Cheap Chinese WIFI module
Derik
Re: Cheap Chinese WIFI module
Post by Derik »
Try it in a few days to...
What is the switch i need to set the Sonoff?
Whit the Espeasy settings
Derik
Post by Derik »
alexsh1 wrote:I have Sonoff RF and this is not an easy process to flash this one as one has to touch the R21 pads with a screwdriver (pulls GPIO0 to GND to enter the flash mode) on the PCB before giving a 3.3 V power via FTDI
Please..
Alexsh
Where do in need to place the screwdirver??
I do have a 5 pins Sonoff..
Is there a other option.
Is there some that have a good how to..
I try to flash 3 sonoff with 3 different USB TTL ,..
And no succes with all...
some one have a idea/???
SweetPants
Post by SweetPants »
Derik wrote:some one have a idea/???
Read this article? http://tech.scargill.net/more-sonoff/
Driftvk
Post by Driftvk »
Has anybody tried putting espeasy on one of these sonoff switch/temp+humidty modules? https://www.itead.cc/sonoff-th.html
Software: Win2012R2, Domoticz, Mosquitto, Koenkk Zigbee2MQTT, Broadlink Python Plugin.
Hardware:CurrentCost128 3x IAMs, 5x Temperature sensor Wemos D1 Mini with 'ESPEasy', Zigbee via CC2531, ArduinoMega RFLink Gateway, Broadlink RM Mini3
alexsh1
Domoticz version: v3.8975
Post by alexsh1 »
Please..
Alexsh
Sorry, I have just seen this post.
No, there is no other way, unless you want to solder a wire (this is what I did at the end) - this is extremely difficult one due to the size of the board so unless you are comfortable with this, do not try to do it as you may destroy the board.
This is the fix for WiFi + 433Mhz version.
Find R21 pads with a magnifying glass. You have to touch the R21 pads with a screw driver BEFORE powering the board with 3.3V
DO NOT POWER THE BOARD WITH 220-240V!!!
This is the reference:
alexsh1
Post by alexsh1 »
Driftvk wrote:Has anybody tried putting espeasy on one of these sonoff switch/temp+humidty modules? https://www.itead.cc/sonoff-th.html
These ones must have the same board, but you will be on your own - I have not seen anyone modifying them. Why ordering it if you can order a WiFi one and add DHT11/22 with easyesp?
Westcott
Post by Westcott »
Hi All,
Much to my surprise I've managed to flash my Wifi-only Sonoff with ESPEasy v147, and configure it with its web interface.
I've managed to follow the "Tutorial Domoticz Switch" all the way to the bottom, apart from working out how to "toggle GPIO-0 " in the Testing section.
So, how to do the next step - control it from Domoticz?
Is there a tutorial for this anywhere?
UPDATE!
Added MQTT hardware to Domoticz, and can update a dummy switch with mosquitto-pub.
Westcott
Post by Westcott »
Further update!
No need for any of that MQTT malarkey!
It can be done by adding 'Devices' and 'Rules' with the ESPeasy web interface, and setting Domoticz Switch on/off actions to something like -
http://172.16.176.25/control?cmd=event,TurnOn
where TurnOn is a Rule.
And GPIO-0 is the pushbutton on a Sonoff 5-pin Wifi device.
toreandre
Post by toreandre »
Is there any info on how to controll the wifi module without flashing it with ESPeasy?
It seems like a timeconsuming prosess if its possible to send normal http commands to it from a dummyswitch in domoticz.
markjgabb
Domoticz version: 3.8153
Post by markjgabb »
Second tore Andre, surely we should just be able to directly send http to this?
I can see them on wish for $8 might buy a couple to see,
If any dev guys want to try adding direct support to domoticz pm me and I'll see send you a couple of them.
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
sincze
Domoticz version: 2024.4
Post by sincze »
superczar wrote:Just tried out one with ESP_easy firmware - Was a fairly easy process if you are a little famiilar with soldering
Works far better than my flaky (and expensive) Wemos -and small enough to be housed inside the wall electrical panels
Ordering a bunch of these doohickeys :D
tnx, for your post.
Ordered 2 to try to do the same ;-) :D
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
sincze
Post by sincze »
Both Sonoff Items arrved today.
- Soldered 5 pin header to the board and followed these instructions. (used some flux)
- https://www.youtube.com/watch?v=fN_QKOWvG1s
- My 5 pin devices have the PUSH button attached to GPIO0 so putting it in flash mode is easy.
They are now both running ESPEasy. :D
Just some images I also used to figure out the pins.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
krizzz
Post by krizzz »
Still doubting on how reliable these units are for €8. Something with 220v on it I would definitly want to trust.
sincze
Post by sincze »
krizzz wrote:Still doubting on how reliable these units are for €8. Something with 220v on it I would definitly want to trust.
A well I buy CoCo 433mhz (3) units for 15 euro's including a remote at the Hornbach..
They also switch 220v :D
So divide 15/3. From that point of vieuw 8 euro's seems reasonable. :D
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
krizzz
Post by krizzz »
But probably Hornbach only sells units aproved by TUV after testing. I even have a little bit more faith in this...
sincze
Post by sincze »
krizzz wrote:But probably Hornbach only sells units aproved by TUV after testing. I even have a little bit more faith in this...
+1 for you Krizz :lol:
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
krizzz
Post by krizzz »
But please know I am going to try and find a job for the switches to do Image. Also the sonoff's are not (yet) mentioned in the RAPEX http://ec.europa.eu/consumers/consumers ... dex_en.htm database of the EU. So it still looks like there safe. But I would rather see a test report Image
sincze
Post by sincze »
krizzz wrote: But please know I am going to try and find a job for the switches to do Image. Also the sonoff's are not (yet) mentioned in the RAPEX http://ec.europa.eu/consumers/consumers ... dex_en.htm database of the EU. So it still looks like there safe. But I would rather see a test report Image
That is a nice link. Really informative.
Do you use it a lot?
I heard of it but had never seen it.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
krizzz
Post by krizzz »
Me neither! Some guy at another forum poster the link. What i am curious about is when something Spears on the list. When somebody's house burned down?
sincze
Post by sincze »
Just the settings for easy_setup.
ESPEasy settings for switching a bulb for example.
And at the bottom the settings for the virtual switch in domoticz.
On: http://IP_Address_of_Sonoff/control?cmd=GPIO,12,1
Off: http://IP_Address_of_Sonoff/control?cmd=GPIO,12,0
Ow and for the internal LED ;-)
On: http://IP_Address_of_Sonoff/control?cmd=GPIO,13,0
Off http://IP_Address_of_Sonoff/control?cmd=GPIO,13,1
##UPDATE:
On the ESP Easy Under Tools -> Advanced, I enabled rules. http://www.letscontrolit.com/wiki/index ... rial_Rules
Under rules I entered:
on lamp_on do
    gpio,12,1
    gpio,13,0
endon
on lamp_off do
    gpio,12,0
    gpio,13,1
endon
on SW_1#Switch do
  if [SW_1#Switch]=1
    gpio,12,1
    gpio,13,0
    gpio,12,0
    gpio,13,1
  endif
endon
In this way If I call from domoticz:
On: http://IP_Address_of_Sonoff/control?cmd=event,lamp_on
Off: http://IP_Address_of_Sonoff/control?cmd=event,lamp_on
This will switch on / off the lamp AND the LED light inside of the Sonoff box. :D.
In addition pressing the PUSH button on the Sonoff will trigger the light as well and update the domoticz status.
A Slight modification in the device name was needed.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
