Raspberry Pi hardware PWM fan control and monitoring
Discuss the Raspberry pi fan control and monitoring with bash script here.
Re: Raspberry Pi hardware PWM fan control and monitoring
Hey, i found your tutorial (at first thanks for that) puttet everything together but there is a problem when i test the script.
i edited the config txt and added
https://jumpnowtek.com/rpi/Using-the-Ra ... imers.html
i updated kernel i think its 5.2 now.
i propably misst something, i would be thankfull for a tip.
thx guys
pi@raspberrypi:~ $ sudo /usr/local/bin/fancontrol.sh
/usr/local/bin/fancontrol.sh: Zeile 38: interval: Kommando nicht gefunden.
sleep: fehlender Operand
„sleep --help“ liefert weitere Informationen.
out of : guide for how to install it: Using the Raspberry Pi hardware PWM timersFor example to get a hardware timer on GPIO_18 (pin 12) on any RPi, add this to config.txt
4.9 kernel
dtoverlay=pwm
thx guys
