Python plugin framework for Windows
zak45
Domoticz version: V2024.4
Post by zak45 »
Hi All,
open this thread to have some feedback from you if you have been able to have a running Python Plugin system on your Windows machine.
On my side looks like this work except the onConnect function which give me always error. Have tried Kodi & Yamaha plugins.
this is my configuration :
W10 x64
Python x86 v 3.5.3
Domoticz v 3.6591 running as service using local system account
my log when start Domoticz
2017-02-13 17:47:04.266 Domoticz V3.6591 (c)2012-2017 GizMoCuz
2017-02-13 17:47:04.266 Build Hash: 0176f5fc, Date: 2017-02-03 10:30:02
2017-02-13 17:47:04.295 Sunrise: 08:00:00 SunSet:18:08:00
2017-02-13 17:47:04.295 EventSystem: reset all events...
2017-02-13 17:47:04.328 PluginSystem: Started, Python version '3.5.3'.
2017-02-13 17:47:04.333 Active notification Subsystems: email, kodi, pushbullet (3/12)
2017-02-13 17:47:04.335 WebServer(HTTP) started on address: :: with port 8080
2017-02-13 17:47:04.458 WebServer(SSL) started on address: :: with port 443
2017-02-13 17:47:04.460 Proxymanager started.
2017-02-13 17:47:04.461 Camera: settings (re)loaded
2017-02-13 17:47:04.462 Starting shared server on: :::6144
2017-02-13 17:47:04.462 TCPServer: shared server started...
2017-02-13 17:47:04.462 RxQueue: queue worker started...
2017-02-13 17:47:06.464 Wunderground: Worker started...
2017-02-13 17:47:06.465 Http: Worker started...
2017-02-13 17:47:06.465 Kodi: Started
2017-02-13 17:47:06.465 EventSystem: reset all events...
2017-02-13 17:47:06.466 EventSystem: reset all device statuses...
2017-02-13 17:47:06.468 EventSystem: Started
2017-02-13 17:47:06.566 Kodi: (KodiSalon) Starting thread.
2017-02-13 17:47:06.566 Kodi: (KodiCuisine) Starting thread.
2017-02-13 17:47:06.668 Kodi: Starting I/O service thread.
2017-02-13 17:47:06.714 Kodi: (KodiCuisine) Connected to '192.168.1.38:9090'.
2017-02-13 17:47:06.804 PluginSystem: Entering work loop.
2017-02-13 17:47:06.965 OpenZWave: Starting...
2017-02-13 17:47:06.965 OpenZWave: Version: 1.4.2340.g63fa7f6.dirty
2017-02-13 17:47:06.965 OpenZWave: using config in: C:\Program Files (x86)\Domoticz\Config/
2017-02-13 17:47:07.155 OpenZWave: Driver Ready
my log when I start the Kodi Player HW Python plugin:
2017-02-13 17:53:08.480 (Koditest) Initialized version 1.3.0, author 'dnpwwo'
2017-02-13 17:53:08.480 (Koditest) Debug log level set to: 'true'.
2017-02-13 17:53:08.480 (Koditest) 'Version':'1.3.0'
2017-02-13 17:53:08.480 (Koditest) 'Mode6':'Debug'
2017-02-13 17:53:08.481 (Koditest) 'Author':'dnpwwo'
2017-02-13 17:53:08.481 (Koditest) 'Key':'Kodi'
2017-02-13 17:53:08.481 (Koditest) 'Port':'9090'
2017-02-13 17:53:08.481 (Koditest) 'HomeFolder':'C:\Program Files (x86)\Domoticz\plugins\Kodi\'
2017-02-13 17:53:08.481 (Koditest) 'Mode2':'Ignore'
2017-02-13 17:53:08.481 (Koditest) 'HardwareID':'11'
2017-02-13 17:53:08.481 (Koditest) 'Mode3':'False'
2017-02-13 17:53:08.481 (Koditest) 'Address':'127.0.0.1'
2017-02-13 17:53:08.481 (Koditest) 'Name':'Koditest'
2017-02-13 17:53:08.481 (Koditest) Device count: 4
2017-02-13 17:53:08.481 (Koditest) Device: 1 - ID: 641, Name: 'Koditest - Status', nValue: 0, sValue: ''
2017-02-13 17:53:08.481 (Koditest) Device ID: '641'
2017-02-13 17:53:08.481 (Koditest) Device Name: 'Koditest - Status'
2017-02-13 17:53:08.481 (Koditest) Device nValue: 0
2017-02-13 17:53:08.481 (Koditest) Device sValue: ''
2017-02-13 17:53:08.481 (Koditest) Device LastLevel: 0
2017-02-13 17:53:08.481 (Koditest) Device: 2 - ID: 642, Name: 'Koditest - Source', nValue: 0, sValue: ''
2017-02-13 17:53:08.481 (Koditest) Device ID: '642'
2017-02-13 17:53:08.481 (Koditest) Device Name: 'Koditest - Source'
2017-02-13 17:53:08.481 (Koditest) Device: 3 - ID: 643, Name: 'Koditest - Volume', nValue: 0, sValue: ''
2017-02-13 17:53:08.481 (Koditest) Device ID: '643'
2017-02-13 17:53:08.481 (Koditest) Device Name: 'Koditest - Volume'
2017-02-13 17:53:08.482 (Koditest) Device: 4 - ID: 644, Name: 'Koditest - Playing', nValue: 0, sValue: ''
2017-02-13 17:53:08.482 (Koditest) Device ID: '644'
2017-02-13 17:53:08.482 (Koditest) Device Name: 'Koditest - Playing'
2017-02-13 17:53:08.482 (Koditest) Device nValue: 0
2017-02-13 17:53:08.482 (Koditest) Device sValue: ''
2017-02-13 17:53:08.482 (Koditest) Device LastLevel: 0
2017-02-13 17:53:08.482 (Koditest) Transport set to: 'TCP/IP', 127.0.0.1:9090.
2017-02-13 17:53:08.482 (Koditest) Protocol set to: 'JSON'.
2017-02-13 17:53:08.482 (Koditest) Heartbeat interval set to: 10.
2017-02-13 17:53:08.482 PluginSystem: Starting I/O service thread.
2017-02-13 17:53:08.482 (Koditest) Connect directive received, transport connect initiated successfully.
2017-02-13 17:53:09.488 (Koditest) Calling message handler 'onConnect'.
2017-02-13 17:53:09.488 Error: (Koditest) 'onConnect' failed 'TypeError':'onConnect() missing 2 required positional arguments: 'Status' and 'Description''.
2017-02-13 17:53:18.029 (Koditest) Calling message handler 'onHeartbeat'.
2017-02-13 17:53:18.845 (RFX433E) Temp + Humidity (433-TempSalon)
StanHD
Re: Python plugin framework for Windows
Post by StanHD »
Windows 7
Python x86 v 3.4.3
Domoticz v 3.6694 running as service
Sonos python plug-in, no errors works great.
Python:- Broadlink RM2, Sonos
zak45
Post by zak45 »
@StanHD
if you have opportunity to try / test the Kodi plugin and see how is going could be great.
You can test it even if you do not have kodi...
thanks a lot.
StanHD
Post by StanHD »
Ok, did that and after re-starting Domoticz service and adding hardware log shows:
2017-02-13 20:51:59.374 (Test) Initialized version 1.2.0, author 'dnpwwo'
2017-02-13 20:51:59.449 (Test) Devices created.
2017-02-13 20:51:59.456 PluginSystem: Starting I/O service thread.
2017-02-13 20:52:00.505 (Test) Failed to connect (10061) to: 127.0.0.1:
The failed to connect I guess is because I don't have Kodi installed local.
I do get the 4 devices created in the switch tab.
Does that help?
zak45
Post by zak45 »
yes.. thanks.
this show that something is wrong with my install, but not able to find what :-(
can you do this for me please:
open cmd as admin
and type :
python
import sys
print (sys.path)
interested to see the output.
Brutus
Post by Brutus »
I have the kodi plugin working with my kodi that is running on the same Widows installation.
Windows 7 x64
Python 3.5.2 x86
Domoticz V3.6694 As Service
Kodi and Buienradar plugin.
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
StanHD
Post by StanHD »
zak45 wrote:yes.. thanks.
open cmd as admin
and type :
python
import sys
print (sys.path)
Here you go:- :)
zak45
Post by zak45 »
@StanHD
@Brutus
One quick question : do you compile Domoticz by your own or download already compiled version from the Website ?
FYI: have done fresh install of Domoticz & Python 3.5.3 on W7 x64 computer. tested the Kodi plugin and got the onConnect error :?
Brutus
Post by Brutus »
zak45 wrote:@StanHD
@Brutus
I always download the beta's from the website.
28x Fibaro Modules
SMA Solar System
zak45
Post by zak45 »
Have installed last Domoticz beta on new fresh w7 x64.
Have installed Python 3.5.3, checked put into PATH & for All users.
Tested Kodi plugin v 1.2.0.
Still onConnect error :roll:
2017-02-16 19:11:06.074 Domoticz V3.6722 (c)2012-2017 GizMoCuz
2017-02-16 19:11:06.094 Build Hash: 00b71110, Date: 2017-02-16 09:26:28
2017-02-16 19:11:06.094 Startup delay... waiting 10 seconds...
2017-02-16 19:11:16.235 Sunrise: 07:55:00 SunSet:18:13:00
2017-02-16 19:11:16.235 EventSystem: reset all events...
2017-02-16 19:11:16.298 PluginSystem: Started, Python version '3.5.3'.
2017-02-16 19:11:16.298 Active notification Subsystems: (0/12)
2017-02-16 19:11:16.313 WebServer(HTTP) started on address: :: with port 8080
2017-02-16 19:11:16.532 WebServer(SSL) started on address: :: with port 443
2017-02-16 19:11:16.532 Proxymanager started.
2017-02-16 19:11:16.532 Starting shared server on: :::6144
2017-02-16 19:11:16.532 TCPServer: shared server started...
2017-02-16 19:11:16.532 RxQueue: queue worker started...
2017-02-16 19:11:18.622 EventSystem: reset all events...
2017-02-16 19:11:18.622 EventSystem: reset all device statuses...
2017-02-16 19:11:18.622 EventSystem: Started
2017-02-16 19:11:18.856 PluginSystem: Entering work loop.
2017-02-16 19:11:18.903 (test) Initialized version 1.2.0, author 'dnpwwo'
2017-02-16 19:11:18.903 (test) Debug log level set to: 'true'.
2017-02-16 19:11:18.903 (test) 'Mode2':'Ignore'
2017-02-16 19:11:18.903 (test) 'Address':'127.0.0.1'
2017-02-16 19:11:18.903 (test) 'HomeFolder':'C:\Program Files (x86)\Domoticz\plugins\Kodi\'
2017-02-16 19:11:18.903 (test) 'Name':'test'
2017-02-16 19:11:18.903 (test) 'Mode3':'False'
2017-02-16 19:11:18.903 (test) 'Key':'Kodi'
2017-02-16 19:11:18.903 (test) 'Mode6':'Debug'
2017-02-16 19:11:18.903 (test) 'Author':'dnpwwo'
2017-02-16 19:11:18.903 (test) 'HardwareID':'3'
2017-02-16 19:11:18.903 (test) 'Version':'1.2.0'
2017-02-16 19:11:18.903 (test) 'Port':'9090'
2017-02-16 19:11:18.903 (test) Device count: 4
2017-02-16 19:11:18.903 (test) Device: 1 - ID: 2, Name: 'test - Status', nValue: 0, sValue: ''
2017-02-16 19:11:18.903 (test) Device ID: '2'
2017-02-16 19:11:18.903 (test) Device Name: 'test - Status'
2017-02-16 19:11:18.903 (test) Device nValue: 0
2017-02-16 19:11:18.903 (test) Device sValue: ''
2017-02-16 19:11:18.903 (test) Device LastLevel: 0
2017-02-16 19:11:18.903 (test) Device: 2 - ID: 3, Name: 'test - Source', nValue: 0, sValue: ''
2017-02-16 19:11:18.903 (test) Device ID: '3'
2017-02-16 19:11:18.903 (test) Device Name: 'test - Source'
2017-02-16 19:11:18.903 (test) Device: 3 - ID: 4, Name: 'test - Volume', nValue: 0, sValue: ''
2017-02-16 19:11:18.903 (test) Device ID: '4'
2017-02-16 19:11:18.903 (test) Device Name: 'test - Volume'
2017-02-16 19:11:18.903 (test) Device: 4 - ID: 5, Name: 'test - Playing', nValue: 0, sValue: ''
2017-02-16 19:11:18.903 (test) Device ID: '5'
2017-02-16 19:11:18.903 (test) Device Name: 'test - Playing'
2017-02-16 19:11:18.903 (test) Transport set to: 'TCP/IP', 127.0.0.1:9090.
2017-02-16 19:11:18.903 (test) Protocol set to: 'JSON'.
2017-02-16 19:11:18.903 (test) Heartbeat interval set to: 10.
2017-02-16 19:11:18.903 PluginSystem: Starting I/O service thread.
2017-02-16 19:11:18.903 (test) Connect directive received, transport connect initiated successfully.
2017-02-16 19:11:20.011 (test) Calling message handler 'onConnect'.
2017-02-16 19:11:20.011 Error: (test) 'onConnect' failed 'TypeError':'onConnect() missing 2 required positional arguments: 'Status' and 'Description''.
2017-02-16 19:11:28.871 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:11:29.168 Incoming connection from: 127.0.0.1
2017-02-16 19:11:39.308 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:11:49.729 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:11:49.729 PluginSystem: Starting I/O service thread.
2017-02-16 19:11:49.729 (test) Connect directive received, transport connect initiated successfully.
2017-02-16 19:11:50.774 (test) Calling message handler 'onConnect'.
2017-02-16 19:11:50.774 Error: (test) 'onConnect' failed 'TypeError':'onConnect() missing 2 required positional arguments: 'Status' and 'Description''.
2017-02-16 19:12:00.212 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:12:10.633 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:12:21.069 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:12:21.069 PluginSystem: Starting I/O service thread.
2017-02-16 19:12:21.069 (test) Connect directive received, transport connect initiated successfully.
2017-02-16 19:12:22.130 (test) Calling message handler 'onConnect'.
2017-02-16 19:12:22.130 Error: (test) 'onConnect' failed 'TypeError':'onConnect() missing 2 required positional arguments: 'Status' and 'Description''.
2017-02-16 19:12:31.568 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:12:41.973 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:12:52.409 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:12:52.409 PluginSystem: Starting I/O service thread.
2017-02-16 19:12:52.409 (test) Connect directive received, transport connect initiated successfully.
2017-02-16 19:12:53.470 (test) Calling message handler 'onConnect'.
2017-02-16 19:12:53.470 Error: (test) 'onConnect' failed 'TypeError':'onConnect() missing 2 required positional arguments: 'Status' and 'Description''.
2017-02-16 19:13:02.908 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:13:13.329 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:13:23.734 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:13:23.734 PluginSystem: Starting I/O service thread.
2017-02-16 19:13:23.734 (test) Connect directive received, transport connect initiated successfully.
2017-02-16 19:13:24.811 (test) Calling message handler 'onConnect'.
2017-02-16 19:13:24.811 Error: (test) 'onConnect' failed 'TypeError':'onConnect() missing 2 required positional arguments: 'Status' and 'Description''.
2017-02-16 19:13:34.233 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:13:44.607 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:13:55.168 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:13:55.168 PluginSystem: Starting I/O service thread.
2017-02-16 19:13:55.168 (test) Connect directive received, transport connect initiated successfully.
2017-02-16 19:13:56.229 (test) Calling message handler 'onConnect'.
2017-02-16 19:13:56.229 Error: (test) 'onConnect' failed 'TypeError':'onConnect() missing 2 required positional arguments: 'Status' and 'Description''.
2017-02-16 19:14:05.511 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:14:16.010 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:14:26.431 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:14:26.431 PluginSystem: Starting I/O service thread.
2017-02-16 19:14:26.431 (test) Connect directive received, transport connect initiated successfully.
2017-02-16 19:14:27.507 (test) Calling message handler 'onConnect'.
2017-02-16 19:14:27.507 Error: (test) 'onConnect' failed 'TypeError':'onConnect() missing 2 required positional arguments: 'Status' and 'Description''.
2017-02-16 19:14:36.867 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:14:47.366 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:14:57.771 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:14:57.771 PluginSystem: Starting I/O service thread.
2017-02-16 19:14:57.771 (test) Connect directive received, transport connect initiated successfully.
2017-02-16 19:14:58.832 (test) Calling message handler 'onConnect'.
2017-02-16 19:14:58.832 Error: (test) 'onConnect' failed 'TypeError':'onConnect() missing 2 required positional arguments: 'Status' and 'Description''.
2017-02-16 19:15:08.207 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:15:18.706 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:15:29.111 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:15:29.111 PluginSystem: Starting I/O service thread.
2017-02-16 19:15:29.111 (test) Connect directive received, transport connect initiated successfully.
2017-02-16 19:15:30.172 (test) Calling message handler 'onConnect'.
2017-02-16 19:15:30.172 Error: (test) 'onConnect' failed 'TypeError':'onConnect() missing 2 required positional arguments: 'Status' and 'Description''.
2017-02-16 19:15:39.532 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:15:50.031 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:16:00.467 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:16:00.467 PluginSystem: Starting I/O service thread.
2017-02-16 19:16:00.467 (test) Connect directive received, transport connect initiated successfully.
2017-02-16 19:16:01.528 (test) Calling message handler 'onConnect'.
2017-02-16 19:16:01.528 Error: (test) 'onConnect' failed 'TypeError':'onConnect() missing 2 required positional arguments: 'Status' and 'Description''.
2017-02-16 19:16:10.873 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:16:21.371 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:16:31.808 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:16:31.808 PluginSystem: Starting I/O service thread.
2017-02-16 19:16:31.808 (test) Connect directive received, transport connect initiated successfully.
2017-02-16 19:16:32.869 (test) Calling message handler 'onConnect'.
2017-02-16 19:16:32.869 Error: (test) 'onConnect' failed 'TypeError':'onConnect() missing 2 required positional arguments: 'Status' and 'Description''.
2017-02-16 19:16:42.229 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:16:52.712 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:17:03.133 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:17:03.133 PluginSystem: Starting I/O service thread.
2017-02-16 19:17:03.133 (test) Connect directive received, transport connect initiated successfully.
2017-02-16 19:17:04.209 (test) Calling message handler 'onConnect'.
2017-02-16 19:17:04.209 Error: (test) 'onConnect' failed 'TypeError':'onConnect() missing 2 required positional arguments: 'Status' and 'Description''.
2017-02-16 19:17:13.569 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:17:24.068 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:17:34.473 (test) Calling message handler 'onHeartbeat'.
2017-02-16 19:17:34.473 PluginSystem: Starting I/O service thread.
2017-02-16 19:17:34.473 (test) Connect directive received, transport connect initiated successfully.
2017-02-16 19:17:35.534 (test) Calling message handler 'onConnect'.
2017-02-16 19:17:35.534 Error: (test) 'onConnect' failed 'TypeError':'onConnect() missing 2 required positional arguments: 'Status' and 'Description''.
What I missing ???
Brutus
Post by Brutus »
zak45 wrote:Have installed last Domoticz beta on new fresh w7 x64.
What I missing ???
Dnpwwo helped me with a nice install instruction maybe you are doing something different?
http://www.domoticz.com/forum/viewtopic ... 20#p110486
28x Fibaro Modules
SMA Solar System
zak45
Post by zak45 »
Thanks, this one has already helped me.
My last test has been to uninstall 3.5.3 and install 3.5.2... just in case of !!!
And ... same error.
So, I'm a little bit lost :!:
What is frustrating is that you know there is something wrong somewhere.. but not able to find it ...
zak45
Post by zak45 »
so, looks like found something
viewtopic.php?f=6&t=16168
thanks a lot guys
StanHD
Re: RE: Re: Python plugin framework for Windows
Post by StanHD »
zak45 wrote:so, looks like found something
thanks a lot guys
Wow that's an unexpected find, Microsoft eh?. Image Well done glad you found the problem Image
Vzet
Post by Vzet »
I’m quite new to Domoticz and struggling with plugins.
Can someone please explain to me, how to “activate” a python plugin for Domoticz running under Windows?
zak45
Post by zak45 »
Vzet wrote: Wednesday 25 October 2017 10:52 I’m quite new to Domoticz and struggling with plugins.
Welcome to this wonderfull world ... but can make some frustration also at the beginning !!!
just to try to provide some help:
install python 32 b
select custom installation and choose for "all users"...
see this link viewtopic.php?f=41&t=7098&p=110486&hili ... er#p110486
Vzet
Post by Vzet »
Hi Zak45, thanks for your answer.
I already installed Python before, but what is not clear to me is:
do I have to run the plugin once manually, and is it than completely integrated in Domoticz, or do I have to call it in Domoticz somehow, or do I need to call the plugin in a script in Domoticz, or do I just need to place the Python plugin in a certain directory, or.………???
zak45
Post by zak45 »
see http://www.domoticz.com/wiki/Using_Python_plugins
you need also to follow the instruction provided by the plugin devloper
e.g:
Vzet
Post by Vzet »
Thnx again for the answers.
I don’t have a “plugins” directory under my Domoticz directory (under Program Files). Maybe something went wrong installing Python.
I will try to reinstall Python, with your link in an earlier post.
