Dahua Ip camera snapshot url
imparator
hi, i searched for the dahua camera snapshot url , on this forum, and internet, but get not a working solution, for this camera
in the wiki i found :
http://<IP address>:9989/onvif/media_service/snapshot?channel=0&subtype=0
also not working,
camera model is : IPC-HDBW-2200
has somebody a working url for this camera ?
thx
also not working,
thx
- nayr
- Domoticz version: github
Re: Dahua Ip camera snapshot url
Attached is a screenshot of the config for my Dahua cameras, Ive got four different models and they all use the same config. I dont have anything after snapshot.
Please notice, the preview always shows a broken image when I press test connection.. but otherwise the cameras work perfectly fine, so if your using the test button only to check if its working then you will believe its not functioning, when it likely is.
- Screen Shot 2016-01-17 at 1.18.30 PM.png (69.37 KiB) Viewed 90784 times
- sincze
- Domoticz version: 2024.4
Hi.
On my 4300 series camera I can confirm both work:
http://192.168.*.*:9989/onvif/media_service/snapshot?channel=0&subtype=0
http://192.168.*.*:9989/axis-cgi/mjpg/video.cgi
In domoticz however I use:
http://192.168.*.*:9989/cgi-bin/snapshot.cgi?loginuse=#USERNAME&loginpas=#PASSWORD
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- sincze
Pff.. unable to figure out the Dahua C35 snapshot settings.
It seems port 9989.... no longer available....
Nmap shows: 9989/tcp closed unknown
as to earlier DAHUA ... 9989/tcp open unknown
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
wooojo
Settings for the camera Dahua HDW1220sp of August 2016
ImageURL: cgi-bin/snapshot.cgi?Channel=0
Port: 80
Test Connection DOES NOT WORK !!!!!!
Port: 80
- sincze
Tnx also works for 4431c-awooojo wrote:Settings for the camera Dahua HDW1220sp of August 2016
Port: 80
Still looking for working DAHUA C-35 settings
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
markjgabb
- Domoticz version: 3.8153
download ispy and allow it to find it for you, i find for almost every camera it can get the diffrent streams fairly easily
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
RFlink 334 mhz
mysensors
broadlink
- sincze
I was looking at the ISPY website only to find it.markjgabb wrote:download ispy and allow it to find it for you, i find for almost every camera it can get the diffrent streams fairly easily
That is an excellent idea I totally forgot the possibility. Long time ago I found my first foscam links that way.
Now moved from FOSCAM to DAHUA
Thank you very much I will let you know the results.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- sincze
....sincze wrote:I was looking at the ISPY website only to find it.markjgabb wrote:download ispy and allow it to find it for you, i find for almost every camera it can get the diffrent streams fairly easily
Thank you very much I will let you know the results.![]()
ISpy came and found...
cgi-bin/snapshot.cgi?1Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- Teknor
- Domoticz version: 3.48
Which port did you use?
Raspberry Pi 3 | EasyESP NodeMCU v3 | RFXTRX433e | Mysensors NRF24L01 | MotionEYE | PikrellCam
- sincze
Re: RE: Re: Dahua Ip camera snapshot url
Teknor wrote:Which port did you use?
Port 80.
Sent from my SM-G925F using Tapatalk
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
bmwproboi05
Thanks! I used the cgi-bin/snapshot.cgi?1 in the image link and it worked! May need to see if I can adjust the resolution as it takes awhile to load
rldn
Hi guys,
maybe a reply on an old topic but im still looking for an answer for the following.
I have a Dahua IPC-HDBW8630E-Z and i want a streaming of this cam on my own created domoticz frontpage.
The only thing i can embed is a simple snapshot from http://IP-ADDRESS:8080/cgi-bin/snapshot.cgi.
I cant manage to make this a stream, only with refreshing the whole page.
Is there another way or url for the live stream for this cam?
torrie0712
I have the same problem. I also can't see a stream from my camera. I have an Dahua IPC-HDBW4431R-ZS.
In Blue Iris i can find my camera and i get the following settinga
Opening 192.168.178.10 port 80...
HTTP Get / request...
OK
ONVIF GetSystemDateAndTime
2018-03-21T13:28:06.000Z
Requesting device information...
Bad response
GetCapabilities...
Querying services
Has Imaging services: /onvif/imaging_service
Has media services: /onvif/media_service
Has RTP_RTSP_TCP, requesting profiles
Has Event services: /onvif/event_service
RelayOutputs: 0
InputConnectors: 0
Has Device IO services: /onvif/deviceIO_service
AudioOutputs: 0
Has PTZ service: /onvif/ptz_service
Checking for common cameras...
Foscam FI86xx/98xx compatible?
Foscam FI89xx compatible?
Foscam FI9821 V2 compatible?
Foscam FI9821 media port compatible?
RTSP port open?
RTSP port detected!
Doneg in Blue Iris
Still i can't see a stream in Domoticz. I tried all trhe things suggested here.
Has anyone an idea??
OK
Bad response
GetCapabilities...
Querying services
RelayOutputs: 0
InputConnectors: 0
AudioOutputs: 0
RTSP port open?
RTSP port detected!
Doneg in Blue Iris
jordantheripper
- Domoticz version: 3.9208
Hy, I have your model of dahua but I can't connect to domoticz. Can you please tell me your complete cgi command? thankssincze wrote: Thursday 02 February 2017 23:43Tnx also works for 4431c-awooojo wrote:Settings for the camera Dahua HDW1220sp of August 2016
Port: 80
Test Connection DOES NOT WORK !!!!!!![]()
update
mi mistake
my dahua camera is Dahua IPC-HFW4431R-Z but still I have find nothing to connect to domoticz.
Some one can help me? thanks
- mcestoni
Hello
I have 4 models of dahua cameras
IPC-KW12W
IPC-HFW2100R-VF
IPC-HFW1000S-W
IPC-HDBW1120E-W
and they all work Ok in domoticz
In the field ImageURL : cgi-bin/snapshot.cgi?
IPC-KW12W
IPC-HFW2100R-VF
IPC-HFW1000S-W
IPC-HDBW1120E-W
howi42
I also use the Dahua IPC-HDBW4431R-ZS.
To get a snapshot, I can use
http://10.0.0.30/cgi-bin/snapshot.cgi?1
but then I have to type user and password.
I could not found a version where I add user and password to the URL.
Any ideas ?
Any ideas ?
Rainman
- Domoticz version: 4.9700
@howi42
Can you try;
http://user:[email protected]/cgi-bin/snapshot.cgi?1
I believe I have the similar camera and use;
protocol:HTTP
port: 80
imageURL : cgi-bin/snapshot.cgi?1
Test connection does not work, but the image is shown in the overview page.
Otherwise check if you can downgrade the authentication in the camera config itself from digest to basic. (Assuming you have not connected this to the internet).
Can you try;
protocol:HTTP
port: 80
howi42
Thanks, but it did not work.
And, I do not see a way to change form digest to basic.
A workaround could be to trigger an alarm manually; that would create a snapshot I could use.
But I am not sure if this can be done.
