Battery level reporting from Android
pvoj
Domoticz version: 3.5964
Post by pvoj »
I read through several topics in the forum and found a simple solution to send battery information from Android to Domoticz. I use Automate on Android to get the data and create the json url. You can download the Flow from the Automate community Flow library. It is named: Battery level reporting tool for Domoticz. The battery level is sent over json like this: ../json.htm?type=command&param=udevice&idx=92&svalue=55.1
In Domoticz I created a dummy percentage sensor. The ID of the sensor is set in the Automate flow as well as the url and the ssid of the wifi.
Peter
DAVIZINHO
Re: Battery level reporting from Android
Post by DAVIZINHO »
hi,
This is very interesting for me.
Can you tell us more details?
kluczus
Post by kluczus »
It is simple. I'm using a tasker. In my configuration I have:
- scene: two conditions - near wifi with specific ssid and time betwen 0:01am and 12:59 pm every 10 minutes,
- task: Net->http get, in server domoticzip:port, in path
json.htm?type=command&param=udevice&idx=IDX&svalue=%BATT
RPi2 + sonoff + 433MHz + Xiaomi Gateway + EQ-3 MAX!
drbytes
Post by drbytes »
Try Wall All, posted about here in the forum. I wrote it, .. it allows you to post battery info to MQTT of pull it via HTTP GET.
There's alot more data it can gather.
I've posted a bunch of codes to test it out, but give me some feedback, I'm always looking to improve or add features
Freemann
Domoticz version: >=Béta
Post by Freemann »
I just posted this;
http://www.domoticz.com/forum/viewtopic ... 20#p156694
Would be great if its implemented into the Android app and Domoticz itself.
I'm using this Automate flow;
Batterij vol (_70%).png (18.57 KiB) Viewed 6325 times
"Catch error?" >No> Loop every 1 minutes > Get BatteryLevel > Put BatteryLevel in Variable > Post the Automate Variable to an Domoticz UserVariable.
"Catch error?" >Yes> Delay 2 min.
This is working great for about an year now. Based on "Android AccuBattery" the battery of my OnePlus 3t only lost 100mAh(~5%) of capacity :)
Where my previous Nexus5 lost >10% after 1 year.
Also on safety its great; No charging Lithium device in the house while sleeping :D
Domotica/graphs "freak" :)
NUC8i3BEH(8gb/250gb),
Lubuntu 19.04,
Aeotec Z-Stick S2(Gen5)
HarmonyElite
HUE(5 bulbs, 2 blooms)
NetAtmo(complete setup)
MiLight iboxV6(2 MiLightBulbs)
IP-Cam
https://www.frijduurzaam.nl
