blocky presence for many people Topic is solved
markjgabb
- Domoticz version: 3.8153
hi guys
im trying to do a someone is home blocky which i know is pretty common and has been done alot, but i havent seen on for more than 2 people
so we have 4 people in our house
with a switch for each person
p1
p2
p3
p4
so ive created another dummy called occupied
so i would like a if p1 or p2 or p3 or p4 is home set occupied to on, but i cant seem to get the or's right, it seems to me that you can do that many ors in one sentance or it would be a matter of nested ors and im not sure if that would work
p1
p2
p3
p4
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
RFlink 334 mhz
mysensors
broadlink
jannl
- Domoticz version: 2026.1.x
Re: blocky presence for many people
Not sure if this is common. Most people do presence detection with a python or perl script as found in the wiki.
markjgabb
Yeah I've got the presence detection part working. It's just the last bit.
The if anyone of these switches are on turn this switch on.
I figured that might be easier in blocky
Sent from my SM-G900F using Tapatalk
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
RFlink 334 mhz
mysensors
broadlink
pvm
- Domoticz version: 4.10538
Can you show your current blockly? It shouldn't be a problem. Users (like me) who use geofencing with a virtual switch for every user need this functionality.
You can add an 'or' block to the if and in one of the two 'or' sides put another 'or'. And in the 'else' part use the same construction with 'and' blocks to turn the switch off
- Siewert308SW
- Domoticz version: Stable
indeed pvm
Something like this should work.
if P1 == on and occupied == off then
occupied = on
if P2 == on and occupied == off then
occupied = on
if P3 == on and occupied == off then
occupied = on
if P4 == on and occupied == off then
occupied = on
if P5 == on and occupied == off then
occupied = on
if p1 = off and p2 == off and p3 == off and p4 == off and p5 == off and occupied == on then
occupied = off
occupied = on
occupied = on
occupied = on
occupied = on
occupied = on
occupied = off
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
- DS923+ Docker
mayyam
- Domoticz version: 4.11333
Maybe this one can help You. It's working for me.
viewtopic.php?f=23&t=31&start=100#p27521
I'm checking 4 phones that way (well, 2 phones, but 4 MACs because of AP).
I've 3 blocky:
1 - to check if two MACs of first person are present - presence of first person = on or off
2 - to check if two MACs of second person are present - presence of second person = on or off
3 - to check if two persons are present = presence of two people = on or off
I've 3 blocky:
_______________
- Dell FX-160 / Ubuntu 16.04
- RFLink 433Mhz / NRF 2.4GHz
- 2x Xiaomi Gateway
- different species of ESP8266
- 2x Xiaomi Gateway
markjgabb
sorry for slow reply
this is the current blocky I use below
the occupancy switch just never changes to on
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
RFlink 334 mhz
mysensors
broadlink
pvm
In the else part you use 'on' guess that should be 'off'
I would add an extra check to make sure when presence is on it does not switch on again
markjgabb
wow, i cant believe i missed that......seriously.....how the heck did i miss it had on set there.....works perfectly now, so the aditional check so chuck the entire set of or and one side and put an and box around it?
wow thanks...ive been staring at that for hours and never saw that
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
RFlink 334 mhz
mysensors
broadlink
pvm
If off and (p1 on or p2 on) etc
markjgabb
excelent...seem to be working now
thanks guys...still slapping myself for missing that one
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
RFlink 334 mhz
mysensors
broadlink
