(I moved the old start post to a separate pinned topic!
robgeerts
- Domoticz version: 3.7067
Please post some general discussions in this topic
l00pz
Re: Dashboard Design
Wow very nice looking Dashboard. Very interested in this
benj29
Yes! Waow!!!!
Envoyé de mon Moto G (4) en utilisant Tapatalk
fkok
Looks very good. Please share!!!
Great design, looks very professional
Spymate
- Domoticz version: 4.10717
Very nice desing. I want to try this.
Make Github account and make a new project for it.
- EdwinK
- Domoticz version: BETA
Yes, please share.
Hope it would be as easy to adapt as G3rards frontpage
Sevift
- Domoticz version: Latest
Excellent!
- gielie
- Domoticz version: latest β
Wow this looks realy nice.
Would you like to share the code? Id like to try this one.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
pvm
- Domoticz version: 4.10538
Could this be the design frontend for domoboard?
robgeerts
You can find the source over here: https://gitlab.com/robgeerts/dashboard/tree/master
Change CONFIG.JS, for the weather to work, use your own api key from Wunderground.
After saving the config, it loads the switches wich are marked as favorite in Domoticz.
If you have changed the code yourself, it would be great if you can share the changes you made as a snippet in the repository.
I cannot promise it works immediately in your situation, because it was originally created for my own
l00pz
Thanks for sharing this Project but do I need to register at GitLab to see the repository?
robgeerts
Not any more
I have just added 3 buttons for controlling your Ziggo Horizon mediabox (if you have one).
Take a look at CONFIG.JS for more info!
Edit: I also added support for NZBget
l00pz
Thanks! I Downloaded the Dashboard, and it's looking very nice. Made some changes to the icons as I also have some "Switches" in my Favorites. Could you maybe tell where the value of "Temperatuur Woonkamer" is based upon? And how I can change it?
robgeerts
The value of 'Temperature Woonkamer' is coming from a domoticz-switch with type 'Temp'.
In my case, my device (from my energy supplier, called Toon) is sending this value to Domoticz.
I just editted the scripts so it hides the blocks on the right at first, until there's a value available.
Could you post the changes you made (or a screenshot) to see if this is usefull for me? (or anyone else on this forum)
l00pz
Re: New Dashboard Design
And what if you have multiple "Temp" Switches
For no it looks like its using some random Temp Switch that I have, so if this Switch could be configured that would be cool. The Temperature Switches that you're using is also from Toon I presume? I tried adding my HoneyWell EvoTouch to it, but unfortunately it's not possible to control the Temperature with the Dashboard.
As for the Screenshot, this is my current Dashboard.
Skippiemanz
- Domoticz version: 4.10233
Wow!
This really looks great...
But how do you guys set it up with your own switches/temp sensors?
I cant seem to find any place to configure this...
Please help me out
Please help me out
robgeerts
The following code in main.js (search for it as I have a newer version than you right now) fills the Woonkamer-block:
If you know the IDX of the temperature-device, you could change this line to:
(where 102 is the IDX-number)
Oh, I just added traffic info (dutch only)
if(data.result[r]['Type']=='Temp'){Code: Select all
if(data.result[r]['idx']==102){Oh, I just added traffic info (dutch only)
robgeerts
Skippiemanz wrote:Wow!
Please help me out
Initially, it gets the switches from Domoticz, the one you marked as Favorite (the yellow star).
IT only works if you add the right path to Domoticz in CONFIG.JS.
Skippiemanz
Sorry, my mistake... forgot to change the default port number...robgeerts wrote:Skippiemanz wrote:Wow!
Please help me out
Working here now!
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
