cURL inputs
liderbug
cURL inputs
Post by liderbug »
When, from a external script (php/bash/etc) doing a:
curl ... 'http://sg53:8080/json.htm?type=command& ... tchcmd=Off'
allow idx to be replaced with name or hw or id.unit.
Would allow for the command to read param=switchlight&Name=Porch&....
tks
SweetPants
Re: cURL inputs
Post by SweetPants »
lost
Re: cURL inputs
Post by lost »
liderbug wrote: allow idx to be replaced with name
Usually, only IDX are allowed...
http://www.domoticz.com/forum/viewtopic ... 93#p117793
liderbug
Re: cURL inputs
Post by liderbug »
OK, thanks for the response. From your responses I've worked out a soultion:
/domoticz $ MyOnOff Patio On
[MyOnOff]
#!/bin/bash
id=`echo "select id from DeviceStatus where name = '$1';" | sqlite3 domoticz.db `
/usr/bin/curl "http://sg53:8080/json.htm?type=command&param=switchlight&idx=$id&switchcmd=$2"
safi78
Domoticz version: LastBeta
Re: cURL inputs
Post by safi78 »
Nice! I like this :)
Thanks for sharing!
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
