from time to time my Kodi gets a bit hot, so I would like to see its current temperature (or history) in domoticz. I can see the temperature by typing /opt/vc/bin/vcgencmd measure_temp in the console, but could this be somehow converted into a virtual sensor, or maybe integrated into the existing kodi integration?
Or is it already solved and I missed it?
Kodi raspberry pi internal temperature
- Domoticz version: 3.5877
Raspberry Pi 2 B - MySensors (dimmers, switches, motion, temperature, lux, humidity sensors)
zWave (220v switches)
various 433 via RFLink
- Domoticz version: 4.10538
You can install domoticz on it (as a slave device). Or create a script that parses the output of the command you mention and add it to a virtual sensor in domoticz with a json call
- Egregius
- Domoticz version: v2024.7
Re: Kodi raspberry pi internal temperature
Buy the alu Kodi case. It acts as a heat shield.
Mine runs overclocked at 1350Mhz and doesn't go above 60 degrees Celsius.
Thanks, I manage to google it and make it work somehow
I first made a virtual device that can be updated by calling the domoticz url directly
http://192.168.1.1:8080/json.htm?type=c ... &svalue=20
When I checked that the value is updated, I then used the python script I found on the google (changed it a bit)
(change your IP and your device id)
I saved the script in some "temperaturefordomoticz.py" file, somewhere on pi (I have my in /home/pi/ )
Then I called the script from command line like "python /home/pi/temperaturefordomoticz.py" to make sure that value is being sent to domoticz.
Then I made a cronjob that will send the temperature every 5 min with command
crontab -e
then at the bottom of the file I added
*/5 * * * * python /home/pi/temperaturefordomoticz.py
when you save file, you should see all cron jobs by typing "crontab -l" in command line
(more info on cron here https://debian-administration.org/artic ... _with_cron)
(Also note that Kodi osmc by default doesn't have a crontab installed by default, but can be easily installed either via osmc shop, or googling on how to add cron to raspberry)
I've added this on 3 Pi's I have, and they all work nice, I see them in the domoticz as temperature sensors
Hope someone finds this useful
#!/usr/bin/python
import subprocess
import time
import os
import urllib2
serverIP = "192.168.1.1:8080"
deviceId = 1
currentTemp = subprocess.check_output(["/opt/vc/bin/vcgencmd","measure_temp"])
currentTemp = float(currentTemp.split("=")[1][:-3])
urllib2.urlopen("http://" + serverIP + "/json.htm?type=command¶m=udevice&idx=" + str(deviceId) + "&nvalue=0&svalue=" + str(currentTemp))
crontab -e
- Domoticz version: V2022.2
Here's an alternative approach I came up with, using dzVents on my Domoticz RPi. It uses ssh to send the 'vcgencmd measure_temp' command to the RPi running Kodi (in my case, on Libreelec). sshpass is used, which sends the user id and password in-line with the ssh command (which avoids having to enter the password every time you run ssh, but you may think it is not secure ...).
In my case, the Domoticz temperature device is called 'Kodi CPU'.
Substitute your values for the <brackets> in line 12.
-- This script uses ssh to read the CPU temperature on another RPi
-- and sends the result to Domoticz
timer = { "every minute"}
execute = function(dz)
local base = "sshpass -p <password> ssh <userid>@<url> -o StrictHostKeyChecking=no -o UserKnownHostsFile=/dev/null "
cmd = base .. "'vcgencmd measure_temp'"
local f = io.popen(cmd)
local r = f:read("*a")
f:close()
temp = string.match(r, '%d[%d.,]*')
--print ("Kodi CPU temp: " .. temp)
local kodi_cpu = dz.devices("Kodi CPU")
kodi_cpu.updateTemperature(temp)
