P1 can't open serial port
rhendriks
Domoticz version: Newest
Post by rhendriks »
Since a few updates the P1 port soes not work anymore.
In the logfile :
2016-12-25 13:02:00.676 P1 Smart Meter: Serial Worker stopped...
2016-12-25 13:02:00.677 P1 Smart Meter: Using serial port: /dev/ttyAMA0
2016-12-25 13:02:18.723 Error: Serial Port closed!... Error: End of file
I have used the serial port AMA0.
If I would read out the p1 data in PuTTy this is the output:
root@raspberrypi:~# cu -l /dev/ttyAMA0 -s 9600 --parity=none
cu: open (/dev/ttyAMA0): Permission denied
cu: /dev/ttyAMA0: Line in use
then I did this:
sudo chmod a+rw /dev/ttyAMA0
I see the telegrams from the P1 meter ,but after +/- 1min it did stopped .
what can I do to let it work?
Domoticz V3.5877
bnwgraaf
Re: P1 can't open serial port
Post by bnwgraaf »
Same lroblem for me!
I have a working p1 meter reading on a rpi b+ and I am now setting up a new rpi zero.
All installation went okay (fresh jessie with domoticz}.
I can read with the co.mands mentioned in this post, but the readings stop after a few seconds.
In domoticz I have added the P1, with the right settings, but the devices list stays empty....
Kohen
Post by Kohen »
Same for me.
Running Domoticz on a Synology DS412+ (DSM6)
Running with the latest beta.
I've disconnected the USB reconnected it to another port
Also removed and added it again
nothing....
Synology NAS 412+, Aeotec stick V5, Aeotec recessed door sensor, Aeotec micro double smart switch, Fibaro Dimmer, iPad 2 with own 3d printed wall mount.
bnwgraaf
Post by bnwgraaf »
I have added some line in a srtupfile and now it works perfectly!
sudo nano /etc/rc.local
Add these lines:
sudo systemctl stop [email protected]
sudo systemctl disable [email protected]
Kohen
Post by Kohen »
And how to do that on a synology?
