I would buy relays compatible with RFXCom 433mhz, recessed into the wall (like fibaro), in order to set on/off my light via domoticz or via physical button.
Do you have any suggestions?
Relay Switch 433mhz like Fibaro
tontze
- Domoticz version: Beta Ch
Re: Relay Switch 433mhz like Fibaro
Problem with these are that when switching physically, they dont update state in domoticz .. Attleast i havent found a single one that will send status when changed...
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
bigpea
oh very nice, thanks i will see with more attention! thanks.
tontze
Thats interesting =)sisaenkov wrote:Even this one?
https://www.openhardware.io/view/101/Wa ... table-Node
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
mjdb
- Domoticz version: all beta
A do-it-yourself Relay Switch with return-channel...
viewtopic.php?f=56&t=17656
If your wall is big enough, you will get it in.
2 x Domoticz on Raspberry Pi; 2 x RFXtrx433; Aeotec Z-Stick
KlikAanKlikUit ICS-2000 as Relay
Aeotec MultiSensors 6; Danfoss Z Thermostats 014G0013; Kaku Switches, Z-wave Switches
