Uservariable not updating via API-command
DutchHans
Post by DutchHans »
Good morning,
(Raspberry Pi3 on the latest Beta)
I am trying to update a uservariable (according to the wiki) with the API command from a LUA script:
os.execute('http://xxx:[email protected]:8080/json.htm?type=command&param=updateuservariable&vname=RainPrediction&vtype=2&vvalue=25')
The Uservariable(String) is not updating. but when I give the same command in the browser, it works.
"status" : "OK",
"title" : "UpdateUserVariable"
Am I missing something?
Please help.
Regards, Hans
Nautilus
Re: Uservariable not updating via API-command
Post by Nautilus »
Try:
os.execute('curl -s "http://xxx:[email protected]:8080/json.htm?type=command&param=updateuservariable&vname=RainPrediction&vtype=2&vvalue=25" &')
You need to tell "what" it is that should open the url, in this case "curl". Plenty of examples here on the forum :)
DutchHans
Post by DutchHans »
Nautilus,
Thank you so much, that did the trick.
Regards, Hans
