1100 humidity
- Fixed: AlectoV4 Some packets contained an invalid temperature
- Fixed: Globaltronics GT-WT-02 negative temperature/channel number mixup
- Fixed: Globaltronics GT-WT-02 now always reporting a humidity
- Fixed: Tristate send, removed debug message and fixed a timing bug
- Fixed: WS7000 rain reporting
- Fixed: Added additional Brel protocol variant
- Fixed: LightwaveRF turned MOOD commands into regular switch commands so any home automation software can use them
- Fixed: Improved Friedland doorbell signal detection
- Fixed: Acurite 5in1 corrected wind speed, wind direction and rainfall values (Thanks: Xztraz.)
- Fixed: Improved AcuRite 00592TXR detection
- Fixed: Tunex zero humidity value
- Fixed: Improved Home Confort transmit routine and added up/down support (Thanks: Geert)
- Fixed: Battery detection in Prologue protocol
- Fixed: Added channel number to device ID for THGR810
- Fixed: Added channel number support to Warema devices
- Fixed: Improved UPM ESIC protocol detection
- Fixed: Improved SA33 detection
- Fixed: Gaposa protocol timing
- Added: battery status on various Alecto/Maplin devices (Thanks: Ad)
- Added: Hardware & Software configuration via i/o pins:
pin 6 to ground for: CC2500 enable
pin 7 to ground for: disable internal pull-up on RF data in
pin 12 to ground for: reset of EEPROM settings
devros
Re: New RFLink firmware (R46) now available!
Post by devros »
Thanks, about learning code how to overwrite learned code in EPROM or how to remove wrong code
thanks
devros
Post by devros »
Did some test and i can create one custom RF switch, but when i create another previous one is overwriten,....
Stuntteam
Post by Stuntteam »
There are 32 address spots.
There is storage for 16 ON and 16 OFF records.
The samples write to records 1 and 2, to write to other records change the record number that is marked as x in the line below:
10;RFFind;x;151557;B;1E;1;
Thus:
10;RFFind;6;151557;B;1E;1;
writes to record 6.
(http://www.nemcon.nl/blog2/faq#RFFind)
devros
Post by devros »
Thanks that was the problem... it work now, great work
blauwebuis
Domoticz version: current
Post by blauwebuis »
This new ability is WONDERFUL!!
Stuntteam
Post by Stuntteam »
devros
Post by devros »
yea it works really great but i have one more question,
i have 3 switches and one remote with 4 buttons (http://www.ebay.com/itm/4-Channel-RF-Wi ... SwLnBXXpTp
i used learning for 2 switches with my remote (A+B on Off and C+D second on off) and it works great (on and off is now corect), problem is that i cant remove RF codes from remote to learn 3th switch, or how to connect switch to domoticz without remote, i checked FAQ about manual commands but its not working. Do i have to buy another remote?
Stuntteam
Post by Stuntteam »
You should be able to learn something to the sockets yourself without an additional remote.
contact me at [email protected] for some help..
blauwebuis
Would this new option allow me to buy cheap RF sockets from Aliexpress? What are the odds of them working through this new ability?
For example:
https://nl.aliexpress.com/item/EU-3-Pac ... 74280.html
Stuntteam
Post by Stuntteam »
Yes, however.. you would have more fun with a 10 euro Flamingo set from the Action..
blauwebuis
Yes, but the Action doesn't sell those anymore. They're seasonal apparently.
Stuntteam
Post by Stuntteam »
Full racks at my local store.. maybe check a different store in your area?
Alternatively you could go for a Kaku set:
http://www.hornbach.nl/shop/KLIKAANKLIK ... tikel.html
costs 3 euros more but you get a 10 times better set.
marcojpolet
Post by marcojpolet »
Hi stuntteam, what is so much better? The reception range?
Marco
Verstuurd vanaf mijn SM-G920F met Tapatalk
blauwebuis
@stuntteam: thanks! I'll see about getting the KAKU from Hornbach, great tip! Thank you!
On a related note: since the upgrade to version 46 my Domoticz log is full of:
2017-03-18 11:31:56.125 RFLink: 20;1A;PONG;
2017-03-18 11:32:46.145 RFLink: 20;1B;PONG;
2017-03-18 11:33:36.167 RFLink: 20;1C;PONG;
2017-03-18 11:34:26.190 RFLink: 20;1D;PONG;
2017-03-18 11:35:16.211 RFLink: 20;1E;PONG;
2017-03-18 11:36:06.231 RFLink: 20;1F;PONG;
2017-03-18 11:36:56.254 RFLink: 20;20;PONG;
2017-03-18 11:37:46.275 RFLink: 20;21;PONG;
The 50 second interval made me think it was related to Domoticz checking if it was still ok (but not getting a response).
Oddly enough, my data timeout is set to 'none'. I tried changing that to another value, saving it, and then going back again. But that didn't help.
Stuntteam
Post by Stuntteam »
What Domoticz version do you use?
blauwebuis
I'm using the latest beta.
