Hello, I have been able to verify that the RFXCom works perfectly with these engines, tested using the RFXmngr, but in Domoticz in the section Manual light / switch, this type is not in the drop down, so I intuit are not yet available.
Is there any possibility of integrating them into Domoticz? Do you know of any alternatives? Or do you have to wait for an upgrade and add it?
Thank you.
RFXCom to control A-OK motors.
b_weijenberg
- Target OS: -
Re: RFXCom to control A-OK motors.
Enable the BlindsT1 protocol for receive, press a button on the A-OK remote. Add the received device.
RFX-433, RFX-433EMC, RFX-868
i000
Hi b_weijenberg, first of all thank you.b_weijenberg wrote:Enable the BlindsT1 protocol for receive, press a button on the A-OK remote. Add the received device.
The process is enable T1 in hardware inside the setup RFXCom, and after? How I add the recive device? Inside learn? Inside Learn I try it and not work, error message time exceed.
i000
In the devices Tab not appear, I'm blocked here
