Im new for domoticz and i dont understant lua
At first i have done notification when system is armed/disarmed, those run just fine.
Problem is this second phase when i am trying to send message if alarm is on and front door is open. (and later i will do same for all doors and motion sensors)
Sensor is Aeotec ZW112, and switch type is set to door lock. (i have tested others also, no help)
Nothing happens after saving this as active. ???
Everything works exept these blocky events.
Help for beginner
AimoPaukku
- Domoticz version: Stable
Help for beginner
- Image2.jpg (21.51 KiB) Viewed 1268 times
Fainted
Re: Help for beginner
Try to do it like this
should work
- 1.jpg (31.88 KiB) Viewed 1239 times
AimoPaukku
I cant see any diffrence tham visual alignment?
I know my problem is in IF, ands second half.
I have tried with motion sensor and door switch, using on/off, open/close, motion/no motion,
NOTHING
Do part is tested and working.
NOTHING
AimoPaukku
Something strange is happening...
I did a full new rasbian and domoticz installations and devices setup. Now i got some of those events work.
Strangely 2 doors work now fine, other 2 dont.
All four are similar sensors, with similar preferences, and similar blocks.
