Rfxcom lost transmission power
DutchHans
Good evening..
All of a sudden my transceiver seem to have lost power.. Previously it reached all adapters, plugs and valves around the house... Then suddenly it can't reach half of the amount... I thought a plug died.. But it concerned also pirs and dimmers.. Anyone had this before?..
I've updated to the latest firmware of the rfxtrx.. Also updated domoticz till the latest beta...
Can it be that the sd card is damaged?...
All tips are welcome..
Regards, Hans
Regards, Hans
SweetPants
Re: Rfxcom lost transmission power
Are you sure there is no device with low-battery? Some tend to transmit continously when low on battery, screwing up the RfxCom receiver. Especially PIR's behave like this.
DutchHans
Thank you, i will check
DutchHans
Changed batteries in two (most active) pirs.. No changes..
DutchHans
Checked some other pirs..you might have a point.. I can't check today anymore... I will give it a try tomorrow...
- Egregius
- Domoticz version: v2024.7
Actually basic knowledge about the 433 stuff that they spit continously when battery is low. If you had searched the forum or Googled you could have found that faster than your bump after less than 2 hours
SweetPants
and????DutchHans wrote:Checked some other pirs..you might have a point.. I can't check today anymore... I will give it a try tomorrow...
OneOhEd
- Domoticz version: latest
I seem to be suffering from the same issue. Been working fine for years but suddenly my RFXcom isn't properly receiving sensors (PIR, door contacts, etc). Tried updating RFXcom (Ext2 firmware 1012) but now it receives ALMOST nothing... (no PIR, contacts, etc and most switches).
Very frustrated - been replacing batteries too... no luck
b_weijenberg
- Target OS: -
See chapter 15.1 in the RFXtrx User Guide
RFX-433, RFX-433EMC, RFX-868
- Bernd
- Domoticz version: 2023.1
I found out, with a little scanner on 433,92 MHz, that sensors start to generate a continuous RF signal when their battery is getting low, blocking the RFXCOM signal in their neighbourhood. Make sure that all sensors have proper working batteries!!!
Raspberry Pi 4 2GB (RPi OS Light)
RFXCOM RFXtrx433E, firmware version = 1025
Hi i had brakedown on my secont rfxcom433e after lightenibg storm eaven if det storm was not too near seems like det receiver damaged it sends comands ok any see this problem
b_weijenberg
- Target OS: -
Transmit power is OK.sbjbjoer wrote:Hi i had brakedown on my secont rfxcom433e after lightenibg storm eaven if det storm was not too near seems like det receiver damaged it sends comands ok any see this problem
It is possible that the receiver is damaged by a lightning pulse.
Please check the RFXtrx on another location >500 meters away from the current location and check with RFXmngr on a laptop if you receive a sensor with a normal range.
If the RFXtrx is defect contact support rfxcom.com for a possible repair.
Jamboman
I can confirm Bent’ experience. A faulty KAKU motion detector (possibly on weak batteries) blocked several KAKU receivers nearby from responding to ON /OFF signals. When I removed the batteries all of a sudden the issues were over.
