Error in dimmer value
fabix68
Post by fabix68 »
- Domoticz version 3.4951
- System Raspberry Pi
- Browser IE/Chrome/Firefox/Safari
the value set on the domoticz dimmer is different from the one that receives the mysensor .
It works perfectly if the value sent by the MYSControll
gizmocuz
Re: Error in dimmer value
Post by gizmocuz »
This is because it is put in domoticz as a Lighting2 type sensor, that has no 100 dimmer levels but 16
aXion
Post by aXion »
I noticed the same weird thing. However, when I reboot a node, it will send a request to the controller for the current dim level. It then gets sent the correct (displayed value in domoticz) level which is different from the level before the reboot.
emc2
Post by emc2 »
gizmocuz wrote:This is because it is put in domoticz as a Lighting2 type sensor, that has no 100 dimmer levels but 16
Is there an option somewhere to change the Lighting type to something with 100 dimmer levels?
napo7
Post by napo7 »
Same issue for me :
I did present my dimmer as following :
	// Present the device :
	present(0, S_DIMMER );
but Domoticz see it as "Lighing 2" so only 16 dimmers levels !?
How can we change this (present something else ??) so domoticz see it as a "100 levels dimmer" ?
