Domoboard - General Discussions
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
desertdog
- Domoticz version: 2020.1
Re: Domoboard - General Discussions
sorry. I did, but couldn't find it
jhenrikb
Update post 1 with needed dependencies?
sudo apt-get python-setuptools, Geofence etc. Those questions gets asked over and over, me included
I used a long to figure just which "language" you guys are talking. I barely know anything about linux and the RP.
As for Button and text size, they look the same even if I put in 100 pixels text and just incrase the button.css pixels by 100.
So i'll scratch that idea for now. On computer this is no problem, but on the pad hanging in the hallway, i'm missing big buttons that is easy to hit.
desertdog
Maybe someone can also include how to place the config file and where. I understand the example file, but still no idea of and where to place this on the rasberry. Extensive search of the web hasnt given me the answer.
Snowtiger
- Domoticz version: 4.10915
The config file is in the the Domoboard directory - the same directory as the server.py is in, make a myconf.conf file as a copy of example.conf, fill in the settings part - delete the rest and start building your own config file, using the example.conf as reference materialdesertdog wrote:Maybe someone can also include how to place the config file and where. I understand the example file, but still no idea of and where to place this on the rasberry. Extensive search of the web hasnt given me the answer.
squandor
- Domoticz version: 3.5837
Actually it doesn't matter where to put the config if you give the path after the -c for example if you put the config in the home directory of you're user you can do the following:Snowtiger wrote:The config file is in the the Domoboard directory - the same directory as the server.py is indesertdog wrote:Maybe someone can also include how to place the config file and where. I understand the example file, but still no idea of and where to place this on the rasberry. Extensive search of the web hasnt given me the answer.
sudo python server.py -c /home/pi/test.conf-
Snowtiger
I know but I tried to keep it simplesquandor wrote:Actually it doesn't matter where to put the config if you give the path after the -c for example if you put the config in the home directory of you're user you can do the following:Code: Select all
squandor
Haha wasn't specific for you snow tiger but the phone doesn't always do what I want
anconakip
- Domoticz version: 7722
up and running. But only when i have open my telnet. When i close the telnet link, the webpage isnt reacheable anymore.
squandor
you could fix it by let it running in the background or creating an service.anconakip wrote:up and running. But only when i have open my telnet. When i close the telnet link, the webpage isnt reacheable anymore.
Because we are still developing we have it running under screen so the process will be active when we logout.
anconakip
And how do i do that?squandor wrote:you could fix it by let it running in the background or creating an service.anconakip wrote:up and running. But only when i have open my telnet. When i close the telnet link, the webpage isnt reacheable anymore.
squandor
if you haven't installed screen you can runanconakip wrote:And how do i do that?squandor wrote:you could fix it by let it running in the background or creating an service.anconakip wrote:up and running. But only when i have open my telnet. When i close the telnet link, the webpage isnt reacheable anymore.
sudo apt-get install screenCode: Select all
screenIf you start you're server there you can use the keyboard combination CTRL + A + D and you're screen will disappear in the background.
when you want to get back to you're screen session you can simply type:
screen -d -r-
jhenrikb
Hi Squandor.
Seems the .css editing worked fine, I just noticed Chrome doesnt update design when refreshing the page, but Microsoft edge does.
Now I have huge buttons for scenes, on-off and dimmer slider which is really comfortable when using it on the tablet with the finger.
Do you know where the setpoint style is located? For thermostats.
John
John
squandor
Depends which setpoint the slider or the arrows?jhenrikb wrote:Hi Squandor.
John
The arrows are located in the buttons CSS I think but the slider is an combination of the bootstrap slider and the domoboard js
thenecroscope
Hi, this looks really good! just out of interest is possible to create a dark theme, black background etc...? can i do this by editing the css file? many thanks
wez3
Changing the theme colours is possible by changing the CSS files. Mainly this will be custom.css. If you created some cool theme, feel free to share it.thenecroscope wrote:Hi, this looks really good! just out of interest is possible to create a dark theme, black background etc...? can i do this by editing the css file? many thanks
thenecroscope
Great I will give it a try and report back if I make anything good. Thanks for the help!wez3 wrote:Changing the theme colours is possible by changing the CSS files. Mainly this will be custom.css. If you created some cool theme, feel free to share it.thenecroscope wrote:Hi, this looks really good! just out of interest is possible to create a dark theme, black background etc...? can i do this by editing the css file? many thanks
squandor
Sorry if where are so quiet, at the moment are priority goes to develop an procedure to create, edit and update the config using domoboard itself.
It's difficult to develop an webconfig editor because of the extendability of the config so if anyone has any idea's they are always welcome
pvm
- Domoticz version: 4.10538
Could it be an idea to use xml based configuration and xsd as validation and xsd to document the possible modules and configuration options?
pvm
Awst6000
Unfortunately I'm not a coder. But I hope you guys take the time needed and work something out that works intuitive.squandor wrote:Hi,
...if anyone has any idea's they are always welcome...
