seconds after posting the post above following happend:
20;04;DEBUG;Pulses=42;Pulses(uSec)=330,1980,240,1980,270,2010,240,4560,240,2010,240,1980,270,2010,240,1980,270,2010,270,2010,240,2010,240,2010,240,2010,270,1980,270,4560,240,1980,240,2010,240,4560,240,2010,240,2040,210,6990;
20;05;Friedland;ID=00000820;SWITCH=1;CMD=ON;CHIME=01;
20;06;DEBUG;Pulses=36;Pulses(uSec)=330,4560,240,1980,270,2010,240,2010,240,4560,240,1980,270,2010,240,1980,270,1980,270,2010,240,2010,240,2010,240,2010,240,2010,240,1980,240,4560,270,1980,270,1590;
20;07;DEBUG;Pulses=38;Pulses(uSec)=330,2010,240,2010,240,4590,240,4590,240,1980,270,2010,240,2010,240,4560,270,2010,240,2010,240,1980,270,2010,240,2010,240,2010,240,2010,240,1980,270,2010,240,1920,330,1860;
20;08;DEBUG;Pulses=34;Pulses(uSec)=300,2010,240,2010,240,4590,240,2010,240,1980,270,1980,270,1980,270,1980,240,2010,240,2010,240,2010,240,1980,270,1980,240,4590,240,2010,240,2010,240,1890;
20;09;Friedland;ID=00000020;SWITCH=1;CMD=ON;CHIME=01;
Does the unit has some kind of start-up time or something?
Rflink Not Working at all
Re: Rflink Not Working at all
So, the unit seems to be working fine now. What i did found out is when i connected the Arduino to the PI with the USBcable deliverd with the unit it wouldnt power up, when fiddling with the cable it did. So i recieved a broken USB cable and the build guide i followed was wrong!
Stuntteam wrote:Yes, but use the 12&13 near the USB connector
working after reset! thanks
Guys, what I am doing wrong?
Hardware: RXB6 (08 version and 2.0)
Robotdyn Mega 2560 Pro Mini
RXB6 connection: 5V, GND, DATA D19, DER16
Nothing is received. I have 433mhz radio controlled sockets with remote control and weather station sensors.
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R48;
10;version;
20;01;VER=1.1;REV=48;BUILD=04;
10;status;
20;02;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
10;version;
10;status;
10;rfdebug=on;
20;03;RFDEBUG=ON;
20;01;User initiated: EEPROM settings reset;
- Stuntteam
The Arduino is responding properly. Meaning that the firmware is loaded correctly.
If you do not receive any data in debug mode then you for sure have issues with the RF signal from the module not ending up where the firmware expects it.
This means either your pinout is not correct or you blew up some stuff..
I ordered another receiver. Flashed Arduino again. Still not working.
Here is my setup:
VCC = 5V
GND = GND
DER = D16
DATA = D19
Result? Nothing.
I am trying to receive signal from:
1, a temperature sensor
2, a wall switch:
https://www.banggood.com/KTNNKG-433MHz- ... 98672.html
Here is my setup:
VCC = 5V
GND = GND
DER = D16
DATA = D19
Result? Nothing.
10;version;
10;status;
10;version;
10;status;
10;version;
10;status;
rfdebug=on;
10;rfdebug=on;
20;03;RFDEBUG=ON;
10;STATUS;
20;04;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
2, a wall switch:
I found the answer.
Receiver - Arduino:
GND = GND
VCC 5V = D16
DATA = D19
and it started working. I don't know why it is not worked with previous connection. Like in:
https://diyprojects.io/gateway-rflink-r ... MiBti-B3EY
Receiver - Arduino:
GND = GND
VCC 5V = D16
DATA = D19
