Solved: Problem with LUA script reading from Fronius inverter
Reinder
Post by Reinder »
I´m trying to make a LUA script that reads the data from my Fronius inverter into Domoticz. For some reason it doesn´t work when I try to read directly from the url. When I download the file that´s created from calling the url and I save that to my pi, then the script does work.
The error I get when reading from the url is
Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_get_solar.lua: /home/pi/domoticz/scripts/lua/script_device_get_solar.lua:27: attempt to index field 'Body' (a nil value)
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
local config=assert(io.popen('curl http://192.168.1.11/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceID=1&DataCollection=CommonInverterData'))
-- local config=assert(io.open('/home/pi/domoticz/scripts/lua/test.js')) --with this line it works
local productie = config:read('*all')
config:close()
local jsonProductie = json:decode(productie)
dagenergie = jsonProductie.Body.Data.FAC.Unit
Any suggestions what´s going on?
Reinder
Re: Problem with LUA script reading from Fronius inverter
Post by Reinder »
Fixed it! The http-address needs to be enclosed with "http: etc" because of the &.
caveman85
Domoticz version: 3.8153
Re: Solved: Problem with LUA script reading from Fronius inverter
Post by caveman85 »
Can you please share the complete (renewed) code? I have a Fronius Inverter and want to test with getting the data into Domoticz also!
Meulderg
Domoticz version: 3.5877
Post by Meulderg »
The script that was posted here, didn’t give me the result I wanted (it didn’t give me a result at all).
It took me a while to get things working for me, as I’m no expert in scripting.
This script runs between sunrise – 30 min and sunset +30 min
After that it looks at the state of the converter, if it is running than it will retrieve data and update the sensors.
-- Script to read solardata from FroniusAPI
-- Autor : Meulderg
-- Date : 29-Jan-2017
-- Name: script_time_Fronius.lua
-- Warning: Don't forget to setup the Local Networks otherwize the device counters won't get updated if site security is used.
		-- Variables to customize ------------------------------------------------
	local DEBUG = 0            				-- 0 is off, 1 for domoticz log, 2 for fronius JSON data to log
	local IPdomiticz = '192.168.xxx.xxx:8080'	-- IP adress of the domoticz service + port
	local IPFronius = '192.168.xxx.xxx'		-- IP adress of the Fronius converter
	local idx_Fronius_Opbrengst = 19		-- idx of the virtual sensor, you need to change this to your own Device IDx
	local idx_UDC = 16 						-- idx of the virtual sensor, you need to change this to your own Device IDx
	local idx_UAC = 15						-- idx of the virtual sensor, you need to change this to your own Device IDx
	local idx_IDC = 18						-- idx of the virtual sensor, you need to change this to your own Device IDx
	local idx_IAC = 17						-- idx of the virtual sensor, you need to change this to your own Device IDx
	local idx_DAY_ENERGY = 12				-- idx of the virtual sensor, you need to change this to your own Device IDx
	local idx_YEAR_ENERGY = 13				-- idx of the virtual sensor, you need to change this to your own Device IDx
	local idx_TOTAL_ENERGY = 14				-- idx of the virtual sensor, you need to change this to your own Device IDx
	--Create Virtual Hardware via JSON script (Copy this URL manualy)
	--Change IP, Port and name accordingly
	--http://127.0.0.1:8080/json.htm?type=command&param=addhardware&htype=15&port=1&name=Fronius&enabled=true
	--Create Virtual sensors via JSON script (Copy these URL manual)
	--Change IP, Port and idx (idx is of the previously created hardware ID) accordingly
	--http://127.0.0.1:8080/json.htm?type=createvirtualsensor&idx=4&sensorname=Fronius_Opbrengst&sensortype=18
		--Above sensor needs to be manual adjusted to Type: Return.
	--http://127.0.0.1:8080/json.htm?type=createvirtualsensor&idx=4&sensorname=Fronius_Day_Energy&sensortype=248
	--http://127.0.0.1:8080/json.htm?type=createvirtualsensor&idx=4&sensorname=Fronius_Year_Energy&sensortype=248
	--http://127.0.0.1:8080/json.htm?type=createvirtualsensor&idx=4&sensorname=Fronius_Total_Energy&sensortype=248
	--http://127.0.0.1:8080/json.htm?type=createvirtualsensor&idx=4&sensorname=Fronius_UAC&sensortype=4
	--http://127.0.0.1:8080/json.htm?type=createvirtualsensor&idx=4&sensorname=Fronius_UDC&sensortype=4
	--http://127.0.0.1:8080/json.htm?type=createvirtualsensor&idx=4&sensorname=Fronius_IAC&sensortype=19
	--http://127.0.0.1:8080/json.htm?type=createvirtualsensor&idx=4&sensorname=Fronius_IDC&sensortype=19
	-- one-time load of the routines
		JSON = (loadfile "C:\\Domoticz\\scripts\\lua\\json.lua")()		-- For Windows
	--	JSON = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()	-- For Linux
	if(DEBUG == 1) then print ('Fronius script running!!') end
	-- get current time & calculate sunrise and sunset.
	time_now = os.date("*t")
	minutes_now = time_now.min + time_now.hour * 60
    if(DEBUG == 1) then print ('Time in minutes: ' ..minutes_now) end
	if(DEBUG == 1) then print ('Sunrise in minutes: ' ..timeofday['SunriseInMinutes'] - 60) end
	if(DEBUG == 1) then print ('Sunset in minutes: ' ..timeofday['SunsetInMinutes'] + 60) end
	-- Validation for sunrise and sunset.
	if (minutes_now > timeofday['SunriseInMinutes'] - 30) and (minutes_now < timeofday['SunsetInMinutes'] + 30) then
		--Extract data from Fronius converter.
		froniusurl	= 'curl "http://'..IPFronius..'/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceID=1&DataCollection=CommonInverterData"'
		jsondata    = assert(io.popen(froniusurl))
		froniusdevice = jsondata:read('*all')
		jsondata:close()
		froniusdata = JSON:decode(froniusdevice)
		--Process fronius data
		if (froniusdata ~= nil) then
		if(DEBUG == 2) then print (froniusdevice) end
		local StatusCode 		= froniusdata['Body']['Data']['DeviceStatus']['StatusCode']
			if( StatusCode == 7) then --Fronius converter is Running
			local DAY_ENERGY	= froniusdata['Body']['Data']['DAY_ENERGY']['Value']
			local YEAR_ENERGY	= froniusdata['Body']['Data']['YEAR_ENERGY']['Value']
			local TOTAL_ENERGY	= froniusdata['Body']['Data']['TOTAL_ENERGY']['Value']
			local PAC 			= froniusdata['Body']['Data']['PAC']['Value']
			local UDC			= froniusdata['Body']['Data']['UDC']['Value']
			local UAC			= froniusdata['Body']['Data']['UAC']['Value']
			local IDC			= froniusdata['Body']['Data']['IDC']['Value']
			local IAC			= froniusdata['Body']['Data']['IAC']['Value']
			if(DEBUG == 1) then print ('PAC: '..PAC) end
			if(DEBUG == 1) then print ('Day Energy: '..DAY_ENERGY) end
			if(DEBUG == 1) then print ('Year Energy: '..YEAR_ENERGY) end
			if(DEBUG == 1) then print ('Total Energy: '..TOTAL_ENERGY) end
			if(DEBUG == 1) then print ('UDC: '..UDC) end
			if(DEBUG == 1) then print ('UAC: '..UAC) end
			if(DEBUG == 1) then print ('IDC: '..IDC) end
			if(DEBUG == 1) then print ('IAC: '..IAC) end
			--To update the devices.
			commandArray[#commandArray + 1]={['OpenURL']="http://"..IPdomiticz.."/json.htm?type=command&param=udevice&idx="..idx_Fronius_Opbrengst.."&nvalue=0&svalue="..PAC..";"..DAY_ENERGY..""}
			commandArray[#commandArray + 1]={['OpenURL']="http://"..IPdomiticz.."/json.htm?type=command&param=udevice&idx="..idx_UDC.."&nvalue=0&svalue="..UDC..""}
			commandArray[#commandArray + 1]={['OpenURL']="http://"..IPdomiticz.."/json.htm?type=command&param=udevice&idx="..idx_IDC.."&nvalue=0&svalue="..IDC..""}
			commandArray[#commandArray + 1]={['OpenURL']="http://"..IPdomiticz.."/json.htm?type=command&param=udevice&idx="..idx_UAC.."&nvalue=0&svalue="..UAC..""}
			commandArray[#commandArray + 1]={['OpenURL']="http://"..IPdomiticz.."/json.htm?type=command&param=udevice&idx="..idx_IAC.."&nvalue=0&svalue="..IAC..""}
			commandArray[#commandArray + 1]={['OpenURL']="http://"..IPdomiticz.."/json.htm?type=command&param=udevice&idx="..idx_DAY_ENERGY.."&nvalue=0&svalue="..DAY_ENERGY..""}
			commandArray[#commandArray + 1]={['OpenURL']="http://"..IPdomiticz.."/json.htm?type=command&param=udevice&idx="..idx_YEAR_ENERGY.."&nvalue=0&svalue="..YEAR_ENERGY..""}
			commandArray[#commandArray + 1]={['OpenURL']="http://"..IPdomiticz.."/json.htm?type=command&param=udevice&idx="..idx_TOTAL_ENERGY.."&nvalue=0&svalue="..TOTAL_ENERGY..""}
			print ('Fronius converter state other than running')
			local UDC = 0	local UAC = 0	local IDC = 0	local IAC = 0
		print ('Fronius converter data is empty or unreachable')
	print ('Fronius converter Offline')
-- Example of the data returned by the Fronius converter
	"Head" : {
		"RequestArguments" : {
			"DataCollection" : "CommonInverterData",
			"DeviceClass" : "Inverter",
			"DeviceId" : "1",
			"Scope" : "Device"
		"Status" : {
			"Code" : 0,
			"Reason" : "",
			"UserMessage" : ""
		"Timestamp" : "2017-01-29T12:16:22+01:00"
	"Body" : {
		"Data" : {
			"DAY_ENERGY" : {
				"Value" : 1535.1,
				"Unit" : "Wh"
			"FAC" : {
				"Value" : 50,
				"Unit" : "Hz"
			"IAC" : {
				"Value" : 4.68,
				"Unit" : "A"
			"IDC" : {
				"Value" : 3.49,
				"Unit" : "A"
			"PAC" : {
				"Value" : 1062,
				"Unit" : "W"
			"TOTAL_ENERGY" : {
				"Value" : 839677.06,
				"Unit" : "Wh"
			"UAC" : {
				"Value" : 231.1,
				"Unit" : "V"
			"UDC" : {
				"Value" : 342.7,
				"Unit" : "V"
			"YEAR_ENERGY" : {
				"Value" : 119222.5,
				"Unit" : "Wh"
			"DeviceStatus" : {
				"StatusCode" : 7,
				"MgmtTimerRemainingTime" : -1,
				"ErrorCode" : 0,
				"LEDColor" : 2,
				"LEDState" : 0,
				"StateToReset" : false
This code is used on a windows based domoticz.
Sensors Fronius
Sensors Fronius
randriese
Post by randriese »
After configuring this script on my machine i'm getting log entries that the script takes more than 10 seconds to run.
also, Domoticz itself gets unresponsive and laggy...
anyone else having this problem? I'm running Domoticz on a Raspberry Pi 2B
Meulderg
Post by Meulderg »
Today i change from a windows machine to a Raspberry PI 3B.
Only had to change the location of the LUA script and the IDs of the sensors.
works for me :-)
Also i don't have any errors as you can see in my log.
2016-11-23 14:29:01.123 EventSystem: Fetching url...
2016-11-23 14:29:01.123 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_Fronius.lua
2016-11-23 14:29:02.107 (Fronius) General/Voltage (Fronius_UDC)
2016-11-23 14:29:02.119 (Fronius) General/Voltage (Fronius_UAC)
2016-11-23 14:29:02.129 (Fronius) General/Custom Sensor (Fronius_Day_Energy)
2016-11-23 14:29:02.136 (Fronius) General/Custom Sensor (Fronius_Year_Energy)
2016-11-23 14:29:02.140 (Fronius) General/Custom Sensor (Fronius_Total_Energy)
2016-11-23 14:30:01.041 EventSystem: Fetching url...
2016-11-23 14:30:01.041 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_Fronius.lua
2016-11-23 14:30:02.027 (Fronius) General/Voltage (Fronius_UDC)
2016-11-23 14:30:02.046 (Fronius) General/Voltage (Fronius_UAC)
2016-11-23 14:30:02.058 (Fronius) General/Custom Sensor (Fronius_Day_Energy)
2016-11-23 14:30:02.062 (Fronius) General/Custom Sensor (Fronius_Year_Energy)
2016-11-23 14:30:02.066 (Fronius) General/Custom Sensor (Fronius_Total_Energy)
2016-11-23 14:31:00.842 EventSystem: Fetching url...
2016-11-23 14:31:00.843 EventSystem: Fetching url...
2016-11-23 14:31:00.843 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_Fronius.lua
2016-11-23 14:31:01.834 (Fronius) General/Voltage (Fronius_UDC)
2016-11-23 14:31:01.844 (Fronius) General/Voltage (Fronius_UAC)
2016-11-23 14:31:01.856 (Fronius) General/Custom Sensor (Fronius_Day_Energy)
2016-11-23 14:31:01.859 (Fronius) General/Custom Sensor (Fronius_Year_Energy)
2016-11-23 14:31:01.864 (Fronius) General/Custom Sensor (Fronius_Total_Energy)
2016-11-23 14:32:01.207 EventSystem: Fetching url...
2016-11-23 14:32:01.207 EventSystem: Script event triggered: /home/pi/domoticz/scripts/lua/script_time_Fronius.lua
2016-11-23 14:32:02.194 (Fronius) General/Voltage (Fronius_UDC)
2016-11-23 14:32:02.207 (Fronius) General/Voltage (Fronius_UAC)
2016-11-23 14:32:02.219 (Fronius) General/Custom Sensor (Fronius_Day_Energy)
2016-11-23 14:32:02.223 (Fronius) General/Custom Sensor (Fronius_Year_Energy)
2016-11-23 14:32:02.228 (Fronius) General/Custom Sensor (Fronius_Total_Energy)
lumjajo
Domoticz version: 4.10717
Post by lumjajo »
Hi Meulderg, I used your script, to read out the data of my Fronius inverter. Works almost perfect, except, it does really put a load on the raspberry as well as on the network, by constantly fetching the JSON data. Do you still run it this way or did you already modify. I was trying to put a loop or wait into it, but nothing really worked.
I thin its enough to read out data every 5min. And that would be really helpful. Can you or anyone else support me in this?
Jo
Meulderg
Post by Meulderg »
Hi Jo,
Yes, i'm still running the script as i posted it here.
Can't say that mine is running with a high load.
I believe it is possible to change the runtime of the script by adding
time = os.date("*t")
if ((time.min % 15)==0) then
Hope this helps.
Tonnie
Post by Tonnie »
Hi Meulberg
I'm using your script. In my log I can see the results. I like to add the hardware and other sensors.
Can you tell me how must I do that ?
Meulderg
Post by Meulderg »
Hi Tonnie,
Sorry for my late resonse, but in the script there are also url's to create hardware and sensors.
That is how i did it.
--http://127.0.0.1:8080/json.htm?type=com ... abled=true
--http://127.0.0.1:8080/json.htm?type=cre ... sortype=18
--http://127.0.0.1:8080/json.htm?type=cre ... ortype=248
--http://127.0.0.1:8080/json.htm?type=cre ... nsortype=4
--http://127.0.0.1:8080/json.htm?type=cre ... sortype=19
of course you can/must adjust the ip address and the name of the sensor.
Hope this will help you.
kinghuzi
Post by kinghuzi »
Hi Meulderg,
First of all thank you for the above script, works like a charm. I also have a fronius smart meter attached to my inverter. Would it be possible to create a version of your script that pulls data off the smart meter (Its related to consumption).
The JSON URL is http://192.168.1.230/solar_api/v1/GetMe ... ope=System
The data is presented as below, it would be great to have devices for the below particularly important is the "PowerReal_P_Sum". I tried creating one myself but have no clue on LUA coding and kept getting all sorts of errors. Also could you advice how to add a delay to the script to make it run every 5 seconds.
   "Body" : {
      "Data" : {
         "0" : {
            "Current_AC_Phase_1" : 4.5040002139285207,
            "Current_AC_Sum" : 4.5040002139285207,
            "Details" : {
               "Manufacturer" : "Fronius",
               "Model" : "Smart Meter 63A-1",
               "Serial" : "17081671"
            "Enable" : 1,
            "EnergyReactive_VArAC_Phase_1_Consumed" : 480,
            "EnergyReactive_VArAC_Phase_1_Produced" : 808800,
            "EnergyReactive_VArAC_Sum_Consumed" : 480,
            "EnergyReactive_VArAC_Sum_Produced" : 808800,
            "EnergyReal_WAC_Minus_Absolute" : 89241,
            "EnergyReal_WAC_Phase_1_Consumed" : 116174,
            "EnergyReal_WAC_Phase_1_Produced" : 89241,
            "EnergyReal_WAC_Plus_Absolute" : 116174,
            "EnergyReal_WAC_Sum_Consumed" : 116174,
            "EnergyReal_WAC_Sum_Produced" : 89241,
            "Frequency_Phase_Average" : 50.00000074505806,
            "Meter_Location_Current" : 0,
            "PowerApparent_S_Phase_1" : 1058.8899763319641,
            "PowerApparent_S_Sum" : 1058.8899763319641,
            "PowerFactor_Phase_1" : 0.74999998323619366,
            "PowerFactor_Sum" : 0.74999998323619366,
            "PowerReactive_Q_Phase_1" : -519.99998837709427,
            "PowerReactive_Q_Sum" : -519.99998837709427,
            "PowerReal_P_Phase_1" : 802.07998207211494,
            "PowerReal_P_Sum" : 802.07998207211494,
            "TimeStamp" : 1503649834,
            "Visible" : 1,
            "Voltage_AC_Phase_1" : 235.1000111666508
   "Head" : {
         "DeviceClass" : "Meter",
         "Scope" : "System"
      "Status" : {
         "Code" : 0,
         "Reason" : "",
         "UserMessage" : ""
      "Timestamp" : "2017-08-25T18:30:34+10:00"
Meulderg
Post by Meulderg »
Hi Kinghuzi,
As i sad before i'm no scripting guy myself, it took me a long time of experimenting to get things working.
Try to adjust my script to get data from your Smartmeter.
If the URL (which i cannot access). you posted gives you the correct data.
Than try if it gives you any data in the Domoticz logging and work up from there.
Also set the DEBUG to 1 in the script to see what the data is giving you.
And i don't think you can read data every 5 seconds, as the minimum for launching a script is 1 minute.
(but correct me if i'm wrong).
	local DEBUG = 1            				-- 0 is off, 1 for domoticz log, 2 for fronius JSON data to log
	local IPFronius = '192.168.1.230'		-- IP adress of the Fronius converter
		--Extract data from Fronius Smartmeter.
		froniusurl	= 'curl "http://'..IPFronius..'/solar_api/v1/GetMeterRealtimeData.cgi?Scope=System"'
		jsondata:close()
		local StatusCode 		= froniusdata['Body']['Data']['0']['Enable']
			if( StatusCode == 1) then --Fronius Smartmeter is Running
			local PowerReal-P-Sum	= froniusdata['Body']['Data']['0']['PowerReal_P_Sum']
			if(DEBUG == 1) then print ('PowerReal P Sum: '..PowerReal-P-Sum) end
Kind regards,
Geert-Jan
kinghuzi
Post by kinghuzi »
Managed to get consumption data from fronius. Still struggling to add delay in the script so it doesn't run every few ms as it's using near 25% rp3 cpu.
kinghuzi
Post by kinghuzi »
Has anyone had issue of blocklys not working after this lua runs for a day or so. Only a Domo restart works.
fmal
Post by fmal »
Hi Meulderg, I'm using your script for my Fronius Primo Inverter and it works fine. The only minor problem is that the inverter firmware gives a wrong value for DAY_ENERGY, it's a known bug and they will fix it.
But I did not understand this comment in your script:
What do you mean by "manual adjusted"? I do not know how to change the sensor type in Domoticz, and it looks as working this way.
My sensors are these:
Idx Hardware ID Unit Nome Modello Sottotipo Dati
73	Fronius	00082073	1	Fronius_UAC	General	Voltage	223.2 V
72	Fronius	82072	1	Fronius_Year_Energy	Usage	Electric	73035.8 Watt
71	Fronius	82071	1	Fronius_Day_Energy	Usage	Electric	269.9 Watt
70	Fronius	00082070	1	Fronius_Prod	General	kWh	0.2699 kWh
Ty for your great help!
fmal
Post by fmal »
Some minor errors in this scripts:
in line 86:
there is DAY_ENERGY and I think it should be:
commandArray[#commandArray + 1]={['OpenURL']="http://"..IPdomiticz.."/json.htm?type=command&param=udevice&idx="..idx_Fronius_Opbrengst.."&nvalue=0&svalue="..PAC..""}
Then the types of the sensors for DAY_ENERGY, YEAR_ENERGY and TOTAL_ENERGY report Watts as measurement unit. I think that ony PAC is the punctual power from FV and is expressed in W, the cumulated values should be kWh.
Another thing: now I only collect PAC and UAC, but these two values are changing forever, and my logs are growing until system crashes. I have debug = 0 but the data logged are really too big, I have two calls to the script each second. How can I slower the check?
TY
emulan
Post by emulan »
even if i have correct ip and can read my fronius primo inverter, i get :fronius converter data is empty or unreachable
any suggestion?
Davil
Post by Davil »
Meulderg wrote:The script that was posted here, didn’t give me the result I wanted (it didn’t give me a result at all).
-- Autor : Meulderg
		jsondata:close()
	"Head" : {
			"DeviceId" : "1",
			"Scope" : "Device"
		"Status" : {
			"Code" : 0,
			"Reason" : "",
			"UserMessage" : ""
	"Body" : {
		"Data" : {
			"DAY_ENERGY" : {
				"Value" : 1535.1,
				"Unit" : "Wh"
			"FAC" : {
				"Value" : 50,
				"Unit" : "Hz"
			"IAC" : {
				"Value" : 4.68,
				"Unit" : "A"
			"IDC" : {
				"Value" : 3.49,
				"Unit" : "A"
			"PAC" : {
				"Value" : 1062,
				"Unit" : "W"
			"TOTAL_ENERGY" : {
				"Unit" : "Wh"
			"UAC" : {
				"Value" : 231.1,
				"Unit" : "V"
			"UDC" : {
				"Value" : 342.7,
				"Unit" : "V"
			"YEAR_ENERGY" : {
				"Value" : 119222.5,
				"Unit" : "Wh"
			"DeviceStatus" : {
				"StatusCode" : 7,
				"ErrorCode" : 0,
				"LEDColor" : 2,
				"LEDState" : 0,
Hello Meulderg!
I am trying to understand how to do this on my Raspberry pi but unfortunately I am a newbie with Lua-stuff Image️.
I have created that Hardware dummy and all the virtual sensors. But then Im stuck and don't understand what /how to do then?! I also understand how to read from fronius API, but not how to transfer the reading to the virtual sensors.
Im so frustrated that Im such a noob. I wish someone could fixed it remotely for me hehe... I really want this to work!
Best regards /David from Sweden
Skickat från min HTC U11 plus via Tapatalk
tjabas
Post by tjabas »
I also have a fronius inverter want to connect it to domoticz, but i wonder how i install this script on my raspberry, im not good at programming.
thanks
tjabas
Post by tjabas »
i finally got it working ,all of the sensors are uppdating, but now the blockly wont work, this script is updating the sensors every second, and it seems to freeze all my blocky configuration, is there a way to decrease the updating frequency?
