Failed to detect any pins error ?
jslegers
Domoticz version: 2025.2
Post by jslegers »
Yesterday my neighbor and I installed a water meter with a TCRT5000 board. I have connected the sensor on pin 12 GPIO 18.
If i start manually /usr/local/bin/gpio export 18 in and then /home/pi/domoticz/domoticz my water counter works.
But when we place /usr/local/bin/gpio export 18 in in the domoticz.sh script we get an error.
29 22:20:11.910 EventSystem: reset all events...
2016-02-29 22:20:11.936 Error: GPIO: Failed to detect any pins, make sure you exported them!
2016-02-29 22:20:11.972 Active notification subsystems: (0/10)
2016-02-29 22:20:11.982 Webserver started on port: 8080
2016-02-29 22:20:11.995 Started sh
We have also tried to put this command in /etc/init/d/rc.local file but the same error.
Any one else also seen this problem before ?
sincze
Domoticz version: 2024.4
Re: Failed to detect any pins error ?
Post by sincze »
I'll install latest Domoticz version from the site 2.4834 on my SD and see if I can replicate the situation. :D
Pretty strange.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
sincze
Post by sincze »
Ok Running v2.2563 on Raspberry Pi 2.
I did the following:
1. DOWNLOAD & INSTALL WIRING PI http://wiringpi.com/download-and-install/
2. Create the exports my Watermeter is connected to
Watermeter GPIO
Watermeter GPIO
Aansluiting Sensoren (GPIO).png (305.51 KiB) Viewed 5734 times
	gpio export 18 in
	gpio edge 18 both
2. Check the export:
	gpio exports
3. To have the GPIO available in Domoticz I added the following lines to the /etc/init.d/domoticz.sh script as described here: https://www.domoticz.com/wiki/GPIO
At the end of the file after the ":"
#Run export GPIO Raspberry
/usr/local/bin/gpio edge 18 both
4. Reboot the system
sudo shutdown -r now
[code]
5. Created the GPIO sensor as described here: [url]https://www.domoticz.com/wiki/GPIO[/url]"
6. Added LUA to /domoticz/script/lua directory as script_device_watermeter.lua
[code]
	print('> Monitoring water consumption')
	-- Water usage
	-- Retrieve value from water meter device:
	sWaterUsage = otherdevices_svalues['Water']
	-- To have a better readable format, divide number by 1000:
	sWaterUsagePrint = tonumber(sWaterUsage / 1000);
	-- calculation is done with the unmodified water value
	sWaterUsage = tonumber(sWaterUsage);
	print(">> Utilities: Water usage until now is " .. sWaterUsagePrint .. " ");
	if (devicechanged['GPIO_WATER'] == 'Closed')
	then
	   sWaterUsageTot = (sWaterUsage + 1)
	print(">> Utilities: Water usage is now " .. sWaterUsageTot .. " ");
	commandArray['OpenURL']='http://IPADDRESS:PORT/json.htm?	type=command&param=udevice&idx=164&svalue='..sWaterUsageTot..''
This is working okay, no error messages. :D
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Post by sincze »
I just updated to v2.4834
Using the steps described here: https://www.domoticz.com/wiki/Installin ... pberry_PI
mkdir ~/domoticz
cd ~/domoticz
wget http://www.domoticz.com/releases/release/domoticz_linux_armv7l.tgz
tar xvfz domoticz_linux_armv7l.tgz
rm domoticz_linux_armv7l.tgz
The Watermeter is still working.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Post by sincze »
Just added 4,7k resistor between 3,3v and GND pin.
Modified the LUA script from:
if (devicechanged['Water'] == 'Closed')
then
to:
then
   sWaterUsageTot = (sWaterUsage + 0.5)
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Post by sincze »
And while busy whu not remove the http update if the device update can be done from within LUA now :D
-- Script parameters
debug = true                    -- Turn debugging on ("true") or off ("false")
metername="Watermeter"
meteridx=7
if (debug)
then
-- Water usage
sWaterUsage = otherdevices_svalues[metername]
if (debug)
then
then
   commandArray['UpdateDevice']=meteridx .. "|0|" .. sWaterUsageTot
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
jslegers
Post by jslegers »
Thanks for the effort. I will test it this weekend.
Good job.
joostnl
Post by joostnl »
Thank you for all your work. Only i can't get it to work...
I did everything you descriped but when i add the lua to Domoticz.
I get in my log:
2017-02-12 15:26:26.917 LUA: > Monitoring water consumption
2017-02-12 15:26:26.918 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_watermeter.lua: /home/pi/domoticz/scripts/lua/script_device_watermeter.lua:24: attempt to perform arithmetic on global 'sWaterUsage' (a string value)
In your script i only changed the device idx to: 117 (because i see that in devices)
Do i have to change more in the script?
Or do i also need to ad a watermeter to display the input values? (i added only the switch you described)
Thanks in advance!
sincze
Post by sincze »
joostnl wrote:Thank you for all your work. Only i can't get it to work...
I get in my log:
Thanks in advance!
Show me your script
you need to change IDX and create a water meter as well. in my example below the meter is called water
So the GPIO switch is for counting open/closed.... and that should add 1 liter to the watermeter. :D
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
joostnl
Post by joostnl »
The idx value of '117' is my GPIO Switch so I used this in the script
I added a flowmeter called: 'Water' with a dummy hardware, then add virtual sensor is this correct?
Another question: How did you mount the sensor and why you used a resistor inbetween?
Thanks for your responds, im pretty new to scripting :geek:
meteridx=117
if (debug)
then
-- Water usage
if (debug)
then
then
sincze
Post by sincze »
joostnl wrote:The idx value of '117' is my GPIO Switch so I used this in the script
meteridx=117
if (debug)
then
-- Water usage
if (debug)
then
then
Have a look here for my mounting bracket. ;-)
viewtopic.php?t=2157&start=20
viewtopic.php?t=5021#p64026
The resistor was used as a pull down to avoid false positives.
In the end I removed it and solved the whole watermeter in a different way.
as described here: viewtopic.php?t=5021#p41946. It has been working for over 2 years now flawless with isrcounter.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
joostnl
Post by joostnl »
Thanks for your photo's I made a simular bracket from DIN RAIL.
I tuned the sensor that the green light go's on when the reflective part of the water meter passes by. I found it to hard to point it at the end of the red arrow.
Must i change my sensor now to NO or NC?
Without your script i get some times an error.
"2017-02-18 17:19:30.120 Error: Watermeter hardware (13) thread seems to have ended unexpectedly"
This is not normal right?
I got the script working, i was confused with were 'water' and 'watermeter' had to be haha
Why are you counting with 0.5? I thougth 1 revolution was 1 L not 0.5
2017-02-18 17:19:26.172 GPIO: Queuing interrupt for GPIO 18.
2017-02-18 17:19:26.172 GPIO: 1 interrupts in queue.
2017-02-18 17:19:26.172 GPIO: Too many interrupts for GPIO 18. Ignoring..
2017-02-18 17:19:26.172 GPIO: Acknowledging interrupt for GPIO 18.
2017-02-18 17:19:26.172 GPIO: Processing interrupt for GPIO 18...
2017-02-18 17:19:26.222 GPIO: Done processing interrupt for GPIO 18 (LOW).
2017-02-18 17:19:26.223 (Watermeter) Lighting 1 (Watermeter)
2017-02-18 17:19:27.882 GPIO: Queuing interrupt for GPIO 18.
2017-02-18 17:19:27.882 GPIO: 1 interrupts in queue.
2017-02-18 17:19:27.883 GPIO: Too many interrupts for GPIO 18. Ignoring..
2017-02-18 17:19:27.883 GPIO: Acknowledging interrupt for GPIO 18.
2017-02-18 17:19:27.883 GPIO: Processing interrupt for GPIO 18...
2017-02-18 17:19:27.933 GPIO: Done processing interrupt for GPIO 18 (HIGH).
2017-02-18 17:19:27.933 (Watermeter) Lighting 1 (Watermeter)
2017-02-18 17:19:33.073 GPIO: Queuing interrupt for GPIO 18.
2017-02-18 17:19:33.073 GPIO: 1 interrupts in queue.
2017-02-18 17:19:33.073 GPIO: Too many interrupts for GPIO 18. Ignoring..
2017-02-18 17:19:33.074 GPIO: Acknowledging interrupt for GPIO 18.
2017-02-18 17:19:33.074 GPIO: Processing interrupt for GPIO 18...
2017-02-18 17:19:33.124 GPIO: Done processing interrupt for GPIO 18 (LOW).
sincze
Post by sincze »
Ha well mine was counting double so when I used 1 liter... :D
- On detection of the disk it would say 1 liter used
- When leaving the detection of the disk area.. again 1 liter used.
But instead ofcourse it was still just 1 liter not 2.
Also I had some problems when the disk would stop.... (because i did not use water) right in the middle of the detection area.
No problem as it was ignoring the multiple interrupts just as your log shows.
However when I continued using water again.. Again one 1 additional liter. So my mater usage was double according to domoticz.
Hope this helps :D
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
joostnl
Post by joostnl »
Clear, mine is counting correctly if I use 10L water it counts 10, so I changed to script to +1.
Can you maybe tell me how to install the Isrcounter?
I followed https://www.domoticz.com/wiki/GPIO
Do i only have to set the correct:
We use gpio: 18 so i have to change 4 into 18?
// What GPIO input are we using?
// This is a wiringPi pin number
#define IN_PIN 4
#define INTERRUPT_DEBOUNCE_DELAY 500
sincze
Post by sincze »
joostnl wrote:Clear, mine is counting correctly if I use 10L water it counts 10, so I changed to script to +1.
#define IN_PIN 4
how to install isrcounter is slightly different.
viewtopic.php?f=32&t=3151&start=60#p112272
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
