Rflink with Mac...
433Mhz opensource Receiver & Transmitter.
rege
Rflink with Mac...
Post by rege »
Hello
I'm a newbie with domoticz and rflink
I have a setup with a raspberry and a diy rflink
Works well with Oregon sensor and rf plugs
I would like to make it work with my somfy RTS but i don't have any pc (just an old MacBook)
How can I send direct commands just like rflinkloader ?
From the mac or the raspberry, or domoticz?
woodtrix
Re: Rflink with Mac...
Post by woodtrix »
Serial commands... why don't you install domoticz on the mac and use that to control rflink attached to the the old macbook, you can control the domoticz on you're mac using the pi domoticz with
https://www.domoticz.com/wiki/Setting_up_Device_sharing
Much easier then coding and send serial commands yourself...
Stuntteam
Post by Stuntteam »
Just use a terminal program on the mac..
rege
Rflink with Mac...
Post by rege »
Thank you for answering
I don't get it :
In the tutorial I've seen I must learn my domoticz as a remote for my somfy blind with this command: 10;RTS;0F0F0F;0412;3;PAIR;
How can I send it from terminal or from ssh command from the mac controlling the Pi?
Sorry If I'm unclear.
Stuntteam
Post by Stuntteam »
Use for example minicom
make a serial connection to rflink 57600,n81
there you can send commands to rflink and see data from rflink.
commands to rflink need to be closed with crlf.
you cna add them manually or go to settings with CTRL A, Z
rege
Post by rege »
Thanks a lot
Exactly what I was looking for!
Collin98
Post by Collin98 »
Listed below meticulously to be able to install AppVn Appvn Official assist you. Share this blog post on social media.
