Reacticz dashboard: no install, no hassle
Snowtiger
Domoticz version: 4.10915
Re: Reacticz dashboard: no install, no hassle
Post by Snowtiger »
blackdog65 wrote:Hi,
I have managed to get node-red and mqtt installed and running as well as a mqtt client in domoticz... so far so good.
If I clone reactictz directly into the domoticz www folder it cannot install as it is looking for package.json in the home folder. So do I install build etc in my home folder and then move the entire package to domoticz? I was going round in circles last night until very late... but still want to attack it and win today ;)
I think you need to fill the correct root directory in the package.json file - see the post above yours about building your own build, especially the part about the note
NietGiftig
Domoticz version: V3.6224
Post by NietGiftig »
Maybe you missed this part about installing React on your PC.
Necessary to build your own version of Reacticz
https://github.com/t0mg/reacticz/blob/m ... ng-testing
If you really read the guidelines here it's must be working
But cloning the complete git to the www dir is not good
After npm run build (a node.js command) the contents of the build directory must be copied to your www directory, or a subdirectory of the ww dir from domoticz
RPI-2 + SSD / ESPEasy Sensors & Switches / Sonoff / RFLink / Action Switches / TP-Link switch / Node-Red / Reacticz
ptitneo
Post by ptitneo »
By default Reacticz builds assuming it is hosted at the server root. Before you build Reacticz, you need to change the homepage property in the package.json. See the note in the build instructions here.
blackdog65
Post by blackdog65 »
Thanks guys, I had the package json correct but the where to put it all... wrong :oops:
The instructions ( and I have read them all) are ambiguous about..
a) Root folder or home folder
b) Move build folder... but rename it reacticz? Or into a new folder called reacticz?
Sorry if I appear stupid... very little sleep last night :roll:
Sean :D
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
NietGiftig
blackdog65 wrote: Sorry if I appear stupid... very little sleep last night :roll:
Maybe have some sleep, and come back tomorow.
And tell us what you want.
If you want to run Recticz on your own server, you have to buld reacticz first.
After that it must be placed in a subdir from the www dir of domoticz
But now am I repeating myself, so I stop.
And ambiguous?
I'm a complete www noob, but it worked for me.
ptitneo
Post by ptitneo »
Don't worry, I'm getting that a lot. Which is a little depressing since I created Reacticz to be a no-install thing, so I made the public server to spare the burden of installing it. But it seems everyone still wants to do that anyway :)
Anyway, I'd be really grateful if a good soul could make a wiki page with detailed step-by-step instructions and command lines for building and installing in domoticz's www folder! It seems I'm failing at making it clear myself.
blackdog65
ptitneo wrote:Don't worry, I'm getting that a lot. Which is a little depressing since I created Reacticz to be a no-install thing, so I made the public server to spare the burden of installing it. But it seems everyone still wants to do that anyway :)
Thanks,
I'm rebuilding it now and will see how I get on.
Once I get it all sorted I'll have a look at writing something for the wiki, maybe the domoticz wiki too. I probably missed a simple step, as we sometimes "can't see the wood for the trees". I'm quite busy re-building a new look domoticz.com at the moment, but with the unhelpful and sarcastic attitude of some users... I wonder is it worth it :roll:
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
NietGiftig
ptitneo wrote:since I created Reacticz to be a no-install thing, so I made the public server to spare the burden of installing it. But it seems everyone still wants to do that anyway :)
A separate branch ot github, with Reacticz build for local Domoticz /www/reacticz/ use, would be nice
But then, the user must know how to use the git to copy the correct branch. :shock:
The wish to have it build local comes with the burden of having installing node.js, react etc.
On Windows?, Linux?, Mac?
On your desktop?, or on the raspberry?
Snowtiger
Post by Snowtiger »
I have Nginx running on my Pi with the gh-pages branch cloned into the root folder - no hassle, no install ;) but this requires an extra webserver running when you have Domoticz available, I know - but install and running Nginx is not a big deal
ptitneo
Post by ptitneo »
NietGiftig wrote: A separate branch ot github, with Reacticz build for local Domoticz /www/reacticz/ use, would be nice
I agree, a dedicated branch with just the pre-built releases as zip packages would probably make it easier for those who want a local install but don't have node.
felix63
Domoticz version: 2020.1
Post by felix63 »
I can not get Reacticz to work. Spend a couple of hours (it way past bedtime). Googled everything I could think of.
I have the correct version of mosquitto running
$ mosquitto -v
1486420919: mosquitto version 1.4.10 (build date Thu, 25 Aug 2016 10:12:09 +0100) starting
however
sudo mosquitto start
(or restart) don't work. The service isn't started. I checked with
--sudo service --status-all
My config-file (/etc/mosquitto/mosquitto.conf) is
# Place your local configuration in /etc/mosquitto/conf.d/
# A full description of the configuration file is at
# /usr/share/doc/mosquitto/examples/mosquitto.conf.example
pid_file /var/run/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
include_dir /etc/mosquitto/conf.d
which refers to /etc/mosquitto/conf.d/ which has /etc/mosquitto/conf.d/websocket.conf
# Standard Listener
listener 1883
protocol mqtt
#allow_anonymous false
#password_file /etc/mosquitto/passwords.txt
# Websockets Listener
listener 1884
#http_dir
#Set the protocol to accept for this listener. Can be mqtt (the default), or websockets.
protocol websockets
If I run mosquitto from the console with
sudo mosquitto -c /etc/mosquitto/mosquitto.conf
and I check my ports I see:
portscan is gestart…
Port Scanning host: 192.168.178.50
	 Open TCP Port: 	22     		ssh
	 Open TCP Port: 	443    		https
	 Open TCP Port: 	1880   		vsat-control
	 Open TCP Port: 	1883   		ibm-mqisdp
	 Open TCP Port: 	1884   		idmaps
	 Open TCP Port: 	2812   		atmtcp
	 Open TCP Port: 	6144   		statsci1-lm
	 Open TCP Port: 	8080   		http-alt
portscan is voltooid…
So MQTT seems to be running. In Domoticz I've created the hardware:
19	Mosquitto	Ja	MQTT Client Gateway with LAN interface	192.168.178.50	1884	Niet actief
The server settings in Reacticz are:
MQTT Broker URL: connected!
ws://192.168.178.50:1884
Domoticz server URL:
http://192.168.178.50:8080
The mosquitto log-file doesn't help.
1486422160: mosquitto version 1.4.10 (build date Thu, 25 Aug 2016 10:12:09 +0100) starting
1486422160: Config loaded from /etc/mosquitto/mosquitto.conf.
1486422160: Opening ipv4 listen socket on port 1883.
1486422160: Opening ipv6 listen socket on port 1883.
1486422160: Opening websockets listen socket on port 1884.
1486422161: New client connected from 192.168.178.29 as mqttjs_7610b5c1 (c1, k60).
1486422161: Sending CONNACK to mqttjs_7610b5c1 (0, 0)
1486422161: Received SUBSCRIBE from mqttjs_7610b5c1
1486422161: 	domoticz/out (QoS 0)
1486422161: mqttjs_7610b5c1 0 domoticz/out
1486422161: Sending SUBACK to mqttjs_7610b5c1
1486422161: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32473, 'domoticz/in', ... (37 bytes))
1486422161: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32473)
1486422161: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32474, 'domoticz/in', ... (36 bytes))
1486422161: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32474)
1486422161: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32475, 'domoticz/in', ... (37 bytes))
1486422161: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32475)
1486422161: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32476, 'domoticz/in', ... (36 bytes))
1486422161: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32476)
1486422161: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32477, 'domoticz/in', ... (36 bytes))
1486422161: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32477)
1486422161: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32478, 'domoticz/in', ... (36 bytes))
1486422161: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32478)
1486422161: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32479, 'domoticz/in', ... (37 bytes))
1486422161: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32479)
1486422161: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32480, 'domoticz/in', ... (37 bytes))
1486422161: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32480)
1486422161: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32481, 'domoticz/in', ... (37 bytes))
1486422161: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32481)
1486422161: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32482, 'domoticz/in', ... (37 bytes))
1486422161: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32482)
1486422161: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32483, 'domoticz/in', ... (37 bytes))
1486422161: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32483)
1486422161: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32484, 'domoticz/in', ... (37 bytes))
1486422161: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32484)
1486422161: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32485, 'domoticz/in', ... (37 bytes))
1486422161: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32485)
1486422161: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32486, 'domoticz/in', ... (37 bytes))
1486422161: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32486)
1486422161: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32487, 'domoticz/in', ... (37 bytes))
1486422161: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32487)
1486422161: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32488, 'domoticz/in', ... (36 bytes))
1486422161: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32488)
1486422161: Received PUBREL from mqttjs_7610b5c1 (Mid: 32473)
1486422161: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32473)
1486422161: Received PUBREL from mqttjs_7610b5c1 (Mid: 32474)
1486422161: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32474)
1486422161: Received PUBREL from mqttjs_7610b5c1 (Mid: 32475)
1486422161: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32475)
1486422161: Received PUBREL from mqttjs_7610b5c1 (Mid: 32476)
1486422161: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32476)
1486422161: Received PUBREL from mqttjs_7610b5c1 (Mid: 32477)
1486422161: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32477)
1486422161: Received PUBREL from mqttjs_7610b5c1 (Mid: 32478)
1486422161: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32478)
1486422161: Received PUBREL from mqttjs_7610b5c1 (Mid: 32479)
1486422161: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32479)
1486422161: Received PUBREL from mqttjs_7610b5c1 (Mid: 32480)
1486422161: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32480)
1486422161: Received PUBREL from mqttjs_7610b5c1 (Mid: 32481)
1486422161: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32481)
1486422161: Received PUBREL from mqttjs_7610b5c1 (Mid: 32482)
1486422161: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32482)
1486422161: Received PUBREL from mqttjs_7610b5c1 (Mid: 32483)
1486422161: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32483)
1486422161: Received PUBREL from mqttjs_7610b5c1 (Mid: 32484)
1486422161: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32484)
1486422161: Received PUBREL from mqttjs_7610b5c1 (Mid: 32485)
1486422161: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32485)
1486422161: Received PUBREL from mqttjs_7610b5c1 (Mid: 32486)
1486422161: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32486)
1486422161: Received PUBREL from mqttjs_7610b5c1 (Mid: 32487)
1486422161: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32487)
1486422161: Received PUBREL from mqttjs_7610b5c1 (Mid: 32488)
1486422161: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32488)
1486422179: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32489, 'domoticz/in', ... (36 bytes))
1486422179: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32489)
1486422179: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32490, 'domoticz/in', ... (37 bytes))
1486422179: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32490)
1486422179: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32491, 'domoticz/in', ... (36 bytes))
1486422179: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32491)
1486422179: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32492, 'domoticz/in', ... (37 bytes))
1486422179: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32492)
1486422179: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32493, 'domoticz/in', ... (36 bytes))
1486422179: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32493)
1486422179: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32494, 'domoticz/in', ... (37 bytes))
1486422179: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32494)
1486422179: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32495, 'domoticz/in', ... (36 bytes))
1486422179: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32495)
1486422179: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32496, 'domoticz/in', ... (37 bytes))
1486422179: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32496)
1486422179: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32497, 'domoticz/in', ... (36 bytes))
1486422179: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32497)
1486422179: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32498, 'domoticz/in', ... (37 bytes))
1486422179: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32498)
1486422179: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32499, 'domoticz/in', ... (37 bytes))
1486422179: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32499)
1486422179: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32500, 'domoticz/in', ... (37 bytes))
1486422179: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32500)
1486422179: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32501, 'domoticz/in', ... (37 bytes))
1486422179: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32501)
1486422179: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32502, 'domoticz/in', ... (37 bytes))
1486422179: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32502)
1486422179: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32503, 'domoticz/in', ... (37 bytes))
1486422179: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32503)
1486422179: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32504, 'domoticz/in', ... (37 bytes))
1486422179: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32504)
1486422180: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32505, 'domoticz/in', ... (37 bytes))
1486422180: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32505)
1486422180: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32506, 'domoticz/in', ... (37 bytes))
1486422180: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32506)
1486422180: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32507, 'domoticz/in', ... (37 bytes))
1486422180: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32507)
1486422180: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32508, 'domoticz/in', ... (37 bytes))
1486422180: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32508)
1486422180: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32509, 'domoticz/in', ... (37 bytes))
1486422180: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32510, 'domoticz/in', ... (37 bytes))
1486422180: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32511, 'domoticz/in', ... (37 bytes))
1486422180: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32512, 'domoticz/in', ... (37 bytes))
1486422180: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32513, 'domoticz/in', ... (37 bytes))
1486422180: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32514, 'domoticz/in', ... (37 bytes))
1486422180: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32515, 'domoticz/in', ... (37 bytes))
1486422180: Received PUBLISH from mqttjs_7610b5c1 (d0, q2, r0, m32516, 'domoticz/in', ... (37 bytes))
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32489)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32489)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32490)
1486422180: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32509)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32490)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32491)
1486422180: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32510)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32491)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32492)
1486422180: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32511)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32492)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32493)
1486422180: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32512)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32493)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32494)
1486422180: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32513)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32494)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32495)
1486422180: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32514)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32495)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32496)
1486422180: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32515)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32496)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32497)
1486422180: Sending PUBREC to mqttjs_7610b5c1 (Mid: 32516)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32497)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32498)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32498)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32499)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32499)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32500)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32500)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32501)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32501)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32502)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32502)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32503)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32503)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32504)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32504)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32505)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32505)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32506)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32506)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32507)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32507)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32508)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32508)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32509)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32509)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32510)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32510)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32511)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32511)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32512)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32512)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32513)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32513)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32514)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32514)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32515)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32515)
1486422180: Received PUBREL from mqttjs_7610b5c1 (Mid: 32516)
1486422180: Sending PUBCOMP to mqttjs_7610b5c1 (Mid: 32516)
1486422190: mosquitto version 1.4.10 terminating
I have the following problems:
1- mosquitto doesn't start as a service they way it should
2- in the domoticz.log 1-2 times per minute it shows:
2017-02-06 23:52:52.469 MQTT: Connecting to 192.168.178.50:1884
2017-02-06 23:52:52.671 Error: MQTT: disconnected, restarting (rc=7)
3- in Reacticz all the devices are shown as 'Offline?'
Sorry for the lengthy post. But does someone have any idea what I could try next?
G3rard
Domoticz version: No
Post by G3rard »
You should connect Domoticz to MQTT port 1883 and not 1884.
Reactiz should be connected to the websocket, which is 1884, so that part is correct.
Not sure if that is the only problem, but maybe it is :)
Not using Domoticz anymore
felix63
Post by felix63 »
That sure helped with part of my problems! thanks
ptitneo
Post by ptitneo »
Hi everyone, due to popular demand I've created a first release tag on github, you can now download a pre-built package that will work from your domoticz/www folder right out of the box :)
https://github.com/t0mg/reacticz/releases/tag/v0.1.8
Reacticz now supports many new sensors as well as domoticz/mqtt authentication, thanks to the efforts of G3rard and davidlb.
Cheers!
PS felix63 I hope you were able to fix your problems! I think so since you've created tickets on github :)
simonrg
Domoticz version: 3.8807
Post by simonrg »
Great work, Reacticz is a very nice and clean interface.
The local implementation is even cleaner and I thought may give me new possiblities.
I would like to be able to create a number of different very simple pages of buttons - ones for different times of day and different parts of the house, with just a few buttons displayed. So TV Room - just with the TV and light controls for that room, Bedtime - just with set alarm and switch of lights in different parts of the house.
My knowledge of web page details is scanty, so this may be either very easy to do by another route or just plain stupid.
I thought if I just made symbolic links to the reacticz directory on my Raspberry Pi -
ln -s reacticz/ reacticz-tv
So I thought I would now have two different pages - http://domoticz-ip:8080/reacticz/ and http://domoticz-ip:8080/reacticz-tv/, which will show different sets of buttons, but this doesn't work as obviously the caching is done by ip not by directory so both directories display the same buttons.
Is there any easy way to do this? I hoped to have a series of home page buttons which took me to the few controls I need for different situations.
Thanks, Simon
Raspberry Pi 2 B - 2A@5V PSU - Raspbian + Domoticz + RFXtrx(89), LightwaveRF House(dimmers, sockets, wireless/mood switches), Owl CM113, 4 LaCross Temp / Humidity Sensors, 4 Siemens PIR, Smappee, Solaredge, ESP8266
ptitneo
Post by ptitneo »
Interesting :) Your symlink idea is pretty clever. Unfortunately reacticz uses localStorage, which is unique for a given domain and protocol, regardless of the path.
I knew that eventually the need would come for several configurations on the same device. I have a simple idea that I need to try. In the mean time feel free to file an issue in github!
Cheers,
ptitneo
Post by ptitneo »
Following up on this: I've added an experimental way to have multiple dashboards on the same device/browser. It's documented on the wiki.
The feature is available on the public server.
Cheers!
rickwilleme
Domoticz version: 3.6792
Post by rickwilleme »
First of all: thanks ptitneo for this amazing piece of software.
For me (well, maybe more for my girlfriend :lol: ) this is really a game changer!!
During the config, I do however encounter a small issue.
We have 2 blinds (left and right). One is being recognized, but not responding. The other mentions "Offline ?"
Any way to troubleshoot this issue?
Help is very appreciated!
Regards,
Rick
Raspberry Pi ~ Fibaro Dimmer (Z-Wave) ~ Several KAKU switches and dimmers (433 MHz) ~ Amazon Echo ~ Somfy RTS ~ Sony TV ~ Kodi/XBMC ~ Essent E-Thermostaat (ICY) ~ Cresta thermostat ~ Wundermap Weather ~ Smoke detectors
rickwilleme
In addition to the statement above, I actually notice that more switches and groups are not responding.
My gut feeling says that something got messed up in the config, but 'starting all over' doesn't seem to fix it..
ptitneo
Post by ptitneo »
Sounds like something is wrong with the config indeed. Are you using the public server or a local install? And in the server settings do you get the green "connected!" message on both Domoticz and MQTT?
