Good morning,
I have since the last two years many things automated with Domoticz.. Its simply beautiful to work with.. I have several X10 inwall switches (i bought them when I started experimenting with Domoticz second hand) but they are pretty loud.. And for the WAF I would like to change them for others.. What are the best inwall switches.. They should be able to switch LED and usable in a (so called in dutch "Hotelschakeling") i already have aRfxcom and Zwave protocols..
Cheers, Hans
What ar the best affordable Inwall switches?
Re: What ar the best affordable Inwall switches?
I am also on the lookout for a simple on off wall light switch - this will control a 5W LED porch light.
jannl
- Domoticz version: 2026.1.x
You could use a zwave inwall switch, not really sure about the sound level when switching.
Basically a 'Hotelschakeling' can be created with zwave switches, since you can control what is switched on/off when operating a switch.
pvm
- Domoticz version: 4.10538
Fibaro switches do not make any sound. I do not know about kaku/coco, much cheaper though
DutchHans
As i mentioned, they should be able to switch Led.. Would be nice if they could be used for tube lights as well.. Several coco can't be used for that.. Another thing is.. As I live in Germany there are no tubes in the walls to pull extra wires through, (the blue cables used for switching) i only have the brown and black ones in the wallswitches
pvm
Fibaro can be used without blue wire. You might need the bypass when using low power (led)
