SNMP monitoring Synology NAS
Lichtschilder
Post by Lichtschilder »
hi all,
as a new user of Domoticz i thought it would be nice to integrate monitoring my NAS in Domoticz.
have found the Wiki page: http://www.domoticz.com/wiki/NAS_Monitoring#Synology
when following this method i get some results but can't seem to be able to get a few meters working.
anyone here who has any tips?
tried to search first but haven't found a tip yet.
currently running:
domoticz: Version: 3.4834
Synology DSM 6.0.2
have tried both changeing the .36 to .38 in the script.. didn't work yet?
working:
on/of switch
temperature 1 and temperature 2
CPU status
not working:
disk counter
disk %
ramp%
any one with a suggestion? help would be appriciated by this newbie :)
huizi036
Re: SNMP monitoring Synology NAS
Post by huizi036 »
curl -s -i -H "Accept: application/json" "http://192.168.1.248:8080/json.htm?type ... e=$HDtemp1"
when i enter this command i receive ERR please can somebody advise
Version: 3.5877
"status" : "ERR"
Martijn85
Domoticz version: Stable
Post by Martijn85 »
I have this working with two synology systems: DS110j (DSM 5.x) and DS214+ (DSM 5.x)
This is my complete script for the DS110j (one harddisk):
#!/bin/bash
# Settings
NASIP="x.x.x.x"            # NAS IP Address
COMMUNITY="public"              # SNMP Community
DOMO_IP="x.x.x.x"          # Domoticz IP Address
DOMO_PORT="8080"                # Domoticz Port
DOMO_LOGIN=""                   # Domoticz Username
DOMO_PASS=""                    # Domoticz Password
DOMO_PASSCODE="xxxx"        # Domoticz Light/Switch Protection
NAS_IDX="x"                    # NAS Switch IDX
NAS_HD1_TEMP_IDX="x"           # NAS HD1 Temp IDX
NAS_HD_SPACE_PERC_IDX="x"      # NAS HD Space IDX in percent
NAS_HD_SPACE_IDX="x"			# NAS HD Space IDX in GB
NAS_CPU_IDX="x"                # NAS CPU IDX
NAS_MEM_IDX="x"                # NAS MEM IDX
# Check if NAS in online
PINGTIME=`ping -c 1 -q $NASIP | awk -F"/" '{print $5}' | xargs`
echo $PINGTIME
if expr "$PINGTIME" '>' 0
then
  curl -s "http://$DOMO_LOGIN:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$NAS_IDX" | grep "Status" | grep "On" > /dev/null
       if [ $? -eq 0 ] ; then
       echo "NAS already ON"
       # Temperature HD
       HDtemp1=`snmpwalk -v 2c -c $COMMUNITY -O qv $NASIP 1.3.6.1.4.1.6574.2.1.1.6.0`
       # Send data
       curl -s -i -H "Accept: application/json" "http://$DOMO_LOGIN:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD1_TEMP_IDX&nvalue=0&svalue=$HDtemp1"
       # Used volume space in percent
       HDTotal=`snmpwalk -c $COMMUNITY -v2c -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.5.38`
       HDUsed=`snmpwalk -c $COMMUNITY -v2c -O qv $NASIP .1.3.6.1.2.1.25.2.3.1.6.38`
       HDFreePerc=$((($HDUsed * 100) / $HDTotal))
       # Send data
       curl -s -i -H "Accept: application/json" "http://$DOMO_LOGIN:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD_SPACE_PERC_IDX&nvalue=0&svalue=$HDFreePerc"
       # Free space volume in GB
       tmpHDUnit=`snmpwalk -v 2c -c $COMMUNITY -O qv $NASIP 1.3.6.1.2.1.25.2.3.1.4.38`
	   HDUnit=${tmpHDUnit%% *}
       tmpHDTotal=`snmpwalk -v 2c -c $COMMUNITY -O qv $NASIP 1.3.6.1.2.1.25.2.3.1.5.38`
	   HDTotal=${tmpHDTotal%% *}
       tmpHDUsed=`snmpwalk -v 2c -c $COMMUNITY -O qv $NASIP 1.3.6.1.2.1.25.2.3.1.6.38`
	   HDUsed=${tmpHDUsed%% *}
       HDFree=$((($HDTotal - $HDUsed) * $HDUnit / 1024 / 1024 / 1024))
       # Send data
       curl -s -i -H "Accept: application/json" "http://$DOMO_LOGIN:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_HD_SPACE_IDX&nvalue=0&svalue=$HDFree"
       # CPU utilisation
       CpuUser=`snmpwalk -v 2c -c $COMMUNITY -O qv $NASIP 1.3.6.1.4.1.2021.11.9.0`
	   CpuSystem=`snmpwalk -v 2c -c $COMMUNITY -O qv $NASIP 1.3.6.1.4.1.2021.11.10.0`
	   CpuUse=$(($CpuUser + $CpuSystem))
       # Send data
       curl -s -i -H "Accept: application/json" "http://$DOMO_LOGIN:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_CPU_IDX&nvalue=0&svalue=$CpuUse"
       # Free Memory Used in %
       tmpMemAvailable=`snmpwalk -v 2c -c $COMMUNITY -O qv $NASIP 1.3.6.1.4.1.2021.4.6.0`
	   MemAvailable=${tmpMemAvailable%% *}
       tmpMemtotal=`snmpwalk -v 2c -c $COMMUNITY -O qv $NASIP 1.3.6.1.4.1.2021.4.5.0`
	   Memtotal=${tmpMemtotal%% *}
       tmpMemShared=`snmpwalk -v 2c -c $COMMUNITY -O qv $NASIP 1.3.6.1.4.1.2021.4.13.0`
	   MemShared=${tmpMemShared%% *}
       tmpMemBuffer=`snmpwalk -v 2c -c $COMMUNITY -O qv $NASIP 1.3.6.1.4.1.2021.4.14.0`
	   MemBuffer=${tmpMemBuffer%% *}
       tmpMemCached=`snmpwalk -v 2c -c $COMMUNITY -O qv $NASIP 1.3.6.1.4.1.2021.4.15.0`
	   MemCached=${tmpMemCached%% *}
       MemFREE=$(($MemAvailable + $MemShared + $MemBuffer + $MemCached))
       MemUsepercent=$(((($Memtotal - $MemFREE) * 100) / $Memtotal))
	   #// For Available use MemUsepercent=$(((($MemFREE) * 100) / $Memtotal))
       # Send data
       curl -s -i -H "Accept: application/json" "http://$DOMO_LOGIN:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$NAS_MEM_IDX&nvalue=0&svalue=$MemUsepercent"
       echo "NAS ON"
       # Send data
       curl -s -i -H "Accept: application/json" "http://$DOMO_LOGIN:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$NAS_IDX&switchcmd=On&passcode=$DOMO_PASSCODE"
       # Temperature HD1
       # Send data
       # Send data
       # Send data
       # CPU utilisation
       # Send data
       # Send data
       fi
       curl -s "http://$DOMO_LOGIN:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=devices&rid=$NAS_IDX" | grep "Status" | grep "Off" > /dev/null
         echo "NAS already OFF"
           exit
           echo "NAS OFF"
             # Send data
               curl -s -i -H "Accept: application/json" "http://$DOMO_LOGIN:$DOMO_PASS@$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=switchlight&idx=$NAS_IDX&switchcmd=Off&passcode=$DOMO_PASSCODE"
           fi
fi
