The bulb is recognized as a Light Switch/Dimmer but I want to be able to set up scenes where I can define both the color and brightness. I have seen in other threads that there is a color picker for some hardware, does anyone know if the ZW098 is compatible and then how do I set it up?
/Chris
Domoticz beginner.
How to control the RGB part of the Aeotec ZW098 LED Bulb?
chrisk8
Re: How to control the RGB part of the Aeotec ZW098 LED Bulb?
After having messed up things, I removed the bulb (device) from the controller (Aeotec USB-stick) and added it again. This time it showed up as a RGBW device thus enabling the color picker in the Switch. Works fine now as I expected.
I suspect that something interfered with the pairing the first time.
- EdddieN
- Domoticz version: 4.9700
when you change the colours from the colour picker, do the changes happen instantly or do you find these can take a fair bit of time?
Just wondering if it is my network or the bulb since I only seem to see slow behaviour with RGB bulbs (Zipato and Aeotec)
Any feedback would be great!
11101101 - www.machinon.com
