dzVents 1.1.1
dannybloe
Re: dzVents 1.1.1
Thanks.. it's noted in the tracker
Re: dzVents 1.1.1
Now that development is close to an end.EddyG wrote:Just a thought.
Might it be an idea to have a variable setting(s) in dzVents_setting.lua for alternative paths for the http fetch file and the storage files?
I then could put them on a tmpfs. It prevents the sd-card for too many writes.
I already optimized my whole system this way.
Might it be an idea to pick this up and integrate it into dzVents?
It really helps on wear of the SD-card.
My whole system is now on tmpfs or SSD-drive to prevent damage to the SD-card.
dannybloe
Re: dzVents 1.1.1
Ah, yeah.. could you add an issue for that in github/tickets?
The http fetch file is not necessary anymore when we're done with integrating it into domoticz.
