Foscam motion/sound detection using FTP
rfvdboom
Domoticz version: 2023.2
Post by rfvdboom »
i wanted to use the motion/sound detection from my Foscam camera to create a notification. I tried a couple of tutorials, but nothing worked for me. I've found another solution that works for me. Maybe it's not the best solution, but it works!
Foscam can sent images to a FTP server when motion/sound is detected. You can find the settings in your camera. Then I use a PHP script. What does the script do:
1. it will log in on your FTP.
2. it search for files in the path ($logs_dir)
3. when it detect a file, the script will clear the directory and sent a command to a switch in Domoticz. The directory is empty again.
4. The script repeats every 10 seconds
The switch in Domoticz is a Dummy switch (motion sensor). When the switch is on, it sent a notification to PushSafer.
I use Domoticz (and PHP) for only 4 weeks now and i'm not a programmer. If you have any tips to fine tune the script? Let me know.
I hope that the solution works for people with the same problem.
grtz Ralph
<?php
$i = 0;
do {
// set up the settings
$ftp_server = 'ftp.yourserver.nl'; //your ftp server
$ftpuser = 'admin'; //your ftp login
$ftppass = 'admin'; //your ftp pasword
// set up basic connection
$conn_id = ftp_connect($ftp_server);
// login with username and password
$login_result = ftp_login($conn_id, $ftpuser, $ftppass);
$logs_dir = "map1/map2/map3"; //path to directory where Foscam put images
//// Delete all files in the folder logs
ftp_chdir($conn_id, $logs_dir);
$files = ftp_nlist($conn_id, ".");
foreach ($files as $file)
    ftp_delete($conn_id, $file);
    file_get_contents("http://192.168.1.98:8080/json.htm?type=command&param=switchlight&idx=##&switchcmd=On"); //Put the domoticz IDX where the ## is
    echo date('H:i:s')." Sound / motion detected\r\n";
// close the connection
ftp_close($conn_id);
sleep (10); //change the update time here in seconds
} while ($i = -1);
Odroid N2+ | Raspberry P 3 ModelB | RFXcom | AEOTEC Zwave | Honeywell Lyric T6| Milight | Milighthub (NodeMCU) | SolarEdge | P1 Smart meter USB | KAKU | Wemos D1 (esphome) | Denon | Logitech Harmony
safi78
Domoticz version: LastBeta
Re: Foscam motion/sound detection using FTP
Post by safi78 »
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
rfvdboom
Post by rfvdboom »
I dit, but this option didn't work for me.
rfvdboom
Post by rfvdboom »
even better:
Make your pi a FTP server, using this tutorial: https://www.raspberrypi.org/documentati ... ess/ftp.md
and then use this script:
$i = 0;
do {
$files = glob('map1/map2/map3/*'); // get all file names
foreach($files as $file){ // iterate files
  if(is_file($file))
    unlink($file); // delete file
    file_get_contents("http://192.168.1.98:8080/json.htm?type=command&param=switchlight&idx=38&switchcmd=On");
} while ($i = -1);
pushsafer
Domoticz version: 3.5877
Post by pushsafer »
To get a push notification from your ip camera through https://www.pushsafer.com > simple add your pushsafer email address or email alias to the ip cameras alarm / notification panel.
