Nefit Easy: Error: INVALID_RESPONSE [solved]
dewagt
I installed the nefit server
npm i nefit-easy-http-server -g
started it
created the Nefit Easy HTTP server over LAN interface
But when checking:
curl http://127.0.0.1:3000/bridge/ecus/rrc/uiStatus
I got the next messages:
at pending.(anonymous function).send.then.e (/usr/lib/node_modules/nefit-easy-http-server/node_modules/nefit-easy-core/lib/index.js:211:21)
at tryCatcher (/usr/lib/node_modules/nefit-easy-http-server/node_modules/bluebird/js/release/util.js:16:23)
at Promise._settlePromiseFromHandler (/usr/lib/node_modules/nefit-easy-http-server/node_modules/bluebird/js/release/promise.js:510:31)
at Promise._settlePromise (/usr/lib/node_modules/nefit-easy-http-server/node_modules/bluebird/js/release/promise.js:567:18)
at Promise._settlePromise0 (/usr/lib/node_modules/nefit-easy-http-server/node_modules/bluebird/js/release/promise.js:612:10)
at Promise._settlePromises (/usr/lib/node_modules/nefit-easy-http-server/node_modules/bluebird/js/release/promise.js:691:18)
at Async._drainQueue (/usr/lib/node_modules/nefit-easy-http-server/node_modules/bluebird/js/release/async.js:133:16)
at Async._drainQueues (/usr/lib/node_modules/nefit-easy-http-server/node_modules/bluebird/js/release/async.js:143:10)
at Immediate.Async.drainQueues (/usr/lib/node_modules/nefit-easy-http-server/node_modules/bluebird/js/release/async.js:17:14)
at runCallback (timers.js:649:20)
at tryOnImmediate (timers.js:622:5)
I unplugged the nefit easy, (reset) but this didn't work.
In domoticz I got the next messages in the log:
2017-02-09 21:29:38.890 Error: NefitEasy: Invalid data received (main)!
2017-02-09 21:30:09.088 Error: NefitEasy: Invalid data received! (Press)
2017-02-09 21:30:09.285 Error: NefitEasy: Invalid data received! (Gas)
2017-02-09 21:31:09.592 Error: NefitEasy: Invalid data received (main)!
Someone ideas how to solve this?
I have another question. According to Nefit, they don't save anything on their server, only some information about me, and the installation. So if some information is requested it should come from the easy. Some people got the information after resetting the easy, so seems to be right. But don't I need the IP adres of the easy in the settings? Or is that handled by the nefit server?
started it
But when checking:
1x RPi B+
1x RFXcom433e
KAKU: 1x APA3-1500R (3 switches), 4x AMST-606, 1x ASUN-650, 1x AFR-060, 1x AFR-100
ELRO: 4x AB400
ELRO: 4x COCO GDR2-1000R
Wether: 3x Xiron outdoormeters, Alecto 4500, Alecto 1700
Doorbells: 2x action
LG-tv, Yamaha-receiver
1x RFXcom433e
ELRO: 4x AB400
SweetPants
Re: Nefit Easy: Error: INVALID_RESPONSE
Posting your question in two topic's won't speedup the process
Sure you have set your environment variables?
NEFIT_PASSWORD=<password>
NEFIT_ACCESS_KEY=<your access key>
NEFIT_SERIAL_NUMBER=<your nefit serialnumber>
jannl
- Domoticz version: 2025.5.x
And if you start the server through a script, make sure the variables are set in the script, as well as the correct path to the needed binaries
dewagt
I didn't use the environment variables, but a script with:
#!/bin/bash
/usr/bin/easy-server --serial=your-serial --access-key=your-access --password=your-password --host=127.0.0.1 >/dev/null
#!/bin/bash
1x RPi B+
1x RFXcom433e
ELRO: 4x AB400
1x RFXcom433e
ELRO: 4x AB400
dewagt
I saw I had an typo in my password. It didn't change the message on the curl, but the strange thing is, I see now in my domoticz log the next message:
Error: NefitEasy: Error getting http data!
1x RPi B+
1x RFXcom433e
ELRO: 4x AB400
1x RFXcom433e
ELRO: 4x AB400
dewagt
After some trial and error I managed to get more error information.
127.0.0.1 - - [10/Feb/2017:09:11:03 +0000] "GET /bridge/ecus/rrc/uiStatus HTTP/1.1" 500 1597 "-" "Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/602.38 (KHTML, like Gecko) Chrome/55.0.44959.0 Safari/602.37"
Error: Invalid character in statusMessage.
at ServerResponse.writeHead (_http_server.js:195:11)
at ServerResponse.writeHead (/usr/lib/node_modules/nefit-easy-http-server/node_modules/on-headers/index.js:55:19)
at ServerResponse._implicitHeader (_http_server.js:157:8)
at ServerResponse.OutgoingMessage.end (_http_outgoing.js:571:10)
at ServerResponse.send (/usr/lib/node_modules/nefit-easy-http-server/node_modules/express/lib/response.js:205:10)
at app.use (/usr/lib/node_modules/nefit-easy-http-server/lib/cli/server.js:46:18)
at Layer.handle_error (/usr/lib/node_modules/nefit-easy-http-server/node_modules/express/lib/router/layer.js:71:5)
at trim_prefix (/usr/lib/node_modules/nefit-easy-http-server/node_modules/express/lib/router/index.js:310:13)
at /usr/lib/node_modules/nefit-easy-http-server/node_modules/express/lib/router/index.js:280:7
at Function.process_params (/usr/lib/node_modules/nefit-easy-http-server/node_modules/express/lib/router/index.js:330:12)
at Immediate.next (/usr/lib/node_modules/nefit-easy-http-server/node_modules/express/lib/router/index.js:271:10)
at Immediate.<anonymous> (/usr/lib/node_modules/nefit-easy-http-server/node_modules/express/lib/router/index.js:618:15)
at runCallback (timers.js:651:20)
at processImmediate [as _immediateCallback] (timers.js:594:5)
SyntaxError: Unexpected token � in JSON at position 0
at Object.parse (native)
at pending.(anonymous function).send.then.e (/usr/lib/node_modules/nefit-easy-http-server/node_modules/nefit-easy-core/lib/index.js:222:28)
1x RPi B+
1x RFXcom433e
ELRO: 4x AB400
1x RFXcom433e
ELRO: 4x AB400
dewagt
After some trial and error I retyped the complete script. Now it's working. Probably there was some character which can't be seen in the code. Now it's working correctly in domoticz.
The curl still gives a INVALID_RESPONSE. So maybe that's not the correct way to test your connection.
1x RPi B+
1x RFXcom433e
ELRO: 4x AB400
1x RFXcom433e
ELRO: 4x AB400
SweetPants
Re: Nefit Easy: Error: INVALID_RESPONSE [solved]
Nothing wrong with the curl command when i execute it on my system
{"id":"/ecus/rrc/uiStatus","type":"uiUpdate","recordable":0,"writeable":0,"value":{"CTD":"2017-02-10T11:17:35+00:00 Fr","CTR":"room","UMD":"clock","MMT":"20.0","CPM":"auto","CSP":"31","TOR":"off","TOD":"0","TOT":"17.0","TSP":"21.0","IHT":"20.80","IHS":"ok","DAS":"off","TAS":"off","HMD":"off","ARS":"init","FPA":"off","ESI":"off","BAI":"CH","BLE":"false","BBE":"false","BMR":"false","PMR":"false","RS":"off","DHW":"on","HED_EN":"false","HED_DEV":"false","FAH":"false","DOT":"false","HED_DB":""}}
Joost996me
Same problem here...Followed all the steps in https://www.domoticz.com/wiki/NefitEasy
but he pm2 logs remain empty... And also no data in Domoticz
2017-02-12 15:20:03.542 Error: NefitEasy: Error getting http data!
The script nefiteasyhttpserver.sh. No typo's...
#!/bin/bash
/usr/bin/easy-server --serial=xx --access-key=xx --password=xxx --host=127.0.0.1 >/dev/null
help is much appreciated!!!
#!/bin/bash
SweetPants
Assume you did a chmod +x /usr/bin/easy-server and the same for your start-script??Joost996me wrote: #!/bin/bash
Joost996me
Works like a charm here!
Joost996me
Unfortunately no connection again for more than a week now. Nothing changed in the configuration but in the log is see a lot of: Error: NefitEasy: Error getting http data!
Reboots did not solve the problem. Am I the only one with this sudden problem? The easy can be reached with to iPhone app so it doesn't seem a Easy connection problem.
Geitje
I get an http error now and then, but not often.
What version of Debian do you use? Seems the newest version (Buster) has issues with the nefit Easy HTTP server, due to SSL changes. Check here. And then paragraph on "Problems on recent Linux distributions".
Else: can you check the output of the server using the terminal?
curl http://127.0.0.1:3000/bridge/ecus/rrc/uiStatusDomoticz beta, on Raspberry Pi 3B, Raspian Buster
Zwave, Zigate, RFlink etc.
