Introducing dzVents - Domoticz Lua file based event scripting made e-z!
gus
Re: Introducing dzVents - Domoticz Lua file based event scripting made e-z!
Post by gus »
Doler wrote:
gus wrote:Hi!
Trying to switch on groups with dzvents but don't get it to work...
Shouldn't this work:
domoticz.groups['Innelampor Basement'].switchOn()
Please advice
/Rickard
You should use
 domoticz.switchGroup('Innelampor Basement', 'On')
(see Domoticz methods)
Well, I tried that as well
but no changes...
Doler
Post by Doler »
gus wrote:
Doler wrote:
gus wrote:Hi!
Please advice
/Rickard
You should use
but no changes...
It works for me. Do you have 'Enable http fetch' set to True in Settings? If so, did you create the group just shortly so the HTTP fetch didn't have time to run (dependent on your interval setting)?
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
gus
Post by gus »
Doler wrote:
gus wrote:
Doler wrote: You should use
but no changes...
Guess, now it works! Dunno what I did?
Thanks for your help!
Doler
Post by Doler »
gus wrote:
but no changes...
Guess time did it (HTTP fetch), glad it works now.
Cheers, Mark
Clemen
Post by Clemen »
Anyway to control/handle a media player device? The device is a Denon Heos speaker, added to domoticz with switch type "Media Player"
Yustmenl
Domoticz version: 3.5997
Post by Yustmenl »
i have implemented DzVents but when i try to write to the log i get the folowing error
Script:
        active = true,
        on = {['timer'] = 'every minute'},
        execute = function(domoticz)
			domoticz.log('test','domoticz.LOG_INFO')
error in log:
2017-01-02 14:56:00.277 LUA: =====================================================
2017-01-02 14:56:00.277 LUA: >>> Handler: test
2017-01-02 14:56:00.277 LUA: .....................................................
2017-01-02 14:56:00.277 LUA: An error occured when calling event handler test
2017-01-02 14:56:00.277 LUA: /home/pi/domoticz/scripts/lua/dzVents/Utils.lua:107: attempt to compare string with number
2017-01-02 14:56:00.277 LUA: <<< Done
2017-01-02 14:56:00.277 LUA: -----------------------------------------------------
any idea on what i am doing wrong?
Rasberry Pi 3; Razberry 2.0; RFXCOM
bloody2k
Post by bloody2k »
Try with following line :)
domoticz.log('test', domoticz.LOG_INFO)
Yustmenl wrote:i have implemented DzVents but when i try to write to the log i get the folowing error
Script:
 active = true,
error in log:
Yustmenl
Post by Yustmenl »
Thanks that works
dannybloe
Post by dannybloe »
bloody2k wrote:Try with following line :)
Indeed, domotiz.LOG_INFO represents a value and that value is what you pass to the log method.
Kalekulan
Post by Kalekulan »
How can you get the state of a group or scene?
And how should you add a group to this:
'Lights inside'
dannybloe
Post by dannybloe »
Kalekulan wrote:How can you get the state of a group or scene?
'Lights inside'
Well, I'd expect that the device that is passed to the execute method is the actual group or scene. So if it has a state you could get to it:
	execute = function(domoticz, myGroup)
		if (myGroup.state == 'On') then
A group or a scene can be triggered in the 'on' section by their ids.
See the documentation for more information and let me know if there are still problems.
Cheers,
Danny
gus
Post by gus »
Hi All,
I having a hard time to update a text device ( "SubType" : "Text")
Command that I use:
domoticz.devices['Text 1'].updateText(test_text)
Error messages:
attempt to index field 'Text 1' (a nil value)
The JSON command that is working:
http://192.168.17.82:8080/json.htm?type=command&param=udevice&idx=143&nvalue=0&svalue=test_text
List of the complete device thru JSON:
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "test text",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 2,
         "HardwareName" : "Domoticz Internal",
         "HardwareType" : "MySensors Gateway USB",
         "HardwareTypeVal" : 41,
         "HaveTimeout" : false,
         "ID" : "00000A08",
         "LastUpdate" : "2017-01-05 22:15:38",
         "Name" : "Text 1",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : false,
         "SignalLevel" : "-",
         "SubType" : "Text",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "text",
         "Unit" : 1,
         "Used" : 0,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "143"
Where do I think wrong??
/Rikard
dannybloe
Post by dannybloe »
gus wrote:Hi All,
Command that I use:
Error messages:
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 2,
         "ID" : "00000A08",
         "Name" : "Text 1",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SubType" : "Text",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "text",
         "Unit" : 1,
         "Used" : 0,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "143"
/Rikard
Interesting... can you try it by it's id? domoticz.devices[143].
gus
Post by gus »
dannybloe wrote:
gus wrote:Hi All,
Command that I use:
Error messages:
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 2,
         "ID" : "00000A08",
         "Name" : "Text 1",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SubType" : "Text",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "text",
         "Unit" : 1,
         "Used" : 0,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "143"
/Rikard
Ok, tried that, still error but now with a "?"...
 attempt to index field '?' (a nil value)
gus
Post by gus »
gus wrote:
dannybloe wrote:
gus wrote:Hi All,
Command that I use:
Error messages:
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 2,
         "ID" : "00000A08",
         "Name" : "Text 1",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SubType" : "Text",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "text",
         "Unit" : 1,
         "Used" : 0,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "143"
/Rikard
Interesting... can you try it by it's id? domoticz.devices[143].[/qdauote]
Found the problem!
I couldn't find 'Text 1' device in devices.lua, so apparently you needed to add the device in "Device" menu for getting devices.lua to be update.
So now it works!
NietGiftig
Domoticz version: V3.6224
Post by NietGiftig »
I have a MiLight remote witch I want to use to regulate some own build light stripes with ESP8266 comm.
(Nice cheap remote with touch-control)
The remote connects with Domoticz via rfLink via USB.
Now I want to intercept the commands from the RFLink MiLight hardware/device
RFLink sends to Domoticz for example:
20;29;MiLightv1;ID=DB48;SWITCH=04;RGBW=5390;CMD=COLOR;
I have checked this with RFLink readout in serial console
I can use RGBW=5390 to translate to #hexcolor. (53 = color 90=Brightness)
I use Fastled witch has a conversion function. ;-)
I created a Milight device in the RFlink hardware witch reacts to the remote.
in devices.lua I have the following info:
         ["AddjMulti"]= 1.0,
         ["AddjMulti2"]= 1.0,
         ["AddjValue"]= 0.0,
         ["AddjValue2"]= 0.0,
         ["BatteryLevel"]= 255,
         ["CustomImage"]= 0,
         ["Data"]= "Off",
         ["Description"]= "",
         ["Favorite"]= 0,
         ["HardwareID"]= 1,
         ["HardwareName"]= "RFLink",
         ["HardwareType"]= "RFLink Gateway USB",
         ["HardwareTypeVal"]= 46,
         ["HaveDimmer"]= true,
         ["HaveGroupCmd"]= false,
         ["HaveTimeout"]= false,
         ["ID"]= "0000DB48",
         ["Image"]= "Light",
         ["IsSubDevice"]= false,
         ["LastUpdate"]= "2017-01-08 11:57:02",
         ["Level"]= 47,
         ["LevelInt"]= 47,
         ["MaxDimLevel"]= 100,
         ["Name"]= "Mi-Light-m",
         ["Notifications"]= "false",
         ["PlanID"]= "0",
         ["PlanIDs"]= { 0 },
         ["Protected"]= false,
         ["ShowNotifications"]= true,
         ["SignalLevel"]= "-",
         ["Status"]= "Off",
         ["StrParam1"]= "",
         ["StrParam2"]= "",
         ["SubType"]= "RGBW",
         ["SwitchType"]= "Dimmer",
         ["SwitchTypeVal"]= 7,
         ["Timers"]= "false",
         ["Type"]= "Lighting Limitless/Applamp",
         ["TypeImg"]= "dimmer",
         ["Unit"]= 0,
         ["Used"]= 1,
         ["UsedByCamera"]= false,
         ["XOffset"]= "0",
         ["YOffset"]= "0",
         ["idx"]= "149"
I have tried the most obvious attributes but i get no data at all
I use this script for trying, it only prints 'test
   local idxn = 149
	active = true,           -- set to true to activate this script
		idxn,                 -- Mi-light remote
	  print('test')
	  print(domoticz.devices[idxn].Name)
	  print(domoticz.devices[idxn].LevelInt)
	  print(domoticz.devices[idxn].rawData[0])
	  print(domoticz.devices[idxn].rawData[1])
I'm not sure if this is the way to go.
Someone who can enlighten me?
RPI-2 + SSD / ESPEasy Sensors & Switches / Sonoff / RFLink / Action Switches / TP-Link switch / Node-Red / Reacticz
dannybloe
Post by dannybloe »
NietGiftig wrote:I have a MiLight remote witch I want to use to regulate some own build light stripes with ESP8266 comm.
         ["AddjMulti"]= 1.0,
         ["AddjValue"]= 0.0,
         ["CustomImage"]= 0,
         ["Data"]= "Off",
         ["Favorite"]= 0,
         ["HardwareID"]= 1,
         ["ID"]= "0000DB48",
         ["Image"]= "Light",
         ["Level"]= 47,
         ["LevelInt"]= 47,
         ["PlanID"]= "0",
         ["PlanIDs"]= { 0 },
         ["Status"]= "Off",
         ["StrParam1"]= "",
         ["StrParam2"]= "",
         ["Unit"]= 0,
         ["Used"]= 1,
         ["XOffset"]= "0",
         ["YOffset"]= "0",
         ["idx"]= "149"
   local idxn = 149
	  print('test')
First of all, it is device[].name (lower-case). Second, dzVents does a mapping to sane naming when it processes the devices.lua file. It is not the case that all attributes in that file end up in the device object api (at least not one-on-one). So, that said, you can try to do domoticz.logDevice(domoticz.devices[idxn]). It should log all the device values to the domoticz log. (Note that domoticz sometimes swallows log messages so you may have to run it several times to see all the attributes in the log).
dannybloe
Post by dannybloe »
Hi folks, I am closing this topic because it is almost becoming it's own internal forum. Please use the forum Software > dzVents Lua Framework for new topics. That makes it more manageable.
Thanks for using dzVents and happy new year. Let's hope some day gizmocus or someone else with c++ skills finally finds the time to help integrate it into Domoticz.
Locked
