Somfy telis 4 RTS
433Mhz opensource Receiver & Transmitter.
Willem81
Re: Somfy telis 4 RTS
Post by Willem81 »
Unfortunately I have exactly the same issue as piokuc.
Using firmware 42 :(
balans
Domoticz version: stable
Post by balans »
I`m also stuck using firm 42 and a telis1
Willem81
Post by Willem81 »
@stuntteam, It would be great if you can solve this in some way :) I think many people will be happy
passie
Post by passie »
I received my 2 rflink boards last week.
After some struggling with my somfy device I was able to got it working.
This is what i did.
10;RTSSHOW;
RTS Record: 0 Address: FFFFFF RC: FFFF
RTS Record: 1 Address: FFFFFF RC: FFFF
RTS Record: 2 Address: FFFFFF RC: FFFF
RTS Record: 3 Address: FFFFFF RC: FFFF
RTS Record: 4 Address: FFFFFF RC: FFFF
RTS Record: 5 Address: FFFFFF RC: FFFF
RTS Record: 6 Address: FFFFFF RC: FFFF
RTS Record: 7 Address: FFFFFF RC: FFFF
RTS Record: 8 Address: FFFFFF RC: FFFF
RTS Record: 9 Address: FFFFFF RC: FFFF
RTS Record: 10 Address: FFFFFF RC: FFFF
RTS Record: 11 Address: FFFFFF RC: FFFF
RTS Record: 12 Address: FFFFFF RC: FFFF
RTS Record: 13 Address: FFFFFF RC: FFFF
RTS Record: 14 Address: FFFFFF RC: FFFF
RTS Record: 15 Address: FFFFFF RC: FFFF
Press the Learn button on the remote
Enter the following code within 3 seconds. Your blinds will go up and down shortly
10;RTS;02FFFF;0412;3;PAIR;
Your blinds will go up and down again. This means your Rflink is now paired with your RTS motor.
To check this enter the following code again and see if there is a record,
10;RTSSHOW;
RTS Record: 3 Address: 02FFFF RC: 0018
For the rest you can use the manual which is available for Domoticz.
Since I didn't received my antennas yet I have put a coper wire on the Rflink. The distance to the RTS motor is about 2 meters. So keep this in mind when trying to pair. (without antennas)
If pairing isn't working try to move closer to your Somfy device.
Hope this helps others having trouble with there Rflink / Somfy
regards,
passie
Willem81
Post by Willem81 »
Thanks man :) Finally I am able to control the blinds !
10;RTS;0100F2;0;DOWN;
10;RTS;0100F2;0;UP;
10;RTS;0100F2;0;STOP;
All work!
Now I am going to check how to get them to work with Domoticz
Thanks again!!
passie
Post by passie »
Willem81 wrote:Thanks man :) Finally I am able to control the blinds !
10;RTS;0100F2;0;UP;
All work!
Thanks again!!
that's how a new year should start , glad it helped you :)
piokuc
Post by piokuc »
For me still not working. Blinds work after send command for about 3-4 secunds and stop. And must again send command.
I send command:
10;RTS;0F0F0F;3;DOWN;
10;RTS;0F0F0F;3;UP;
10;RTS;0F0F0F;3;STOP;
and 10;RTSSHOW
10;RTSSHOW
RTS Record: 0 Address: C14762 RC: 0440
RTS Record: 1 Address: 828EC2 RC: 0D78
RTS Record: 2 Address: C14761 RC: 06D6
RTS Record: 3 Address: 0F0F0F RC: 0424
RTS Record: 4 Address: 51D840 RC: 9BB1
RTS Record: 5 Address: 828E5B RC: 0DAE
RTS Record: 6 Address: 000000 RC: 0001
RTS Record: 7 Address: 000000 RC: 0000
RTS Record: 8 Address: 000000 RC: 0000
RTS Record: 9 Address: 000000 RC: 0000
RTS Record: 10 Address: 000000 RC: 0000
RTS Record: 11 Address: 000000 RC: 0000
RTS Record: 12 Address: 000000 RC: 0000
RTS Record: 13 Address: 000000 RC: 0000
RTS Record: 14 Address: 000000 RC: 0000
RTS Record: 15 Address: 000000 RC: 0000
Stuntteam
Post by Stuntteam »
In case of the 3-4 second response, did you try the R45 with option:
10;RTSLONGTX;
piokuc
Post by piokuc »
I have FW R45 but option with Longtx not try.
piokuc
Post by piokuc »
How i can use command RTSLONGTX ?
marcusnl
Domoticz version: v3.7367
Post by marcusnl »
Has anyone actually got this to work with Domoticz? And how?
I followed the instructions and paired it. When I have the RFLink connected to my laptop I can send the codes like 10;RTS;02FFFF;3;DOWN; and UP and STOP and ON and OFF and they work and my screen reacts as expected.
10;RTS;02FFFF;3;STOP;
20;1D;OK;
10;RTS;02FFFF;3;UP;
20;1E;OK;
20;1F;OK;
When connected to Domoticz I manually create a Venetian blinds switch EU with the RFY type and ID 20 FF FF. Since the unit code starts with 1 instead of 0 I use 4 and not three but I have tried both. I've just updated to the latest beta v3.7367 but until this morning I tried with the latest stable. My RFLink firmware is 46 and i have a Telis 1 RTS
The log says everything is ok but my screen doesn't move.
2017-04-18 20:53:55.002 User: Domousr initiated a switch command (61/RC1/On)
2017-04-18 20:53:55.003 RFLink Sending: 10;RTS;02ffff;3;ON
2017-04-18 20:53:58.325 RFLink: 20;26;OK;
2017-04-18 20:53:58.325 (RF-Link) Light/Switch (Unknown)
2017-04-18 20:54:21.858 User: Domousr initiated a switch command (61/RC1/Off)
2017-04-18 20:54:21.859 RFLink Sending: 10;RTS;02ffff;3;OFF
2017-04-18 20:54:25.212 RFLink: 20;27;OK;
2017-04-18 20:54:25.212 RFLink: 20;28;PONG;
2017-04-18 20:54:25.212 (RF-Link) Light/Switch (Unknown)
2017-04-18 20:55:14.879 RFLink: 20;29;PONG;
2017-04-18 20:55:49.473 EventSystem: reset all device statuses...
2017-04-18 20:55:53.555 User: Domousr initiated a switch command (62/RC2/On)
2017-04-18 20:55:53.556 RFLink Sending: 10;RTS;02ffff;4;ON
2017-04-18 20:55:56.797 RFLink: 20;2A;OK;
2017-04-18 20:55:56.797 (RF-Link) Light/Switch (Unknown)
2017-04-18 20:55:58.287 RFLink: 20;2B;AB400D;ID=60;SWITCH=1;CMD=ON;
2017-04-18 20:55:58.288 (RF-Link) Light/Switch (Unknown)
2017-04-18 20:56:16.232 User: Domousr initiated a switch command (62/RC2/Off)
2017-04-18 20:56:16.233 RFLink Sending: 10;RTS;02ffff;4;OFF
2017-04-18 20:56:19.560 RFLink: 20;2C;OK;
2017-04-18 20:56:19.561 (RF-Link) Light/Switch (Unknown)
I've tried RTSLONGTX but all I get is timeouts. What am I missing?
Stuntteam
Post by Stuntteam »
Do not create the switch using the RFY type.. use the "create rflink device" button on the hardware tab.
marcusnl
Post by marcusnl »
Just tried that and then created a switch and changed the type to Venetian blinds EU. No luck while the log shows the correct command.
2017-04-19 07:05:27.701 User: Domousr initiated a RFLink Device Create command: 20;08;RTS;ID=02FFFF;SWITCH=03;CMD=DOWN;
2017-04-19 07:05:27.810 (RF-Link) Light/Switch (Unknown)
2017-04-19 07:06:59.207 User: Domousr initiated a RFLink Device Create command: 20;08;RTS;ID=02FFFF;SWITCH=04;CMD=DOWN;
2017-04-19 07:06:59.327 (RF-Link) Light/Switch (Unknown)
2017-04-19 07:07:58.106 User: Domousr initiated a switch command (63/RC 1/Off)
2017-04-19 07:07:58.107 RFLink Sending: 10;RTS;02ffff;4;UP
2017-04-19 07:08:01.379 (RF-Link) Light/Switch (RC 1)
2017-04-19 07:08:01.627 User: Domousr initiated a switch command (50/RC 2/Off)
2017-04-19 07:08:01.628 RFLink Sending: 10;RTS;02ffff;3;UP
2017-04-19 07:08:04.955 (RF-Link) Light/Switch (RC 2)
2017-04-19 07:08:10.529 User: Domousr initiated a switch command (63/RC 1/On)
2017-04-19 07:08:10.531 RFLink Sending: 10;RTS;02ffff;4;DOWN
2017-04-19 07:08:13.791 (RF-Link) Light/Switch (RC 1)
2017-04-19 07:08:18.704 (Weather_underground) Temp + Humidity + Baro (Temp - Humid - Baro)
2017-04-19 07:08:18.710 (Weather_underground) Wind (Wind)
2017-04-19 07:08:18.714 (Weather_underground) Rain (Rain)
2017-04-19 07:08:18.718 (Weather_underground) General/Visibility (Visibility)
2017-04-19 07:08:18.722 (Weather_underground) General/Solar Radiation (Solar radiation)
2017-04-19 07:08:21.289 User: Domousr initiated a switch command (50/RC 2/On)
2017-04-19 07:08:21.291 RFLink Sending: 10;RTS;02ffff;3;DOWN
2017-04-19 07:08:24.590 (RF-Link) Light/Switch (RC 2)
morilm
Target OS: OS X
Post by morilm »
You need to use number 3 as the remote
Domoticz only has 1 to 16... so if you pair to number 3, use also 3 while sending the command.
If not, clear all the entries (r just number 3) and start again using another ID an code
domogijs
Post by domogijs »
I experience a problem with this process (using 433,92).
Pairing goes fine. And the new adres is shown in the list.
If I give the up, down, stop command in de rflink interface a ok is shown. But nothing happens...
What am I doing wrong?
Greets Gijs
Raspberry Pi3, RFlink, PiZigate, Yeelight, klikaanklikuit, Kodi, harmony hub, Zwave, ThermoSmart, XiaomiGateway (Aqara), Google home hub, roomba,
jiemeb
Post by jiemeb »
marcusnl wrote: Tuesday 18 April 2017 21:00 Has anyone actually got this to work with Domoticz? And how?
20;1D;OK;
10;RTS;02FFFF;3;UP;
20;1E;OK;
20;1F;OK;
I had the sale problem. the first version of domoticz in 2014 was working fine.
To have the log and the state of the shutters it is necessary to modify the recording of the key in the database.
for example using sqlitebrowser.
stop the domoticz service and make a copy of the domoticz.db database
then launch sqlitebroswer.
open the domoticz.db database and modify the DeviceStatus table.
add in front of the deviceID data of your Zero 2 pane.
example DeviceID = 123456 becomes 00123456.
Save the changes and exit sqlitebrowser.
restart domoticz and now the state and log work
mf76130
Post by mf76130 »
thanks a lot, i added my somfy motor very easy due to your findings!!
rechsoz
Post by rechsoz »
Please help me,
Pairing - or at least controlling after that - does not work
tried 2 remotes
tried turning on / off lots of times
tried little reset in the back and up+down to reset
tried longtx
just wont work
what can I do to make it work? (anyone from germany/bavaria or berlin around?)
all the best,
Rene
please find my pastebin here...last session of trying. https://pastebin.com/ZLEbrkqi
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R48;
10;version;
20;01;VER=1.1;REV=48;BUILD=04;
10;status;
20;02;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
10;RTSSHOW;
RTS Record: 0 Address: 185401 RC: 0AC6
RTS Record: 1 Address: 0100F2 RC: 0006
RTS Record: 2 Address: F2D7CE RC: 0171
RTS Record: 3 Address: 0F0F0F RC: 042A
RTS Record: 4 Address: 175401 RC: 0B0E
RTS Record: 5 Address: 1A5401 RC: 095A
RTS Record: 6 Address: 0FBB69 RC: 02A6
RTSLONGTX=ON10;RTSSHOW;
20;04;RTS;ID=f2d7ce;SWITCH=01;CMD=UP;
20;05;Debug;RTS P1;aa200171f2d7ce;
20;06;RTS;ID=f2d7ce;SWITCH=01;CMD=UP;
20;07;Debug;RTS P1;ab440172f2d7ce;
20;08;RTS;ID=f2d7ce;SWITCH=01;CMD=DOWN;
20;09;Debug;RTS P1;ab440172f2d7ce;
20;0A;RTS;ID=f2d7ce;SWITCH=01;CMD=DOWN;
20;0B;Debug;RTS P1;ab440172f2d7ce;
20;0C;RTS;ID=f2d7ce;SWITCH=01;CMD=DOWN;
20;0D;Debug;RTS P1;ab440172f2d7ce;
20;0E;RTS;ID=f2d7ce;SWITCH=01;CMD=DOWN;
20;0F;Debug;RTS P1;ac240173f2d7ce;
20;10;RTS;ID=f2d7ce;SWITCH=01;CMD=UP;
20;11;Debug;RTS P1;ac240173f2d7ce;
20;12;RTS;ID=f2d7ce;SWITCH=01;CMD=UP;
20;13;OK;
20;14;Debug;RTS P1;ae200175f2d7ce;
20;15;RTS;ID=f2d7ce;SWITCH=01;CMD=UP;
20;16;Debug;RTS P1;ae200175f2d7ce;
20;17;RTS;ID=f2d7ce;SWITCH=01;CMD=UP;
20;18;Debug;RTS P1;ae200175f2d7ce;
20;19;RTS;ID=f2d7ce;SWITCH=01;CMD=UP;
20;1A;Debug;RTS P1;af440176f2d7ce;
20;1B;RTS;ID=f2d7ce;SWITCH=01;CMD=DOWN;
20;1C;Debug;RTS P1;a0680177f2d7ce;
20;1D;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;1E;Debug;RTS P1;a0680177f2d7ce;
20;1F;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;20;Debug;RTS P1;a0680177f2d7ce;
20;21;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;22;Debug;RTS P1;a0680177f2d7ce;
20;23;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;24;Debug;RTS P1;a0680177f2d7ce;
20;25;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;26;Debug;RTS P1;a0680177f2d7ce;
20;27;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;28;Debug;RTS P1;a0680177f2d7ce;
20;29;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;2A;Debug;RTS P1;a0680177f2d7ce;
20;2B;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;2C;Debug;RTS P1;a0680177f2d7ce;
20;2D;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;2E;OK;
20;2F;Debug;RTS P1;a1660178f2d7ce;
20;30;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;31;Debug;RTS P1;a1660178f2d7ce;
20;32;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;33;Debug;RTS P1;a1660178f2d7ce;
20;34;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;35;Debug;RTS P1;a1660178f2d7ce;
20;36;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;37;Debug;RTS P1;a1660178f2d7ce;
20;38;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;39;Debug;RTS P1;a1660178f2d7ce;
20;3A;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;3B;Debug;RTS P1;a1660178f2d7ce;
20;3C;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;3D;Debug;RTS P1;a1660178f2d7ce;
20;3E;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;3F;Debug;RTS P1;a1660178f2d7ce;
20;40;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;41;Debug;RTS P1;a1660178f2d7ce;
20;42;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;43;Debug;RTS P1;a1660178f2d7ce;
20;44;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;45;Debug;RTS P1;a1660178f2d7ce;
20;46;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;47;Debug;RTS P1;a1660178f2d7ce;
20;48;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;49;Debug;RTS P1;a1660178f2d7ce;
20;4A;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;4B;OK;
20;4C;OK;
10;RTS;02FFFF;0412;3;DOWN;
20;4D;OK;
10;RTS;02FFFF;3;DOWN;                                                             /////DID All not WORK
20;4E;OK;
SWITCH=01;CMD=STOP;
20;81;Debug;RTS P1;a766017ef2d7ce;
20;82;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;83;Debug;RTS P1;a766017ef2d7ce;
20;84;RTS;ID=f2d7ce;SWITCH=01;CMD=STOP;
20;85;OK;
10;RTS;02FFFF;0412;3;UP;
10;RTS;02FFFF;0412;3;UP;  // wont work
secator
Domoticz version: 4.9701
Post by secator »
hello rechsoz,
how do you pair your roller shutter exactly?
1 Press the Learn button on the remote (Your roller shutter will go up and down)
2 Enter the following code within 3 seconds (10;RTS;02FFFF;0412;3;PAIR; Your roller shutter will go up and down shortly if your Rflink is really paired with your RTS motor)
rechsoz
Post by rechsoz »
Hi, thank you so much for anwering.
on my telis remote there is a little button at the back. Pressing for 3 sec doesnt do anything.
If I press up and down on the fron simultaneously, it does go up and down.
then I entered the code in RFLINK (I tried different variations, and it does safe them, as soon as I can understand - see my log).
But it does not go up/down when entering the code. it just takes a few seconds and then says
10;RTS;02FFFF;0412;3;PAIR; //1st try
20;13;OK;
nothing happens. Does not accept up and down command.
what can I do?
