Good to know, had not thought about thosesquandor wrote:Actually bar chart and donut charts does support multiple devicesSnowtiger wrote:It is not possible to get 2 variables in one chart in Domoticz, and so in Domoboard?
Domoboard - Configuration issues
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
Snowtiger
- Domoticz version: 4.10915
Re: Domoboard - Configuration issues
squandor
- Domoticz version: 3.5837
No problem and wez3 has created an bug in github so we will try to fix the line charts so that it is possible to have multiple devices in the chartSnowtiger wrote:Good to know, had not thought about thosesquandor wrote:Actually bar chart and donut charts does support multiple devicesSnowtiger wrote:It is not possible to get 2 variables in one chart in Domoticz, and so in Domoboard?
Snowtiger
good news (y)squandor wrote:No problem and wez3 has created an bug in github so we will try to fix the line charts so that it is possible to have multiple devices in the chartSnowtiger wrote:Good to know, had not thought about thosesquandor wrote: Actually bar chart and donut charts does support multiple devices
Trigun
- Domoticz version: 4.10717
Hi Guys,
Is it common that when adding total usage table, it doesn't add up correctly?
mine shows 3.400 + 0.400 = 7.200
thanks in advance!
thanks in advance!
squandor
i actually don't know, we only parse the value's out of domoticz instead of calculating them so maybe the calculation depends on something in domoticz.Trigun wrote:Hi Guys,
thanks in advance!
Trigun
Hi Guys,
I've fiddling around with Domoboard for a while and it's great but during the time i ran into a few issues.
* Power_usage charts are not adding up correctly(If I use them seperately it's working fine though but adding two different devices is not working correctly)
* i cannot seem to get two of the same graphs showing the powerusage of 2 different devices
reason for this is that I would like to use Domoboard as a dashboard to show the status/usage of different devices in my network.
the is the setup for 1 room I would like to use:
Hopefully I am doing something wrong and someone is able to point me in the right direction.
Thanks in advance
[werkkamer]
[[display_components]]
components = line_charts, bar_charts, power_usage, domoticz_smart_charts
[[top_tiles]]
[[switches]]
Lamp Zolder = 6,switch
[[line_charts]]
Temperatuur zolder = 36,month,temp
[[domoticz_smart_charts]]
Total Usage Zolderlamp = 15,month,usage
Totaal overloop lamp = 4,month,usage
[[power_usage]]
Usage Overlooplamp = 4, month,usage
Usage Zolderlamp = 15, month,usage
Thanks in advance
squandor
Well I know why it's not working but you're not going to be happy about it.Trigun wrote:Hi Guys,
the is the setup for 1 room I would like to use:Hopefully I am doing something wrong and someone is able to point me in the right direction.Code: Select all
[werkkamer] [[display_components]] components = line_charts, bar_charts, power_usage, domoticz_smart_charts [[top_tiles]] [[switches]] Lamp Zolder = 6,switch [[line_charts]] Temperatuur zolder = 36,month,temp [[domoticz_smart_charts]] Total Usage Zolderlamp = 15,month,usage Totaal overloop lamp = 4,month,usage [[power_usage]] Usage Overlooplamp = 4, month,usage Usage Zolderlamp = 15, month,usage
Thanks in advance
We use the charts functions from domoticz but they used globals for the charts which means that you can't use the same graph types on the same page like 2 times month.
We don't know how to fix that at the moment because the code of domoticz is quite large
Trigun
hmm thats a shame, is there a possible workaround perhaps?squandor wrote:Well I know why it's not working but you're not going to be happy about it.Trigun wrote:Hi Guys,
Thanks in advance
squandor
Maybe use 1 smart chart and one normal chartTrigun wrote:hmm thats a shame, is there a possible workaround perhaps?squandor wrote:Well I know why it's not working but you're not going to be happy about it.Trigun wrote:Hi Guys,
Thanks in advance
Or 1 month and another year type. We are looking to combine devices in one chart so you will have the same principle.
Trigun
Ok, that sounds promising.squandor wrote:Maybe use 1 smart chart and one normal chartTrigun wrote:hmm thats a shame, is there a possible workaround perhaps?squandor wrote: Well I know why it's not working but you're not going to be happy about it.
perhaps extracting the data from the domoticz database will work?
Looking forward to the updated version, thanks again for all your help!
- EdwinK
- Domoticz version: BETA
Strange, when i checked (and double checked), my postcode (zip code) was recognized on mijnafvalwijzer.nl, 3161LH, 27 but it also gives an unknown zip-codesquandor wrote:
That's the right notation. But if I trie to use you're zip code on http://mijnafvalwijzer.nl it doesn't give an result so afvalwijzer doesnt support you're zip code
- EdwinK
Earlier today I wrote that I've got things working, but... guess Murphy's law decided to kick in.
Had made a change into domo.conf, but since that didn't work, removed it and put the old config file back.
(Edit) - Just to try something, I made a new test.conf file and when starting that, it all worked again. Retrying my 'old' domo.conf and it failed again with the above error.
root@DiskStation:/var/packages/domoboard# python server.py -c domo.conf
File "server.py", line 149, in <module>
unsanitizedConfig = configobj.ConfigObj(configfile)
File "build/bdist.linux-armv5tel/egg/configobj.py", line 1229, in __init__
File "build/bdist.linux-armv5tel/egg/configobj.py", line 1318, in _load
configobj.NestingError: Cannot compute the section depth at line 76.
jjnj
Is anyone else having issues with the RSS reader?
I see the ''block'' with the title but there is no content.
components = news
[[news]]
rssfeed = http://feeds.nos.nl/nosnieuwsalgemeen
Snowtiger
This NOS feeds is serviced by FeedBurner and therefore not available in this way - I tried http://www.nu.nl/rss/Algemeen and it worksjjnj wrote:Is anyone else having issues with the RSS reader?
components = news [[news]] rssfeed = http://feeds.nos.nl/nosnieuwsalgemeen
squandor
thats a shame indeed.Snowtiger wrote:This NOS feeds is serviced by FeedBurner and therefore not available in this way - I tried http://www.nu.nl/rss/Algemeen and it worksjjnj wrote:Is anyone else having issues with the RSS reader?
squandor
hmm i didn't always liked Murphy's lawEdKo66 wrote:Earlier today I wrote that I've got things working, but... guess Murphy's law decided to kick in.
Had made a change into domo.conf, but since that didn't work, removed it and put the old config file back.Code: Select all
root@DiskStation:/var/packages/domoboard# python server.py -c domo.conf Traceback (most recent call last): File "server.py", line 149, in <module> unsanitizedConfig = configobj.ConfigObj(configfile) File "build/bdist.linux-armv5tel/egg/configobj.py", line 1229, in __init__ File "build/bdist.linux-armv5tel/egg/configobj.py", line 1318, in _load configobj.NestingError: Cannot compute the section depth at line 76. root@DiskStation:/var/packages/domoboard#
- EdwinK
I guess so. But.. I copied it one on one to the new file and it worked. Computers are sometimes stupid thigns
squandor
haha that sure is.EdKo66 wrote:I guess so. But.. I copied it one on one to the new file and it worked. Computers are sometimes stupid thigns
jjnj
Indeed, thank you!Snowtiger wrote:This NOS feeds is serviced by FeedBurner and therefore not available in this way - I tried http://www.nu.nl/rss/Algemeen and it worksjjnj wrote:Is anyone else having issues with the RSS reader?
Hello! I recently discovered this tool, and it's really great! Thank you for your hard work
I got some questions:
- Can i add data from 2 different devices in a line chart? I've seen in the general discussion topic that someone had both temperature and humidity in the same chart, i tried to replicate that (using a Lux sensor instead of humidity)
-Speaking of the Lux sensor, i can't seem to display its data in a line chart (i tried Domoticz smart chart too)
Is it supported? I tried something like
But it's showing an "usage" graph with no data in it.
Thank you!
Room Illumination = 8, day, luxThank you!
