homebridge-edomoticz Plugin
Re: homebridge-edomoticz Plugin
Running the latest beta and have installed a door lock it shows up as device typeval 19 instead av the old type 11. Can I change this in the config.json or somewhere else? Thanks!
Hi!woody4165 wrote:Hiergofreiberg wrote:Hi!
Would it be possible to add Domoticz built-in Security Panel to Homebridge. Currently I have my Paradox EVO192 linked to Security Panel and in Domoticz everyting is working fine. Is there any point in opening issue about this topic?
Regards,
Ergo
how did you linked Paradox alarm to the security panel?
With Tertiush Paradox IP150-MQTT script
e.
Can you share some scripts?ergofreiberg wrote:
Hi!
e.
I'm in contact with Tertius in the OpenHab forum to understand how to get the status of the alarm from MQTT topic.
If I am OT on this topic we can open another one or via PM, if possible.
As I don't know much about programming, I'm just using Node-Red and replacing every zones payload with suitable json.woody4165 wrote:
Very interesting, I don't know much about Node-red, but a little bit of programming...
How do you test if the alarm is Armed or Disarmed?
- Domoticz version: 2021.1
i,m trying to install this on the raspberry pi but i get these errors:
this is the config.json:
treid config.json in jsonlint and its a valid one,
can someone help me please?
thanks
EDIT: I noticed that if i do sudo homebridge it works!!!!!
why cant it not read the config.json when i type homebridge???????
pi@raspberrypi:~ $ homebridge
*** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** Please fix your application to use the native API of Avahi!
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
*** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
*** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
[2017-02-20 18:47:41] Warning: skipping plugin found at '/usr/lib/node_modules/homebridge-edomoticz' since we already loaded the same plugin from '/usr/local/lib/node_modules/homebridge-edomoticz'.
[2017-02-20 18:47:47] Loaded plugin: homebridge-edomoticz
[2017-02-20 18:47:47] Registering accessory 'homebridge-edomoticz.eDomoticz'
[2017-02-20 18:47:47] Registering platform 'homebridge-edomoticz.eDomoticz'
[2017-02-20 18:47:47] ---
[2017-02-20 18:47:47] There was a problem reading your config.json file.
[2017-02-20 18:47:47] Please try pasting your config.json file here to validate it: http://jsonlint.com
/usr/local/lib/node_modules/homebridge/lib/server.js:197
throw err;
SyntaxError: Unexpected token
at Object.parse (native)
at Server._loadConfig (/usr/local/lib/node_modules/homebridge/lib/server.js:191:19)
at new Server (/usr/local/lib/node_modules/homebridge/lib/server.js:52:38)
at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:26:16)
at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
at Module._compile (module.js:434:26)
at Object.Module._extensions..js (module.js:452:10)
at Module.load (module.js:355:32)
at Function.Module._load (module.js:310:12)
at Function.Module.runMain (module.js:475:10)
"bridge": {
"name": "Homebridge",
"username": "CC:21:3E:E4:DE:34",
"port": 51825,
"pin": "031-45-153"
"description": "Configuration file for (e)xtended Domoticz platform.",
"platforms": [
"platform": "eDomoticz",
"name": "eDomoticz",
"server": "user:[email protected]",
"port": "8080",
"ssl": 0,
"roomid": 2,
"usescenes": 0,
"mqttenable": 1,
"mqttserver": "127.0.0.1",
"mqttport": "1883",
"mqttauth": 0,
"mqttuser": "",
"mqttpass": ""
"accessories": []
thanks
because sudo set's home folder as /root whereas normal login its /home/username, make sure your json file is located /home/username with 775 permissions... I think....
Edwin1234, your are missing coma behind server "server",
Thanks For your reply
But moving json to home/pi
Doesnt help.
Doesnt help.
- marcotini
Is it possible that this plugin make my sensor fake-on when they are off? Maybe it's the timout?
Because now that I deactivate Homebridge everythigs work fine.
I don't know fronte what can be caused, because it's happen sometimes with no reason (and at night turn on all the lights lol).
- DewGew
- Domoticz version: V4.10618
I have a homebridge working perfectly. Is there a way to have several users thrue homebridge?
Next if I change server user do I only get the devices for that specific user if have several users in domoticz?
"server": "dewgew:[email protected]",
"port": "8080",
//Br
"port": "8080",
//Br
i can only start homebridge with: sudo homebridge with ssh it works ok but when i stop ssh homebridge stops too how to fix this?
i`m new to linux
how to autostart it?
homebridge is in : /usr/local/lib/node_modules/homebridge/bin
and config.json in : /usr/local/lib/node_modules/homebridge
thanks
i`m new to linux
thanks
Check the first page of the thread, the bottom of the first post, you will see a section called Run in background. There you have two options depending on the version of raspbian you are using.edwin1234 wrote:i can only start homebridge with: sudo homebridge with ssh it works ok but when i stop ssh homebridge stops too how to fix this?
i`m new to linux![]()
thanks
Automation Hardware:
Domoticz on Raspberry Pi 3 with HomeBridge.
Zigbee2MQTT + Xiaomi sensors
Fibaro HomeCenter 2 + Fibaro Dimmer2 & Double Switch2 + Aeon Multisensor 6 + Remotec ZXT-120
Eastron SDM230
Eastron SDM230
I did try it snd get these error:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Sat Feb 25 14:28:27 2017
pi@raspberrypi:~ $ sudo systemctl status homebridge.service -l
● homebridge.service - HomeBridge Service
Loaded: loaded (/lib/systemd/system/homebridge.service; enabled)
Active: active (running) since za 2017-02-25 14:28:26 CET; 1min 35s ago
Main PID: 536 (homebridge)
CGroup: /system.slice/homebridge.service
├─536 homebridge
├─867 /bin/sh -c /bin/echo -n "$(npm -g prefix)/lib/node_modules"
└─868 npm
feb 25 14:28:57 raspberrypi node[536]: *** WARNING *** Please fix your application to use the native API of Avahi!
feb 25 14:28:57 raspberrypi node[536]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
feb 25 14:28:57 raspberrypi node[536]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
feb 25 14:28:57 raspberrypi node[536]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
feb 25 14:28:58 raspberrypi homebridge[536]: *** WARNING *** Please fix your application to use the native API of Avahi!
feb 25 14:28:58 raspberrypi homebridge[536]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
feb 25 14:28:58 raspberrypi homebridge[536]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
feb 25 14:28:58 raspberrypi homebridge[536]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister>
Active: failed (Result: exit-code) since za 2017-02-25 14:30:25 CET; 21s ago
Process: 536 ExecStart=/usr/local/lib/node_modules/homebridge/bin/homebridge (code=exited, status=1/FAILURE)
Main PID: 536 (code=exited, status=1/FAILURE)
feb 25 14:30:25 raspberrypi homebridge[536]: at new Server (/usr/local/lib/node_modules/homebridge/lib/server.js:52:38)
feb 25 14:30:25 raspberrypi homebridge[536]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:26:16)
feb 25 14:30:25 raspberrypi homebridge[536]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
feb 25 14:30:25 raspberrypi homebridge[536]: at Module._compile (module.js:434:26)
feb 25 14:30:25 raspberrypi homebridge[536]: at Object.Module._extensions..js (module.js:452:10)
feb 25 14:30:25 raspberrypi homebridge[536]: at Module.load (module.js:355:32)
feb 25 14:30:25 raspberrypi homebridge[536]: at Function.Module._load (module.js:310:12)
feb 25 14:30:25 raspberrypi homebridge[536]: at Function.Module.runMain (module.js:475:10)
feb 25 14:30:25 raspberrypi systemd[1]: homebridge.service: main process exited, code=exited, status=1/FAILURE
feb 25 14:30:25 raspberrypi systemd[1]: Unit homebridge.service entered failed state.
pi@raspberrypi:~ $
- Target OS: -
Just checking in to say hello.. all is still working great here!
How is everyone?
Cheers
How is everyone?
Cheers
but now that the img file no longer exists in the download that guides you have to follow?
thank you
thank you
Hi guys, I am still experiencing problems with dimmer switches and Siri.
Few months ago I had problem with my LED controllers, now I have same problem with virtual dummy dimmer which opens an URL.
script_device_VU.lua:
If I manually change (with my fingers) the levels in the Home app, no problem it works.
If I ask Siri to Set dimmer level example to 50%:
FIrst it is set the correct level 49, then immediately without any reasen it is switches to 0.
Same problem was with my LED controller. Very interesting.
if devicechanged['VU'] then
print('Level : '..tonumber(otherdevices_svalues['VU']))
commandArray['OpenURL']="http://192.168.1.99/web/vol?set=set" .. otherdevices_svalues['VU']
2017-03-23 23:12:12.423 User: Admin initiated a switch command (37/VU/Set Level)
2017-03-23 23:12:12.498 LUA: Level : 26
2017-03-23 23:12:12.498 EventSystem: Fetching url...
2017-03-23 23:12:12.498 EventSystem: Script event triggered: /home/xy/domoticz/scripts/lua/script_device_VU.lua
2017-03-23 23:12:33.466 User: Admin initiated a switch command (37/VU/Set Level)
2017-03-23 23:12:33.539 LUA: Level : 49
2017-03-23 23:12:33.539 EventSystem: Fetching url...
2017-03-23 23:12:33.539 EventSystem: Script event triggered: /home/madrian/domoticz/scripts/lua/script_device_VU.lua
2017-03-23 23:12:33.467 (Dummy) Light/Switch (VU)
2017-03-23 23:12:33.546 User: Admin initiated a switch command (37/VU/On)
2017-03-23 23:12:33.620 LUA: Level : 0
2017-03-23 23:12:33.620 EventSystem: Fetching url...
2017-03-23 23:12:33.620 EventSystem: Script event triggered: /home/madrian/domoticz/scripts/lua/script_device_VU.lua
2017-03-23 23:12:33.547 (Dummy) Light/Switch (VU)
I have the same wired issue happening. I update a switch with
commandArray['UpdateDevice']= persiana_idx..'|50|' ..value
I get value (dest) as fixed number to control the blinds (20, 50 or 80) so when I select a value in behind, I update it to the next value
persiana_idx = otherdevices_idx[tostring(next(devicechanged))]
dest = tonumber(otherdevices_svalues[next(devicechanged)]
if (dest >= 41 and dest < 71) then dest = 50 endif
commandArray['UpdateDevice']= persiana_idx..'|50|' ..dest
Change is ok and applied... but a few minutes, the value change to the real value...
We should have a ghost somewhere!!!!!
Hi homebridge worked like a charm for 1 month since today. Now in debug mode gives me this message How can I fix this?
thank you
EventedHTTPServer Server listening on port 51826 +0ms
/usr/local/lib/node_modules/homebridge/node_modules/mdns/lib/advertisement.js:56
dns_sd.DNSServiceRegister(self.serviceRef, flags, ifaceIdx, name,
Error: dns service error: unknown
at Error (native)
at new Advertisement (/usr/local/lib/node_modules/homebridge/node_modules/mdns/lib/advertisement.js:56:10)
at Object.create [as createAdvertisement] (/usr/local/lib/node_modules/homebridge/node_modules/mdns/lib/advertisement.js:64:10)
at Advertiser.startAdvertising (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Advertiser.js:43:30)
at Bridge.Accessory._onListening (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:539:20)
at emitOne (events.js:96:13)
at HAPServer.emit (events.js:188:7)
at HAPServer._onListening (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/HAPServer.js:190:8)
at EventedHTTPServer.emit (events.js:188:7)
thank you
- Domoticz version: 3.8153
I'm having trouble to get the plugin active on boot. I have updated the systemd domoticz.service to boot homebridge after domoticz, but domoticz does not have enough time to get up and running.
I can manually restart homebridge and all works great, but I would love it if no manual intervention was needed.
Anybody have thoughts on this?
Apr 9 08:40:04 pi domoticz[426]: 2017-04-09 08:40:04.493 Active notification Subsystems: email (1/12)
Apr 9 08:40:04 pi domoticz[426]: 2017-04-09 08:40:04.521 WebServer(HTTP) started on address: :: with port 8080
Apr 9 08:40:04 pi domoticz[426]: 2017-04-09 08:40:04.570 WebServer(SSL) started on address: :: with port 443
Apr 9 08:40:04 pi domoticz[426]: 2017-04-09 08:40:04.606 Proxymanager started.
Apr 9 08:40:04 pi domoticz[426]: 2017-04-09 08:40:04.619 Starting shared server on: :::6144
Apr 9 08:40:04 pi domoticz[426]: 2017-04-09 08:40:04.640 TCPServer: shared server started...
Apr 9 08:40:04 pi domoticz[426]: 2017-04-09 08:40:04.646 RxQueue: queue worker started...
<snip>
pr 9 08:40:44 pi homebridge[560]: [4/9/2017, 8:40:44 AM] [eDomoticz] Initializing eDomoticz platform...
Apr 9 08:40:44 pi homebridge[560]: [4/9/2017, 8:40:44 AM] Loading 0 accessories...
Apr 9 08:40:45 pi homebridge[560]: [4/9/2017, 8:40:45 AM] [eDomoticz] There was a problem connecting to Domoticz.
Apr 9 08:40:46 pi homebridge[560]: - Error: socket hang up
