Switch turns on/off every 15 min.
nedde
Post by nedde »
I want the switch to turn of after 15 minutes after it is turend on but it keeps
turning on/off every 15 min instead. What's am I doing wrong? Picture Attached.
2017-01-11 15_37_08-Domoticz.png (7.59 KiB) Viewed 4276 times
anasazi
Re: Switch turns on/off every 15 min.
Post by anasazi »
Shouldn't you be using "Off AFTER 15" instead of FOR.
jumbotroll
Post by jumbotroll »
Try this :-)
If Kaffe = On
Do
Set Kaffe = On For 15 minutes
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
emme
Domoticz version: latest
Post by emme »
I think you cannot do that with blocky....
the script will loop all the time....
try LUA instead:
     if devicechanged['Kaffe'] and otherdevices['Kaffe'] == 'On' then
          commandArray['Kaffe'] = 'On FOR 900'     -- the FOR instance works in secs
"We always done this way"
Egregius
Domoticz version: v2024.7
Post by Egregius »
Or pass2php:
<?php
if(apcu_fetch('sKaffe')=='On'&&apcu_fetch('tKaffe')<time-900) sw(apcu_fetch('iKaffe'),'Off');
StanHD
Post by StanHD »
There is an "Off After X Seconds" block (900 seconds) ;)
Python:- Broadlink RM2, Sonos
nedde
Re: RE: Re: Switch turns on/off every 15 min.
Post by nedde »
anasazi wrote:Shouldn't you be using "Off AFTER 15" instead of FOR.
Worked a lot better :) thx
Sent from my Nexus 6 using Tapatalk
gielie
Domoticz version: latest β
Post by gielie »
I have a question, i have this code.
     if devicechanged['Koffie'] and otherdevices['Koffie'] == 'On' then
          commandArray['Koffie'] = 'On FOR 600'     -- the FOR instance works in secs
    if devicechanged['Koffie'] and otherdevices['Koffie'] == 'Off' then
          commandArray['SendNotification']='Koffie machine is uitgeschakeld'
But when de koffie is Off Domoticz will spam me with messages, i only want to recieve 1 message after the event took place.
How can i do this?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
Nautilus
Post by Nautilus »
gielie wrote:I have a question, i have this code.
How can i do this?
The syntax is bit incorrect, not sure if this is the reason. Try:
if devicechanged['Koffie'] == 'On' then
elseif devicechanged['Koffie'] == 'Off' then
Last edited by Nautilus on Tuesday 21 February 2017 12:37, edited 1 time in total.
emme
Post by emme »
could it be that the ON FOR 600 keep the device in the devicechanged table for 600 seconds?!
Nautilus
Post by Nautilus »
emme wrote:could it be that the ON FOR 600 keep the device in the devicechanged table for 600 seconds?!
Not sure about this, but agreed that more logical would be:
    commandArray['Koffie'] = 'Off AFTER 600'
gielie
Post by gielie »
U guys are great, it works, thanks a lot.
Is there also a way to create a countdown?
- FIBARO FGS223
- Toon
- Kodi Media Server
Nautilus
Post by Nautilus »
gielie wrote:Is there also a way to create a countdown?
Sure, with a time script (they run once each minute) you can at least have a once per minute count down timer...
