advice on buying
italoc
advice on buying
Post by italoc »
I'm new for domoticz and i nee do but a Z-WAVE controller and RELAY
for the controller i think to buy this:
Aeotec USB Z-Stick Controllore S5 ZW090-C
and for the RELAY i don't know which of this is better supported on domoticz
FIBARO System FGS222 Double Relay Switch 2x1.5kW
FIBARO System FGS223 Double Relay Switch 2 2x1.5kW
Qubino ZMNHBA2 Flush 2 Relays
Philio Technology Corporation PAN04-1 Double Relay Switch 2x1.5kW
can you help me?
emme
Domoticz version: latest
Re: advice on buying
Post by emme »
they are all well supported in Domoticz... I have few Fibaro and Aeotec relays and I can tell you I do prefer Aeotec than Fibaro: the manual switches use dry contact than neutral wire... but this is my personal opinion that does not affect at all the operation of those devices ;)
ciao
M
"We always done this way"
italoc
Post by italoc »
which is your model?
italoc
Post by italoc »
emme
Post by emme »
for double relay I admit I use Fibaro... (got ony 1)
for switches I use Aeotec DSC18103
for dimmers Aeontec Micro Smart Energy Illuminator
italoc
Post by italoc »
i need a doble relay, and i have read the fibaro FGS-223 have some problem with domoticz FGS-222 works ok?
switch can be used with old meccanical button?
emme
Post by emme »
well... it depends on what you need/want from that device:
I'm using it for the reading lights on my bed... one is for me, the other for my wife (FGS-222)
we both have the related button on our side
it works like it is supposed to do!
It has algo grouping capabilities (it means that by pressing a button you can activate other devices) this has to be configured in the OZWCP...
I'm not using it, but could give a try.
Peronally I do not understand the "partially supported" issue :P
ciao
M
P.S.
it could be that it has a scenray activation feature that... yes... it could be not very well supported my domoticz, but you can create scenaries in Domoticz indeed
italoc
Post by italoc »
i have ordered now a fibaro fgs-222 for use as double relay
i hope that's work correctly
