Switch turns on/off every 15 min.
nedde
I want the switch to turn of after 15 minutes after it is turend on but it keeps
turning on/off every 15 min instead. What's am I doing wrong? Picture Attached.
- 2017-01-11 15_37_08-Domoticz.png (7.59 KiB) Viewed 4278 times
anasazi
Re: Switch turns on/off every 15 min.
Shouldn't you be using "Off AFTER 15" instead of FOR.
- jumbotroll
Try this
If Kaffe = On
Do
Set Kaffe = On For 15 minutes
If Kaffe = On
Do
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- emme
- Domoticz version: latest
I think you cannot do that with blocky....
the script will loop all the time....
try LUA instead:
try LUA instead:
if devicechanged['Kaffe'] and otherdevices['Kaffe'] == 'On' then
commandArray['Kaffe'] = 'On FOR 900' -- the FOR instance works in secs
return commandArrayThe most dangerous phrase in any language is:
"We always done this way"
- Egregius
- Domoticz version: v2024.7
Or pass2php:
<?php
if(apcu_fetch('sKaffe')=='On'&&apcu_fetch('tKaffe')<time-900) sw(apcu_fetch('iKaffe'),'Off');
- StanHD
There is an "Off After X Seconds" block (900 seconds)
Python:- Broadlink RM2, Sonos
nedde
Re: RE: Re: Switch turns on/off every 15 min.
Worked a lot betteranasazi wrote:Shouldn't you be using "Off AFTER 15" instead of FOR.
Sent from my Nexus 6 using Tapatalk
- gielie
- Domoticz version: latest β
I have a question, i have this code.
But when de koffie is Off Domoticz will spam me with messages, i only want to recieve 1 message after the event took place.
How can i do this?
if devicechanged['Koffie'] and otherdevices['Koffie'] == 'On' then
commandArray['Koffie'] = 'On FOR 600' -- the FOR instance works in secs
if devicechanged['Koffie'] and otherdevices['Koffie'] == 'Off' then
commandArray['SendNotification']='Koffie machine is uitgeschakeld'
How can i do this?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
Nautilus
The syntax is bit incorrect, not sure if this is the reason. Try:gielie wrote:I have a question, i have this code.But when de koffie is Off Domoticz will spam me with messages, i only want to recieve 1 message after the event took place.Code: Select all
commandArray = {} if devicechanged['Koffie'] and otherdevices['Koffie'] == 'On' then commandArray['Koffie'] = 'On FOR 600' -- the FOR instance works in secs if devicechanged['Koffie'] and otherdevices['Koffie'] == 'Off' then commandArray['SendNotification']='Koffie machine is uitgeschakeld' end return commandArray
How can i do this?
if devicechanged['Koffie'] == 'On' then
elseif devicechanged['Koffie'] == 'Off' then
Last edited by Nautilus on Tuesday 21 February 2017 12:37, edited 1 time in total.
- emme
could it be that the ON FOR 600 keep the device in the devicechanged table for 600 seconds?!
Nautilus
Not sure about this, but agreed that more logical would be:emme wrote:could it be that the ON FOR 600 keep the device in the devicechanged table for 600 seconds?!
commandArray['Koffie'] = 'Off AFTER 600'
return commandArray- gielie
U guys are great, it works, thanks a lot.
Is there also a way to create a countdown?
- FIBARO FGS223
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
Nautilus
Sure, with a time script (they run once each minute) you can at least have a once per minute count down timer...gielie wrote:Is there also a way to create a countdown?
