I purchased Mega kit and it is working great with my Nexa 101LC smoke detector. I get notification on my mobile immediately if my smoke detector goes off.
I have a set of Cotech remote switches http://www.clasohlson.com/no/Cotech-Sma ... k-/36-6010
I paired switch with the remote first, and then tried to introduce them in the domoticz. When I press button on the remote it appears in the domotics as a Light/Switch, but it doesn't trigger the switch when I click on it.
Also, each time I click on the remote buttons that have On/Off, another switch appears in Domoticz but none of them triggers the switch.
Here are the switches in Domotics.
[Turn Off] 72 RFLink 00A3A7D5 2 Unknown Light/Switch Unitec
[Turn On] 73 RFLink 00AD85BC 6 Unknown Light/Switch Unitec
[Turn On] 74 RFLink 00AF632C 6 Unknown Light/Switch Unitec
[Turn On] 75 RFLink 00A44C8C 6 Unknown Light/Switch Unitec
[Turn On] 76 RFLink 00A8D06C 6 Unknown Light/Switch Unitec
[Turn On] 77 RFLink 00A0EA7C 6 Unknown Light/Switch Unitec
[Turn On] 78 RFLink 00A9C85C 6 Unknown Light/Switch Unitec
[Turn On] 79 RFLink 00A75B1C 6 Unknown Light/Switch Unitec
[Turn On] 80 RFLink 00AAFEAC 6 Unknown Light/Switch Unitec
Is that some "expected" or known behavior, would logs from RFLink Loader help?
RFlink with CoTech (Unitec?) switches
dakipro
- Domoticz version: 3.5877
Raspberry Pi 2 B - MySensors (dimmers, switches, motion, temperature, lux, humidity sensors)
zWave (220v switches)
various 433 via RFLink
- Stuntteam
Re: RFlink with CoTech (Unitec?) switches
Result is expected. You set is not supported at this moment but we are working on it..
dakipro
I am looking forward to it
Since I started making my own home-automation project, I noticed that you are one of the fastest and most "reliable" in responding to support questions.
I thank you for that, keep up the good work
Larsja
- Domoticz version: V2.3530
Have the same cotech kit as you, until its supported by the RFLink I would recommend you this from Nexa: http://www.clasohlson.com/no/Nexa-PE-3- ... re/36-4602
that kit works perfectly
dakipro
Thanks Larsja, only reason I am using Cotech is because I am modifying them internally to work with MySensors project (to have two-way communication), and then I have few of them as leftovers
What is your experience with that nexa kit, do you have misfires sometimes, or does domoticz lose synchronization with the real switch state?
Larsja
Havent noticed any misfires as far as i know ^^ Used one for the aquarium light, turns on at 10.00 and of at 20.00, both status in domoticz and the actuall switch responded as they should. I have just used them in domoticz, havent "linked" them with a normal looking light switch that you can put on the wall.
dakipro
sorry @Stuntteam it took some time before I got to test this, but I can happily confirm that it is working as expected
I have this set of these three and a remote http://www.clasohlson.com/no/Pr366010000/Pr366010000 and they work fine with RFlink.
Althought it is actually the remote that is a "device", meaning that I have two of switches paired in a single group, and domoticz recognizes one device and switches on/off whole group. Which is actually working as I want it to, just that I thought there would be two devices shown.
Thanks for fixing it, marry Christmas to the people celebrating it!
Quart
- Domoticz version: 3.6369
I have a Cotech ip44 receiver. How do I set It up in Domoticz.
What type shall choose when adding it?
