Low cost window/door sensor
b_weijenberg
- Target OS: -
Re: Low cost window/door sensor
If you can use Ext2 firmware enable Lighting4 and X10 and the Kerui sensor will be decoded by the RFXtrx433E as a X10 security sensor.
RFX-433, RFX-433EMC, RFX-868
Hi, my sensor came in today. Tried to learn it AUTOMATIC, but no succes. (clone of a Kerui D026, but also a KR-D026)
Sensor lights when door is closed, opens or the switch on the back goes to 'unmounted' (protection if someone removes the switch)
In RFXmngr with Undec ON and only Lighting 4 ON, I get these messages:
How should I install this sensor? I already installed version 1012 on my RFXcom433E.
- 20161223_161829.jpg (72.86 KiB) Viewed 5453 times
- 20161223_161758.jpg (80.51 KiB) Viewed 5453 times
- Schermafdruk 2016-12-23 16.05.53.png (73.48 KiB) Viewed 5453 times
RFXcom433e ver1009,Raspberry Pi,Domoticz v3.5877
KaKu:16c remote,dimmer,wall-sockets,sunscreenswitch
Promax:wall sockets Elro:wall sockets Somfy:RFY screens
TFA:weather station Chinese temperature sensors, smoke detectors, power switches
Here another pic of the manual of the door-sensor.
- 20161223_171020.jpg (42.04 KiB) Viewed 5446 times
Already got it to work in Domoticz. Was maybe a problem with too may protocols on. Turned almost every protocol off and now it works...
Now finding out what the statusses are for programming the switch in LUA
Problem with the Kerui sensors is: the look the same, but they have different protocols.
Also if you have Rubicson enabled, the most sensors won't respond.
They are working on a fix (new firmware), but it's not perfect yet.
At least, I've got mine working with a lot of support. (thx Bert)
ArieKanarie
Hi Melissen,
Do they send andON signal only, or ON & OFF?
I am looking now for new sensors, but i want them to report ON/OFF
- sincze
- Domoticz version: 2024.4
+1 for this question indeed.ArieKanarie wrote:Hi Melissen,
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
bernardstef
Hi, I can confirm, they send 3 different signals : On, off, and tamper (when dismounted from the door/wall)
Link : https://fr.aliexpress.com/item/High-gra ... 21054.html
ArieKanarie
"Désolé, cet article n'est plus disponible !"
bernardstef
Oh I just see that .... I bought this set 2 weeks ago and received them this week ... from this listing.
Sorry ... But I can confirm they are the same as pictured by Melissen (same insides)
ArieKanarie
jackderuiter
Just ordered these.. now hope they send different open close tamper signal that rflink van decode. They don't have the brand name on it..
@ariekanarie: did You manage to get the other two up and running? You reported that two sensors could not be paired with your system.
ArieKanarie
Yes, finally I succeeded, with help. (disabeling all other protocols was the trick)
But that was not with the sensors from my last post, that was with other doorsensors, which I wanna replace because they only send ON signal.
The ones from my last post should be the same as the ones from Bernardstef.
jackderuiter
Received them very fast. Using IT with rflink but receive continuous other id and unit. Not useable this way. Maybe i should contact rflink team...
ArieKanarie
That is a shame
tontze
- Domoticz version: Beta Ch
Sooo .. they are not working with rflink ?jackderuiter wrote:Received them very fast. Using IT with rflink but receive continuous other id and unit. Not useable this way. Maybe i should contact rflink team...
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
jackderuiter
Not yet. Had a reply from rflink guys but it is not yet working. Should use learning mode but debug log shows IT is not showing correct responses.
ArieKanarie
Any luck yet?
Still looking for some nice door/window sensors with on/off signal..
scottydj2
I also also ordered these.ArieKanarie wrote:psst...
https://nl.aliexpress.com/item/5pcs-lot ... 54563.html
They worked out of the box with RFLink R46 firmware for me:
Unit 0 off for close
Unit 1 on for open
Unit 2 on for tamper alarm.
Commands seem to be sent 3 times each.
Cheers
Scott
jackderuiter
I did not get it up and running with these or at least similar looking sensors. Still gave me different main and unit ids. Rflink progamming command feature did not work for me.
Verstuurd vanaf mijn XT1562 met Tapatalk
