Add library to lua : raspberry
St7ven
Post by St7ven »
I instaled the librs232 library in the raspberry along domoticz. (home/username/ folder). When I call
require("luars232")
I get
no field package.preload['luars232']
no file '/usr/local/share/lua/5.2/luars232.lua'
no file '/usr/local/share/lua/5.2/luars232/init.lua'
no file '/usr/local/lib/lua/5.2/luars232.lua'
no file '/usr/local/lib/lua/5.2/luars232/init.lua'
no file './luars232.lua'
no file '/usr/local/lib/lua/5.2/luars232.so'
no file '/usr/local/lib/lua/5.2/loadall.so'
no file './luars232.so'
How can I include the "home/username/librs232/dist/lib" to the domoticz path variable ?
I set the $PATH environoment variable on rasberry debian jessie. But the error is still prompted in the domoticz log.
joebar
Re: Add library to lua : raspberry
Post by joebar »
Maybe with..
(In your lua script)
package.path = '/home/username/folder/?.lua'
require('luars232')
St7ven
Post by St7ven »
Its work well to link to the lib folder. Thank you.
Unfortunatly, I get the following error
/home/pi/librs232/dist/lib/luars232.so:1: unexpected symbol near char(127)
The luars232.so is known to work and it has been confirmed with a lua (commande line) windows (available when I installed the lua library in windows.
jvdz
Domoticz version: 4.107
Post by jvdz »
Just add the library to \usr\local\lib\lua\5.2 which is the standard place for this.
Another option is you specify the fully qualified name in the require statement:
require("/home/username/..../luars232") Replace the .... with the exact directory.
Jos
simonrg
Domoticz version: 3.8807
Post by simonrg »
St7ven wrote:Its work well to link to the lib folder. Thank you.
Are you sure you have the Lua 5.2 version of the library for Raspian (Debian) on a Raspberry Pi (Arm)?
The error would be consistent with the wrong binary in the .so file.
Possibly stating the obvious the Windows version working doesn't really help as you will need a different version compiled for Raspberry Pi.
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
