hi,
in my house i have this configuration:
- SP room sensor A ( need command 2 SP Valve)
- SP room sensor B ( need command 2 SP Valve)
- SP room sensor C ( need command 3 SP Valve)
iam newbe, i need with LUA script every times change the SP room sensor A, change the value SP to 2 valve. with this metod i can schedulate only 3 device instead 7. i have another problem. i think must use a variables.
example SP room sensor A changed from 16 to 18
the SP of valve A must changed from 16 to 18
the SP of valve B must changed from 16.5 to 18.5 (the gap is alway +0.5 because the radiators is more high and the termostatic valve is at 1.8mt instead 1.10)
someone can help me ?
LUA copy SP from termostat to SP valve
guantolento
- Domoticz version: LastBeta
Master (pi3) - MB sensors + Dummy + Sysfs gpio + 1 NodOn MSP-3 + 1 Aeotec DSB28 Energy Meter + 3 Danfoss RS Room + 7 Danfoss Z Thermostat + 1 Swiid Inter + 9 FGS222
Slave01 (pi2) - MB sensors + Dummy + Weather Underground + 2 FGS223 + 1 FGWPE/F
guantolento
Re: LUA copy SP from termostat to SP valve
i take some test for modify a set point with a test script:
but the 2 setpoint don't work . why ?
if devicechanged['Cucina Pensili - S1'] then
if (otherdevices['Cucina Pensili - S1'] == 'On') then
commandArray['SetSetpoint:82']='22'
commandArray['SetSetpoint:23']='22'
commandArray['Cameretta Comò - S1'] = 'On'
elseif (otherdevices['Cucina Pensili - S1'] == 'Off') then
commandArray['SetSetpoint:82']='16'
commandArray['SetSetpoint:23']='16'
commandArray['Cameretta Comò - S1'] = 'Off'
return commandArrayMaster (pi3) - MB sensors + Dummy + Sysfs gpio + 1 NodOn MSP-3 + 1 Aeotec DSB28 Energy Meter + 3 Danfoss RS Room + 7 Danfoss Z Thermostat + 1 Swiid Inter + 9 FGS222
- Egregius
- Domoticz version: v2024.7
There's a function for this in my pass2php script.
Check the __verwarming.php file on my Github.
I set my valves x degrees lower/higher depending on the difference between room temperature and room setpoint.
guantolento
hi egregius,
but your script is in php not in lua, i understand ok ?
guantolento
Sigh i don't know this language. ....
Inviato dal mio GT-I9301I utilizzando Tapatalk
guantolento
Hi at all,
actually i use this LUA script to copy the value of SP Camere (Virtual SP beacuse the fisic SP Danfoss Room don't work) to 2 fisic SP Valves Danfoss.
the first valve has the same SP, the second has SP + 1.5. i use this from 1 week and work ok.
sp2Name = 'SP Camere' --nome del set point virtuale zona camere
spR3 = 25 --nome valvola fisica 3
spR4 = 30 --nome valvola fisica 4
T2 = otherdevices[sp2Name] --lettura temperatura set point virtuale zona camere
VT2 = tonumber(otherdevices['SP Camere']) --valore del set point virtuale zona camere
pfx = '>>> [Temperatura] >>>' --prefisso log Temperatura
if devicechanged[sp2Name] then
commandArray[#commandArray + 1] = {['UpdateDevice']=spR3..'|0|'..tostring(T2)}
commandArray[#commandArray + 1] = {['UpdateDevice']=spR4..'|0|'..tostring(tonumber(T2)+1.5)}
print (pfx..' SetPoint Modificato / Valore Attuale '..sp2Name..' : '..VT2..'')
