RFLink and Venetian Blinds
433Mhz opensource Receiver & Transmitter.
Twinsen
Post by Twinsen »
After the last updates the STOP command for Venetian blinds is not working.
I have the Domoticz v. 3.6231 and RFLink v. 45
For UP and DOWN commands everything is working perfect.
Please help me to solve this issue.
2016-12-24 09:55:19.688 User: lgr initiated a switch command (7/Stanga/Stop)
2016-12-24 09:55:19.689 Error: RFLink: trying to send unknown switch command: 17
2016-12-24 09:55:46.101 User: lgr initiated a switch command (7/Stanga/On)
2016-12-24 09:55:46.103 RFLink Sending: 10;BrelMotor;b808be;a1;DOWN
2016-12-24 09:55:47.210 (RFLink) Light/Switch (Stanga)
2016-12-24 09:55:49.170 User: lgr initiated a switch command (7/Stanga/Off)
2016-12-24 09:55:49.171 RFLink Sending: 10;BrelMotor;b808be;a1;UP
2016-12-24 09:55:50.315 (RFLink) Light/Switch (Stanga)
Twinsen
Re: RFLink and Venetian Blinds
Post by Twinsen »
I think that, the problem is generated in the last stable release...
How can be solved this issue ?
Twinsen
Post by Twinsen »
Please, can someone help me ?
Stuntteam
Post by Stuntteam »
We will take a look asap.
Twinsen
Post by Twinsen »
Thank you for your answer.
I asked in general section and they told me that everything is ok and command is created correctly.
Twinsen
Post by Twinsen »
Can you help me with an update?
Stuntteam
Post by Stuntteam »
In some cases there was indeed something that did not work as planned.
A fix has been comitted..
Should be available in the next beta.
Twinsen
Post by Twinsen »
Thank you for your time and disponibility.
I will wait for next beta release to test it.
Twinsen
Post by Twinsen »
Everything is OK now
Thanks.
jordantheripper
Domoticz version: 3.9208
Post by jordantheripper »
I there.
Can you please tell me the way you solved the problem?
I'm searching for solution fom my venetian blinds.
Thanks so much
