fibaro fgs-222 dont reconnect after power failure
italoc
Post by italoc »
I'm new on domitcz and Z-Wave, and now i'm testing fibaro fgs-222 relay with aeon Zstick with a single lamp before use in my home circuit
every time that i disconnect the lamp with fgs-22 from the power source (power failure) and reconnect after some time (1-2 hours) domoticz see fibaro relay as disconnected and i need to push a phisical button on relay for turn on the lamp and let's that domoticz recognize the fibaro switch as ready.
it's normal? there is a way to solve this problem? it's impossibile for me every time that i have a power failure in my home that i need to phisically push the button on the relay.
YcKe
Re: fibaro fgs-222 dont reconnect after power failure
Post by YcKe »
Hi Italoc,
Have you tried restarting domoticz? (Or enabling/disabling your open zwave hardware)
A restart should trigger a scan for your environment to detect your zwave nodes even if they were assumed to be dead.
Greetz YcKe
italoc
Post by italoc »
no, i don't try to restart domoticz after power failure... i'm trying this evening...
thanks
italoc
Post by italoc »
after reboot works...
thanks
