giangi wrote:Tnx !!!
Now it works
I also tried to interact with the physical controls and an app that talks directly with the gateway.
It works
which app you're using?
giangi wrote:I only see a few problems with the update status of devices
For example: if I turn off a light with the wall control (physical) in domoticz not always updating ...
Instead the app is immediate
I would understand if a refresh state maybe time (eg 1 minute) you need to enter even with a dummy device.
ideas ?
I did some tests with the LN4890 device.
The built-in domoticz OpenWebNet driver immediately receives the update of the new state controlled via physical control.
You can view this through the log page domoticz.
When this happens, the driver sends a notification to the system that should display the change.
I can not say why but I see about 7-8 seconds between the state receiving, and viewing on the graphical interface.
However I can tell you that I can always see the correct device status update
giangi wrote:another bug: Blinds turning on = close - turning off= open.
This is not a bug.
The graphical interface of domoticz, when you're using a device blind (3 buttons, venetian blind eu) automatically sends:
- OFF, when you click on the icon opening
- STOP when you click on the icon of stopping
- ON, when you click the close icon
I do not think I can change this behavior, however this works well in my system and blinds are controlled properly.
